Pas de sortie Sub sur ce modèle. Je me permet de le rajouter en commentaire pour les potentiels acheteurs, mon mail à audiophonics pour corriger l'erreur étant resté à ce jour sans effet.
The SMSL A200 amplifier is a Class D amplifier incorporating two Infineon MA12070 amplifier chips for output power of up to 2x70W under 4 ohm. Versatile and compact, the A200 features extensive connectivity with analog RCA input, optical Toslink input and coaxial input, as well as USB-C and an HDMI ARC port. A Bluetooth 5.0 chip also enables wireless reception. Output is via speaker terminals. On the front panel, there are two rounded VUmeters and a display for an aesthetically pleasing user experience. Bass and treble can be adjusted, in addition to the volume control.
SMSL has chosen to integrate two Infineon MA12070 Class D amplifier chips, giving the A200 an output power of up to 2x70W at 4 ohms.
A Bluetooth 5.0 chip enables the SMSL A200 to benefit from wireless reception. So, for example, you can send your music directly from your smartphone.
An HDMI ARC port enables the A200 amplifier to retrieve the signal from a TV set for an immersive TV experience using your Hi-Fi speakers.
1 | Right channel Vumeter |
2 | Left channel Vumeter |
3 | Display |
4 | Multifunction button |
5 | SPDIF coaxial input |
6 | Bluetooth antenna connector |
7 | Stereo RCA input |
8 | Toslink optical input |
9 | HDMI ARC input |
10 | Entrée USB-C |
11 | Right channel speaker terminal |
12 | Left channel speaker terminal |
13 | Power switch |
14 | IEC power supply |
Product type | Integrated amplifier |
Amplification type | Class D |
Amplification chip | 2x Infineon MA12070 |
Inputs | 1x Stereo RCA 1x Optical Toslink 1x SPDIF Coaxial 1x USB-C 1x HDMI ARC Bluetooth |
Sortie | Speaker terminals |
Output power | 2x 70W @ 4 Ohm |
Frequency response | 20Hz - 20kHz |
THD+N | 0.013% |
Channel separation | -94dB (1kHz) |
INput sensitivity | -10dB |
SNR | 102dB |
Tone adjustment | Bass: -5dB/+5dB Treble: -5dB/+5dB |
Power consumption | 36W Standby : <0.5W |
Dimensions | 180x47x171mm |
Weight | 1.07kg |
Color | Black |
Package | 1x SMSL A200 amplifier 1x Remote control (AAA battery no included) 1x Bluetooth antenna 1x Power supply cable |
Input | USB |
Input | SPDIF |
Input | Bluetooth |
Input | RCA |
Input | Optical |
Input | HDMI ARC |
Output | Speaker terminal |
Color | Black |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | Infineon MA12070 |
Power (W) | 70.0 |
Remote Control | Yes |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
philippe L.
