FOSI AUDIO M04 Mono/Subwoofer Amplifier
The Fosi Audio M04 is a Class D amplifier based on a TPA3116 chip and capable of delivering 100W @ 3 ohm. The M04 has an RCA input and a speaker terminal output. It can be used with speakers as a mono amplifier, thanks to its “PBTL” mode, or with a passive subwoofer, thanks to its “SUB” mode.
Reference : 19834
59,00 €tax incl.
49,17 € tax excl.
Shipping date: 27-05-2026.
Fosi Audio M04 Mono/Subwoofer Amplifier Class D TPA3116 1x100W @ 3ohm
Fosi Audio M04 picture
The Fosi Audio M04 is a Class D amplifier based on a TPA3116 chip and capable of delivering 100W into 3 ohm. The M04 has an RCA input and a speaker terminal output. It can be used with speakers as a mono amplifier, thanks to its “PBTL” mode, or with a passive subwoofer, thanks to its “SUB” mode. A potentiometer on the front panel adjusts the subwoofer output crossover frequency from 20Hz to 200Hz. It is therefore ideal for users wishing to feed a subwoofer for immersive sound reproduction, or for users wishing to set up a dual-mono HiFi system.
Fosi Audio M04: a TPA3116 amplifier chip
Fosi Audio has chosen to use a TPA3116 amplifier chip in its M04 amplifier. This enables the M04 to develop up to 100W of power at 3 ohms.
Photo of TPA3116 chip
Fosi Audio M04: PBTL/SUB modes
The Fosi Audio M04 features a switch on the front panel to select between PBTL and SUB modes. PBTL mode enables it to power a passive loudspeaker, while SUB mode, as its name suggests, enables it to power a passive subwoofer. The M04 has an overall frequency response of 20Hz-20kHz (±3db), but a potentiometer lets you adjust the subwoofer cutoff frequency from 20Hz to 200Hz.
Fosi Audio MC04 operating modes
Fosi Audio M04 overview
1Power LED indicator
2Operating mode selection switch : PBTL/SUB
3Subwoofer cutoff frequency control
4Power button/Volume control
5Analog input RCA Stereo
6Output on speaker terminals (SUB/SPK)
7DC 12-24V jack power port
Product typeMono/subwoofer amplifier
Amplification chipTI TPA3116
Input1x stereo RCA
Output1x Speaker terminals
Output power100W @ 3 ohms
Minimum load2-8Ω
INput sensitivity600mv
SNR≥ 102dB
THD≤ 0.02% (1KHz, 1W)
Frequency response20Hz-20KHz (±3db)
Subwoofer output cut-off frequency setting20Hz-200Hz
Power supply12-24V DC via DC jack (19V 4.74A power supply included)
Dimensions103x57x43mm
Weight175g
Package1x Fosi Audio M04 Mono/Sub Amplifier
1x 19V 4.74A power adapter
OutputSpeaker terminal
Channel1 (Mono)
Amplifier chipTPA3116
Power (W)100.0
FOSI AUDIO M04 Mono/Subwoofer Amplifier Class D TPA3116 1x100W 3ohm
The Fosi Audio M04 is a Class D amplifier based on a TPA3116 chip and capable of delivering 100W @ 3 ohm. The M04 has an RCA input and a speaker...
