SMSL PA-X Stereo / Mono Amplifier
The SMSL PA-X is an innovative amplifier that uses Gallium Nitride (GaN) transistors to offer 2x250W amplification at 4Ω. Its versatility also enables it to operate in pure mono mode, delivering an impressive 500W into 8Ω. Every component of the PA-X has been meticulously selected to achieve outstanding audio performance, with an incredibly low harmonic distortion rate of 0.0003% and a signal-to-noise ratio of 115dB.
By buying this product you get 76 loyalty points
Reference : 20693
769,00 €tax incl.
640,83 € tax excl.
SMSL PA-X Stereo / Mono Amplifier Infineon GaN 2x250W 4 Ohm / 1x500W 8 Ohm
SMSL PA-X : 3/4 view
SMSL PA-X: Transistor GaN FET
The PA-X uses GaN FET transistors for its amplifier stage. These transistors offer significantly higher efficiency than conventional silicon transistors, minimizing energy losses during switching and reducing heat generation. In addition, GaN transistors are distinguished by their extremely high switching speed, of the order of 1MHz. This increased speed has several notable advantages: it eliminates switching noise in circuits, considerably reducing background noise, and it enables a much faster response time, instantly adapting to variations in power demand for greatly improved audio dynamics.
SMSL PA-X : comparison between a silicon transistor and a GaN transistor
SMSL PA-X: Optimised switched-mode power supply
Le PA-X intègre un étage d'alimentation à découplage spécialement conçu pour une utilisation audio exigeante. Cette alimentation est capable de fournir une puissance considérable tout en maintenant un fonctionnement parfaitement silencieux. Pour une sécurité accrue, le PA-X est équipé de circuits de protection contre la surchauffe et la suralimentation.
SMSL PA-X : power supply stage
SMSL PA-X : speaker terminals
SMSL PA-X : Gold-plated outputs
Les connecteurs de sortie du PA-X sont plaqués or afin de les protéger efficacement contre l'oxydation et la corrosion, tout en assurant une excellente conductivité électrique pour une transmission du signal audio optimale et sans perte.
Overview of SMSL PA-X
SMSL PA-X : Product description diagram
1Control knob
2Remote control receiver
3Power indicator light
4Screen
5Right speaker output (stereo)
6Left speaker output (stereo)
7IEC socket
8Speaker output + (mode)
9Speaker output - (mode)
10Stereo line input (RCA)
11Stereo XLR input
12Mono XLR input
Product typeIntegrated amplifier
Amplification componantInfineon GaN FET transistors
Inputs1x Stereo RCA input
1x Stereo XLR input
1x Mono XLR input
OutputSpeaker terminal
Total harmonic distortion more noise (THD+N)0.003%
Signal-to-noise ratio (SNR)115dB
Dynamic range115dB
Channel separation75dB
Input sensitivityStereo RCA: 0.96Vrms/22kΩ
Stereo XLR: 2.1Vrms/22kΩ
Mono XLR: 2.7Vrms/22kΩ
Stereo output power2x 250Wrms @ 4Ω
2x 200Wrms @ 8Ω
Mono output power1x 500Wrms @ 8Ω
Volume control chipPGA2311
Power supply100-240V AC
Power consumptionStandby: <0.5W
In use: 40W
Dimensions240.35 x 250.50 x 52.40mm
Weight2.57kg
ColorWhite
Package1x SMSL PA-X
1x Remote control
1x Power cable
SMSL PA-X : Measurement
InputXLR
ColorWhite
Channel2 (Stereo)
Channel1 (Mono)
ClassN/A
Amplifier chipTransistors
Power (W)500.0
Power (W)250.0
Remote ControlYes
Download
The SMSL PA-X is an innovative amplifier that uses Gallium Nitride (GaN) transistors to offer 2x250W amplification at 4Ω. Its versatility...
