FOSI AUDIO BT20A PRO Class D Amplifier TPA3255 Bluetooth 5.0 2x225W 4 Ohm
The Fosi Audio BT20A PRO is a compact and powerful Class D amplifier, offered at a very resonable price. Its amplifier stage uses a TI TPA3255 chips, capable of developing a power of 225W under 4Ω per channel.
4.8 / 5
Reference : 17556
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 09-09-2025.
Class D amplifier 2x225W 4 Ohm - Bluetooth 5.0
Fosi Audio BT20A Amplificateur
For its connections, the BT20A PRO is simple and efficient, with stereo RCA or Bluetooth 5.0 input, and plated speaker terminals output as well as a 3.5mm jack pre-output.
On its front, the BT20A PRO has a tone control allowing you to adjust the level of bass and treble, in order to adapt the reproduction of the device to your audio system and your preferences. In addition, a bluetooth pairing history deletion function is now available by holding down the volume button for a long time.
A Bluetooth code may be requested to connect to the amplifier, it is "0000" or "1234".
FOSI AUDIO BT20A Pro Amplificateur Class D 2x TPA3255 Bluetooth 5.0 2x300W 4 Ohm
A high-end amplifier chip
Its amplification stage uses a high-end TI TPA3255 amplification chip, capable of developing a power of 225W under 4Ω per channel. All while providing clear and detailed sound reproduction.
Customization of operational amplifiers
The DIP8 format OP-AMP NE5532 chip is easily replaceable. This can allow you to get your favorite sound signature.
Front and back view of the BT20A PRO
1Power indicator
2Power switch
3Treble control
4Bass control
5Volume control / Erasing Bluetooth pairing history
6RCA Stereo input
7Jack 3.5mm pre-out
8Speaker terminal
9Power plug
10Bluetooth antenna
Technical characteristic
Product typeAmplifier stereo
Amplification typeClass D
Input1x RCA stere'o
Bluetooth 5.0
OutputSpeaker terminal
Pre-out jack 3.5mm
Amplifier chipTI TPA3255
Output power2x 225W / 4 Ohm @ 48V (1% THD)
2x 300W / 4 Ohm @ 48V (10% THD)
2x 110W / 4 Ohm @ 32V (1% THD)
2x 135W / 4 Ohm @ 32V (10% THD)
Accepted impedances2-8Ω
Frequency response20 Hz-20 kHz (± 1,2 dB)
THD0.005%
SNR≥ 108dB
Bluetooth CodecsACC
SBC
Tone controlBass / Treble with midpoint
Power supply voltage24V-48V DC (AC adaptateur included)
Dimensions (L*P*H)166x105x35mm
Net Weight547g
ColorBlue
Package1x Fosi Audio BT20A PRO
1x Power supply 32V 5A
ColorBlue
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)225.0
9 reviews
Pratique et efficace
appareil conforme à la description.
Suffisant pour animer un système c=secondaire dans une petite pièce. Réglages de tonalité simple et pratique comme c'était le cas autrefois. Utile et indispensable pour gérer la dépendance à la fréquence et/ou les enregistrements déséquilibrés.
Avec l'alimentation de 32 V, la puissance est cependant limitée (4entre 40 et 70 W selon impédance des enceintes), mais je le savais avant de concrétiser l'achat. Pour un aperçu des performances réelles, il vaut mieux consulter les mesures faites sur le site ASR. Pour disposer d'au moins 100 W, l'alimentation de 48 V est indispensable mais sera un surcout.
Peut-être serait-il judicieux de moduler le prix en fonction de l'alimentation fournie en laissant le choix au client dès l'achat.
Laurent G.
This review has been posted for FOSI AUDIO BT20A PRO Class D Amplifier TPA3255 Bluetooth 5.0 2x225W 4 Ohm
Small effective amp.
With TPA3255 chip it's a really compact and perfect match to my needs. With tone control i can adjust the sound to fit my situation. Bought 12pcs to a exhibition.
Très bon petit ampli , écoute améliorée après changement d'aop par un muse 8920 , aucun souffle à vide avec l'alimentation fournie , pas de chauffe , excellent rapport qualité-prix.
La fin... Excellent rapport qualité prix !
Mauvaises manip clavier qui valident illico le message en cours de rédaction...
Remplacement des AOP NE5532 d’origine par des Burson V5i, puis des OP275 en enfin des oracles II.
Avec ces trois AOP on a enfin des voix timbrées et incarnées, des aigus variés avec du poids et de la matière, des cuivres rutilants, des instruments à corde en vrai bois d'arbre et non en plastique et toujours une bonne dynamique. Disparues les sifflantes et petites duretés/raideurs, c'est nettement plus expressif que les NE5532 qui sonnent un peu secs et monochromes en comparaison.
L'image sonore est globalement mieux remplie avec une largeur correcte, là où elle reste un peu coincée dans les HP avec les AOP d’origine. Avec une préférence envers l'OP275 par rapport au Burson V5i qui est moins homogène.
L'Oracle après 24 heures de fonctionnement non stop est le plus homogène des trois, avec de beaux timbres, un bon équilibre, pas de sifflantes ou dureté, une dynamique bien répartie, Bref un bon niveau de transparence qui rend hommage aux enregistrements. L'image sonore est large avec une bonne profondeur, du relief et les ambiances de prise de son son palpables. Un peu faible en niveau dans l’infra (via la sortie sub).
Bref on peut modifier de façon substantielle le rendu du Fois BT20a Pro en changeant d'AOP. Selon les enceintes associées, on peut arriver à un haut niveau de qualité globale, sans frustration comparé à de nombreux ampli plus classiques et pas ridicule face à mon SE 845 DIY, qui va certes plus loin en tout mais à quel prix.
La qualité en Bluetooth est moyenne, graves écourtés et aigus proéminents à atténuer sur l'ampli.
suite
Bref l'alim à découpage d'origine n'est pas silencieuse sur des enceintes à haut rendement et l'ampli souffle un peu.
Le niveau de la sortie sub est un poil faible en niveau mais ça passe.
Au niveau écoute au bout de quelques jours de fonctionnement, c'est assez surprenant pour une si petite boite et en regard du prix. C'est propre, dynamique, droit, très détaillé, mais un peu sec et monocorde, avec des sybillances et un aigu qui manque de poids et de texture.
L'image sonore correcte mais qui reste un peu coincée dans les HP et ça m
The Fosi Audio BT20A PRO is a compact and powerful Class D amplifier , offered at a very resonable price. Its amplifier stage...
