The Fosi Audio BT30D is a 2.1-channel Class D amplifier capable of developing 2x50W + 100W power under 4 ohm thanks to two TI TPA3116D2 amplifier chips. It also features Bluetooth 5.0 functionality for stable, high-quality wireless reception. The front panel features no fewer than 5 potentiometers. The first three are for volume control as well as bass and treble equalization, while 2 others offer subwoofer frequency cutoff and subwoofer volume control. The rear panel features an RCA input, a speaker terminal output and two subwoofer outputs: one for passive subwoofer and one for active subwoofer. This small BT30D amplifier is ideal for setting up a 2.1-channel home theater system and enjoying immersive bass.
Inside the Fosi Audio BT30D amplifier are two TI TPA3116D2 amplifier chips, providing 2x 50W + 100W power at 4 ohms. That's a comfortable reserve of power for providing a 2.1-channel system.
In addition to its RCA input, the BT30D features a Bluetooth 5.0 reception chip, enabling you to use a phone or tablet to stream audio remotely.
1 | Power button |
2 | Input mode LED indicator |
3 | Subwoofer volume control |
4 | Subwoofer frequency cutoff |
5 | Treble equalization |
6 | Bass equalization |
7 | Volume control |
8 | Bluetooth antenna |
9 | RCA input |
10 | Active subwoofer output |
11 | Speaker terminals |
12 | Active subwoofer output |
13 | Power supply 12V-24V DC |
Product type | Amplifiier |
Channels | 2.1 |
Amplification chip | TI TPA3116D2 |
Inputs | 1x RCA stereo Bluetooth |
Ouputs | Speaker terminals 1x Passive subwoofer output on speaker terminal 1x Active subwoofer output |
Ouput power | 2x 50W + 100W |
THD | ≤ 0.04% |
SNR | ≥ 98dB |
Frequency response | 20Hz-20kHz(±3dB) |
Input sensitivity | ≤ 280mW |
Termination impedance | 2-8 ohm |
Subwoofer cutoff frequency | 20-200Hz |
Bluetooth range | 15m unobstructed |
Power supply | 12V-24V |
Dimensions | 118 x 132 x 35mm |
Color | Black |
Package | 1x Fosi Audio BT30D 1x 24V DC 4.5A power adapter with power cable 1x Bluetooth antenna |
Input | Bluetooth |
Input | RCA |
Output | Speaker terminal |
Output | RCA |
Color | Black |
Channel | 2.1 |
Class | Class D / T |
Amplifier chip | TPA3116D2 |
Power (W) | 50.0 |
Remote Control | No |
