FOSI AUDIO HT4S Amplifier Bluetooth 5 Channels
The HT4S from Fosi Audio is a compact integrated power amplifier with 5 channels capable of delivering 30W each thanks to two TPA3116 amplifier chips.
Reference : 19622
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 14-10-2025.
Fosi Audio HT4SBluetooth Amplifier 4.1/5.0/5.1 Class D TPA3116 5x30W 4Ω
Fosi HT4S : 3/4 view
The HT4S from Fosi Audio is a compact integrated amplifier with 5 channels capable of delivering 30W each thanks to several TPA3116 amplifier chips.
For even greater flexibility, the HT4S can alternate between 5.0 and 4.1, allowing you to use it in a 5-speaker full-range configuration or reserve one of the channels for a passive subwoofer. Furthermore, the HT4S has a pre-out so you can connect an active subwoofer and enjoy a 5.1 surround configuration.
Finally, for even more versatility, the HT4S offers a Bluetooth input in addition to the Toslink optical input and the 3.5mm jack auxiliary input. As an aesthetic touch, the light strip on the front of the device changes colour according to the input used: blue for Bluetooth, orange for the auxiliary input and red for the optical input.
Fosi Audio HT4S: FLAT or SUB mode
The subwoofer function of the Fosi Audio HT4S can be activated via a selector switch for a 4.1 configuration using the speaker terminals. FLAT mode allows the 5 terminals to output the full frequency range, while SUB mode applies a crossover to the 5th terminal to output a 20Hz-300Hz signal for coupling a passive subwoofer. Use of the FLAT mode, meanwhile, offers the possibility of a 5.1 system using an active subwoofer with the 3.5mm pre-out jack output.
Photo of the Fosi Audio HT4S sub switch
Photo of Fosi Audio HT4S LEDs
Fosi Audio HT4S: audio input LED indicator
A LED indicator lets users quickly know which input source is being used:
  • Bluetooth = blue
  • Optical Toslink = red
  • AUX jack 3.5mm = orange
Fosi Audio HT4S: multiple uses
The Fosi Audio HT4S is ideal for home cinema and Hi-Fi set-ups, but can also be used with up to 5 bass shakers/exciters for an immersive gaming setup.
Example of configuration with the Fosi Audio HT4S
Fosi Audio HT4S: a comprehensive control interface
On the front panel of the Fosi Audio HT4S, you'll find a relatively comprehensive control interface for adjusting bass and treble tones, overall volume, and also the volume of a passive subwoofer.
Fosi Audio HT4S interface
Fosi HT4S : function description
Product type5-channel integrated amplifier
Amplification typeClass D
Amplification chipsTPA3116
Number of channels5.0
4.1
Inputs1x Aux Jack 3.5mm
1x Optical Toslink
Bluetooth
Outputs1x Pre-out
5x Speaker terminals
Output power5.0 : 5x30W 4Ω
4.1 : 4x30W + 1x60W 4Ω
Output impedance4-8Ω
Crosstalk79dB
Total harmonic distortion (THD)0.03%
Signal-to-noise ratio (SNR)88dB
Dynamic range89dB
Noise floor350µV
Frequency response20Hz - 20kHz (±0.5dB)
Power supply voltage110V - 240V AC
Dimensions284 x 178 x 100mm
Weight1.8kg
Package1x Fosi Audio HT4S
1x Power cord
1x Bluetooth antenna
1x 3.5 mm Jack cable
1x Remote control
InputJack 3.5mm
OutputJack 3.5mm
OutputSpeaker terminal
Channel5
Amplifier chipTPA3116
Power (W)30.0
Power (W)60.0
Remote ControlYes
FOSI AUDIO HT4S Amplifier Bluetooth 5 Channels Class D 2xTPA3116 5x30W 4Ω
