SMSL PA40 Integrated Amplifier
SMSL's PA40 is an integrated amplifier based on Infineon's MA5332MS Class D amplifier chip, delivering 2x160W of power at 4Ω with a harmonic distortion of just 0.004%, for crystal-clear sound reproduction with low power consumption and very little heat generation. Furthermore, SMSL has selected a NJU7391 volume control chip with very low distortion, giving you control over volume attenuation without coloring the final sound rendering.
Reference : 20208
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 16-07-2025.
SMSL PA40 Integrated Amplifiers Stereo Class D Infineon MA5332MS 2x160W 4Ω
SMSL PA40 : Front view
SMSL's PA40
SMSL PA40: MA5332MS amplification chip
The PA40's amplifier stage is based on an Infineon MA5332MS chip. This chip provides 2x160W of Class D amplification at 4Ω. This Class D amplifier has all the qualities of this technology, with extremely limited heat generation and an impressive efficiency of 95%.
SMSL PA40 : MA5332MS chip
SMSL PA40 : NJU7391 chip
SMSL PA40: NJU7391 volume control chip
The PA40 is equipped with an NJU7391 volume control chip developed by Nisshinbo Micro Devices, enabling control of volume attenuation via a very low noise and distortion ladder resistance circuit, ensuring transparent volume control to the ear.
SMSL PA40: Audiophile-quality component
The PA40 relies on numerous audiophile-quality components to guarantee optimum listening quality. Furthermore, SMSL has integrated protections against overload, overheating and undervoltage, ensuring the unit's longevity over time.
SMSL PA40 : Audiophile-quality component
SMSL PA40 : Power supply
SMSL PA40: Integrated power adapter
The PA40 benefits from a power supply integrated into the casing, reducing the electromagnetic interference that could be created by an external AC adapter. Furthermore, the power supply stage used provides a stable supply of energy to the device's components, guaranteeing optimum performance in any situation.
SMSL PA40: Adjustable equalizer
The PA40 also features an equalizer with several presets, allowing you to boost bass or treble at will, depending on your taste or the style of music you're listening to.
SMSL PA40 : Device on driver
Product typeIntegrated amplifier
Input1x Stereo RCA
Output2x Speaker terminal
THD+N0.004%
SNR100dB
Crosstalk72dB
Input sensitivityLow gain : 580mV
High gain : 315mV
Input impedanceLow gain : 20kΩ
High gain : 20kΩ
Output power2x160W @ 4Ω
2x85W @ 8Ω
Power consumption40W
Power supply voltage100-240V AC
Dimensions192 x 42 x 185mm
Weight1.26kg
ColorNoir
Package1x SMSL PA40
1x Remote control
1x Power cord
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipInfineon MA5332M
Power (W)160.0
Remote ControlYes
Download
SMSL PA40 Integrated Amplifier Stereo Class D Infineon MA5332MS 2x160W 4 Ohm
SMSL's PA40 is an integrated amplifier based on Infineon's MA5332MS Class D amplifier chip, delivering 2x160W of power at 4Ω...
