DAYTON AUDIO HTA50BT Hybrid Tube Amplifier BT5.0 2x25W / 4 Ohm
The HTA50BT is a stereo integrated amplifier remarkable for its hybrid construction. It indeed embeds a power amplification stage operating in class AB as well as a tube pre-amplification stage.
Reference : 15322
215,00 €tax incl.
179,17 € tax excl.
Warning, before connecting this amplifier you must select the power option matching your electrical network (220V or 110V).
Dayton Audio HTA50BT
Hybrid Tube Stereo Amplifier, USB, SPDIF, Bluetooth 5
Dayton Audio HTA100BT amplificateur tube entrée phono
The HTA50BT is a stereo integrated amplifier remarkable for its hybrid construction. It indeed embeds a power amplification stage operating in class AB as well as a tube pre-amplification stage. A rare design that borrows from contemporary amplification technologies while retaining the typical warm tones of tube circuits to rediscover all the pleasure of these sounds in a modern environment that is easy to connect to a recent High-Fidelity installation.
The HTA50BT stereo amplifier provides the roundness and richness of tube amplifiers while taking advantage of a completely up-to-date connection including no less than a USB, Bluetooth 5 and SPDIF input but also AUX inputs to be fully prepared for all home integration scenarios.
Flexibility
With an output power of 25 watts per channel under a load of 4 ohms, the HTA50BT offers ideal power reserve for the needs of almost any compact audio listening system.
In addition to the regular connectivity of a modern integrated amplifier (Coaxial SPDIF, Optical) which can connect the device to all of your digital sources (DAC, television, game console, etc.), the HTA50BT benefits from broad connectivity designed to dramatically simplify the lives of audiophiles equiped with devices using different technologies.
Bluetooth 5 (SBC & AAC) compatibility allows high quality wireless streaming that is easy to set up with the most common wireless audio sources (smartphone, tablet, laptop, streamer).
Finally, a USB input allows you to play FLAC, MP3, WMA, WAV, and APE audio files stored on an external device such as a hard drive or a USB pen drive.
On the output side, in addition to speaker terminals dedicated to its amplified output, the HTA50BT has a summed line output, very practical for connecting an active subwoofer and obtaining a complete 2.1 system. The latter is directly connected to the output of the preamplification stage.
Ergonomics and design
A superb retro design with surface mounted tubes as well as a solid aluminum housing make the HTA50BT a device with a distinct visual character that is sure to add some style into your audio installation.
Its discreet and sober interface offers a volume button directly accessible on the front.
The latter is complemented by playback controls (play / pause - next track / previous track) as well as a source selector with LED indicator.
The controls control playback from bluetooth and USB digital sources.
Power output25 WPC RMS @ 4 ohms
THD0.5% @ 50 WPC
Minimum speaker impedance4 ohms
Channel separation80 dB
SNR>85 dB
Frequency response20-20,000 Hz, ±2 db
Sub outputPreout for active subwoofer (HTA50BT is a full range amp with no internal crossover)
Preamplifier tube6K4 x 2, 6U1 x 2
TransistorsToshiba A1941 x 2, Toshiba C5198 x 2
BluetoothVersion 5.0
Supports Bluetooth codecsSBC and AAC
Digital audio DAC SNR96 dB
Digital audio DAC sample rateUp to 16-bit/ 48 kHz
Input impedance47k ohms (minimum)
Input sensitivity500 mV
Power110/220 VAC, 50/60 Hz
Dimensions6.3" (H) x 7.5" (W) x 9.2" (D)
Poids3Kg
OutputSubwoofer
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTube
Power (W)50.0
2 reviews
superbe petit ampli
très belle sonorité pour ce petit ampli
associé à des enceintes focal de 8 ohm le son est excellent le coté puissance est époustouflant car, utilisé dans une pièce de 16 mètres carrés, le bouton de volume est réglé quasiment au minimum pour une écoute très confortable
This review has been posted for DAYTON AUDIO HTA50BT Hybrid Tube Amplifier BT5.0 2x25W / 4 Ohm
Perfect
Fast delivery. Really good product for a very good price
The HTA50BT is a stereo integrated amplifier remarkable for its hybrid construction. It indeed embeds a power amplification stage operating in...
