FOSI AUDIO ZA3-48V Stereo / Mono Amplifier
This small, compact and powerful Fosi Audio ZA3 integrated amplifier has the particularity of being able to operate in both stereo and mono mode. It integrates two TI TPA3255 amplifier chips mounted in DIP8, enabling it to deliver power up to 2x150W or 1x240W @ 4Ω. It features a balanced stereo input on XLR in addition to its stereo RCA input, as well as speaker terminals and an active subwoofer output.
4.2 / 5
Reference : 18425
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 12-05-2026.
FOSI AUDIO ZA3-48V
 Stereo / Mono Class D Amplifier TPA3255 2x150W 4 Ohm / 1x240W 4 Ohm
FOSI AUDIO ZA3 Stereo / Mono Class D Amplifier TPA3255 2x150W 4 Ohm / 1x240W 4 Ohm
This small, compact and powerful Fosi Audio ZA3 integrated amplifier has the particularity of being able to operate in both stereo and mono mode. It integrates two TI TPA3255 amplifier chips mounted in DIP8, enabling it to deliver power up to 2x150W or 1x240W under 4Ω. It features a balanced stereo input on XLR in addition to its stereo RCA input, as well as speaker terminals and an active subwoofer output. It also features a 12V trigger. This makes it versatile, offering you the possibility of numerous types of Hi-Fi installations integrating one or more Fosi Audio ZA3 amplifiers. Its power supply is DC, with a voltage range from 24V to 48V DC.
Inside the Fosi Audio ZA3 is one TI TPA3255 chip per channel. This is what allows it to develop its high power, SNR greater than 106dB and THD at 0.006%.
Quality components
The Fosi Audio ZA3 features high-quality components: German Weimar high-frequency filters, Omron relays, dedicated operational amplifiers for balanced input and subwoofer output, Japanese ELNA capacitors, etc.
As NE5532 AOPs are DIP8 mounted, they are easily replaceable to personalize your listening experience. The following AOPs are compatible: Sparkos SS3602, MUSES02, OPA2134PA , OP249, AD827, RM4558, LM4562, etc.
FOSI ZA3 rear panel
1XLR balanced stereo input
2RCA stereo input
3Subwoofer output
4Speaker terminals
5DC 24V-48V power supply
612V Trigger
Product typeIntegrated amplifier
Amplification chipTI TPA3255
Inputs1x RCA stereo input
1x XLR balanced stereo input
1x Trigger 12V on Jack 3.5mm
OutputsSpeaker terminals
Subwoofer output
Trigger
Input sensitivity0.775V
SNR 106dB
Dynamic range 106dB
THD0.006%
Frequency response20Hz-20kHz (±0.1dB)
Supported speaker impedance2-4-8Ω
Output powerMode stéréo : 2x 150W @ 4Ω
Mode mono : 1x 240W @ 4Ω
Power supply voltage24-48V DC
Dimensions155 x 184 x 51mm
Weight838g
Package1x Fosi Audio ZA3 integrated amplifier
1x Power supply 48V DC 5A
InputXLR
OutputSpeaker terminal
OutputSubwoofer
Channel2 (Stereo)
Channel1 (Mono)
Amplifier chipTPA3255
Power (W)150.0
12 reviews
Musicalité oui, mais puissance très moyenne...
Achetez pour remplacer temporairement mon ampli à lampe (WorldAudio Design Kit6550, Push-pull 4x6550 donné pour 2x40w), je suis assez "déçu" par le niveau de puissance.
Intégré dans mon installation HC, quand j'ai réglé les niveaux, j'ai été obligé de pousser le volume de l'ampli au max de rajouter quelques dB alors que l'ampli à lampe était seulement à 75%...
Je ne dis pas que c'est pas assez fort, je dis juste que les chiffres donnés semblent assez sur évalués (auta,t que je puisse comparer).
Par contre c'est vrai que côté musicalité, pour le prix, y a pas grand chose à regretter.
Les basses sont généreuses, c'est bien détaillé, pas mal de ce côté là (surtout au vu du prix).
This review has been posted for FOSI AUDIO ZA3-48V Stereo / Mono Class D Amplifier TPA3255 2x150W 4 Ohm / 1x240W 4 Ohm
Petit mais costaud dans le haut grave et medium aigu
Mon 2 ième achat pour un ami qui l'utilise pour ses enceintes 3 voies diy monter par lui même en multi amplification il l'as utilser sur son medium 18 Sound 8NW650 et aigu beyma hd1030 parfait pour les fréquences haut graves et aigu , les borniers sont pitoyables pour les branchements mais on peut pas en demander plus pour le prix .
le meilleur de fosi
achetés puis revendus pour fosi v3 mono, je regrette cet echange. Meme si v3 mono est plus propre sur le signal, le plaisir d' écoute( spacialisation, detail, relief) est bien meilleur sur les za3
Incroyable à ce prix !!!
Vu les débats médiatiques sur cet appareil j’ai tenté l’achat pour un équipement de bureau. Je ne suis pas déçu du résultat avec des enceintes TRIANGLE COMÈTE 40TH.
Pour en savoir un peu plus avec un ami nous l’avons connecté et essayé sur du matériel beaucoup plus cher (chacun jugera de la qualité de ces appareils) Préampli ACCUPHASE enceintes B&W série 800 D4 câblage AUDIOQUEST dans une pièce de 35m2 et le résultat est tout simplement impressionnant au regard du prix.
Une écoute très naturelle sur tout les registres pas de limitation de puissance ressentie . Évidemment le niveau d’écoute était modéré mais suffisant.
L’amplification numérique c’est l’avenir. Je serai curieux de tester les blocs mon dans les mêmes conditions. Bonnes écoutes à tous. Philippe.
Good for the money
For your information, I have thoroughly tested this device for a month with different OPAs and the result is that it is good for the money and for me personally only good for the near field listening with smaller speakers. It has a warm sound but with digital veil even with the Sparkos OPAs.
 (3)
 (3)
This small, compact and powerful Fosi Audio ZA3 integrated amplifier has the particularity of being able to operate in...
