SHANLING EA5 PLUS Stereo amplifier Streamer DAC AK4493EQ 100AS2 WiFi DLNA AirPlay Bluetooth MQA aptX HD LDAC 2x100W 4Ω
8%
The Shanling EA5 Plus is an extremely versatile streamer, DAC, amplifier and headphone amplifier. It thus allows the integration of a complete connected audio system, as practical as it is efficient. Indeed, the EA5 Plus benefits from a careful technical architecture, which provides a dynamic, rich and precise sound reproduction and its Android operating system offers access to a wide range of applications.
Reduced price!
Reference : 17332
Limited time offer:
929,00 €tax incl.
-8%
854,68 €tax incl.
712,23 € tax excl.
Shipping date: 02-05-2025.
Shanling EA5 Plus
Streamer DAC Amplifier AK4493EQ ICEpower 100AS2 WiFi DLNA AirPlay Bluetooth MQA aptX HD LDAC 2x100W 4Ω
Shanling EA5 Plus Lecteur Réseau DAC Amplificateur AK4493EQ ICEpower 100AS2 WiFi DLNA AirPlay Bluetooth MQA aptX HD LDAC 2x100W 4Ω
AKM AK4493 DAC
The digital/analog conversion stage of the Shanling EA5 Plus uses an AKM DAC AK4493EQ chip, providing a smooth and natural sound reproduction but also very accurate. This chip also supports high-resolution audio streams up to PCM 32bit 768kHz and DSD512.
A powerful amplifier stage
Powerful, the EA5 Plus' amplifier section takes advantage of its own Class D ICEpower 100AS2 amplifier module. This one allows it to develop a comfortable power of 2x 100W under 4Ω with precision and dynamism.
Dedicated headphone amplifier
The EA5 Plus has a dedicated headphone amplifier stage, using OP+BUF architecture. This ensures low distortion, perfect control and impressive power. It is also combined with the brand's CPAF low-pass filtering technology for consistent phase throughout the frequency range. Two TPA6120A2 amplifier chips, one for each channel, are also used. These provide excellent performance with low distortion and very good responsiveness.
KDS Clocks
The EA5 Plus circuitry also uses two Japanese KDS oscillators and an algorithm developed by Shanling to effectively reduce jitter and ensure high clock accuracy.
WiFi & Streaming
True network player, the EA5 Plus benefits from WiFi 2.4/5G connectivity and RJ45 Ethernet input. It supports DLNA/UPnP and AirPlay transmission protocols, allowing you to access files stored on your network devices, whether it's a computer, a NAS or a smartphone.
Bluetooth
In addition to its WiFi connectivity, the EA5 Plus has a bi-directional Bluetooth chip, allowing it to function as both a transmitter and receiver. This makes it extremely easy to stream music from a smartphone. The chip also supports the high resolution codecs LDAC, LHDC and aptX HD.
Control app
The Eddict Player application, which can be downloaded free of charge for Android and iOS devices, allows you to take control of your EA5 Plus from your smartphone or tablet. An ergonomic and intuitive graphical interface accompanies you to access your music and device features as easily as possible.
A sure versatility
Thanks to its many features and extensive connectivity, the Shanling EA5 Plus has no problem finding its place in the vast majority of audio systems. It can be used in a variety of scenarios, from headphone amplifiers to home theater systems, DACs, network players, or all of these functions at the same time.
1Coaxial input
2Optical input
3USB-B input
4USB-A input (USB Host)
5Ethernet RJ45 input
6Power button
7Stereo RCA input
8Stereo RCA output
9Speaker output
10Power input
MQA decoding
The EA5 supports the decoding and playback of MQA (Master Quality Authenticated) files up to MQA 8X. This format allows you to enjoy a sound reproduction as close as possible to the original studio recording.
AGLO Technology
Thanks to AGLO (Android Global Lossless Output) technology, music from every application is processed correctly and in full quality, without any degradation from the Android system processes.
Product typeStreamer
DAC
Amplifier
Inputs1* Coaxial
1* Optical Toslink
1* USB-B
1* USB-A (USB Host)
1* Ethernet RJ45
1* Stereo RCA
Outputs1* Stereo RCA
Speaker terminals
Wireless connectivityWiFi 2.4/5G
Two-way Bluetooth 4.2
DAC chipAKM AK4493
Amplifier moduleICEpower 100AS2
Headphone amplifier chips2* TPA6120A2
Supported Bluetooth codecsTransmission: SBC, aptX, aptX HD, LHDC, LDAC
Reception: SBC, LDAC
Screen4.7"
720*1280px
OSAndroid
Supported formatsDSF, DFF, DXD, APE, FLAC, WAV, AIFF, AIF, DTS, MP3, WMA, ACC, OGG, ALAC, MP2, M4An AC3, M3U, M3U8, ISO
Supported sampling ratesPCM up to 32bit 768kHz
Native DSD up to DSD512
Adjustable gain4 levels
Micro SD card supportUp to 2To
Digital filters6 presets
Output power2*100W @ 4Ω
2*55W @ 8Ω
Frequency response20Hz-20kHz (-0.5dB @ Standard mode)
20Hz-20kHz (+3dB @ 100Hz Game mode)
20Hz-20kHz (-3dB @ Desktop mode)
THD+N0.002% (A-Weighted @ 0.5V)
SNR105dB @ 8Ω (A-Weighted)
Noise71dB @ 8Ω (A-Weighted)
Channels separation66dB @ 8Ω
RCA output measurements
Output levelLow: 0.82V
Medium: 1.4V
High: 3.0V
Turbo: 4.8V
Frequency response20Hz-40kHz (-0.5dB)
SNR118dB @ 32Ω (A-Weighted)
Noise107dB (low gain)
Headphone output measurements
Output power570mW @ 32Ω
THD+N0.0029% @ 32Ω (A-Weighted @ 0.5V)
Dynamic range112dB @ 32Ω (A-Weighted, high gain)
Channels separation70dB @ 32Ω
SNR117dB @ 32Ω (A-Weighted, high gain)
Noise106dB (low gain)
104dB (others gain level)
Output impedance< 0.8Ω
Supply voltage220-240VAC (Cable supplied)
Dimensions (L*P*H)188*238*55mm
InputRJ45
InputWiFi
OutputBluetooth
OutputSpeaker terminal
DAC / ADC ChipAK4493EQ
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
Channel2 (Stereo)
Amplifier chipICEpower 100AS2
Power (W)100.0
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsTidal
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsDLNA
The Shanling EA5 Plus is an extremely versatile streamer, DAC, amplifier and headphone amplifier. It thus allows the integration of a complete...
