SMSL RAW-HA1 Amplifier / Headphone Amplifier
With the SMSL RAW-HA1, the brand unveils a versatile, high-performance integrated amplifier/headphone amplifier. At the cutting edge of technology, this device is based on audiophile components. In fact, it uses an Infineon chip to develop an output power of up to 2x 165W @ 4 ohm and a JRC NJW1194 volume control.
Reference : 19918
249,00 €tax incl.
207,50 € tax excl.
Shipping date: 22-07-2025.
SMSL RAW-HA1 Amplifier Infineon Headphone Amplifier CS43131 Bluetooth 5.1 2x165W 4 Ohm 32bit 768kHz DSD256 MQA/MQA-CD
SMSL RAW-HA1 picture
With the SMSL RAW-HA1, the brand unveils a versatile, high-performance integrated amplifier/headphone amplifier. At the cutting edge of technology, this device is based on audiophile components. In fact, it uses an Infineon chip to develop an output power of up to 2x165W under 4 ohm and a JRC NJW1194 volume control. On the headphone amplification side, we find a Cirrus Logic CCS43131 hybrid DAC/headphone amplifier chip and two outputs: single-ended jack 6.35mm and balanced jack 4.4mm. The RAW-HA1 also boasts numerous digital inputs, including a USB input with XMOS XU-316 interface, enabling it to support sampling rates up to PCM 32bit 768kHz, DSD256 and MQA/MQA-CD. HDMI ARC, optical Toslink, coaxial SPDIF and analog RCA inputs are also available. Output is via speaker terminals, with a subwoofer output for coupling to an active subwoofer.
SMSL RAW-HA1: Infineon class D amplification with subwoofer output
The SMSL RAW-HA1's speaker terminal outputs are powered by an Infineon class D amplifier chip, enabling it to develop output power of up to 2x165W under 4 ohm and up to 2x85W under 8ohm. This amplifier therefore boasts a considerable power reserve, enabling it to power up to column speakers and thus provide the soundtrack to beautiful spaces. A subwoofer output is also available, enabling it to be coupled to an active subwoofer for an immersive listening experience.
Photo of the Infineon chip in the SMSL RAW-HA1
Photo of CS43131 DAC chip/headphone amplifier
SMSL RAW-HA1: DAC Headphone amplifier CS43131
Inside the SMSL RAW-HA1, a Cirrus Logic chip also acts as DAC and headphone amplifier for the 6.35mm jack and 4.4mm jack outputs available on its front panel.
SMSL RAW-HA1: XMOS XU-316 USB interface
The SMSL RAW-HA1's USB-C input is equipped with an XMOS XU-316 interface, enabling it to support high-resolution sampling rates up to PCM 32bit 768kHz and DSD256. An MQA decoder also enables it to support MQA or MQA-CD formats on all its digital inputs.
Photo of XMOS XU-316 USB interface chip
Photo of NJW1194 volume control chip
SMSL RAW-HA1: volume control NJW1194
An electronic volume control chip with low-noise, low-distortion characteristics, thanks to its resistance ladder circuit, adjusts the volume of the SMSL RAW-HA1's speaker terminal and headphone outputs.
SMSL RAW-HA1: Bluetooth 5.1
A Qualcomm QCC5125 Bluetooth receiver chip provides high-quality wireless transmission with AAC, SBC, aptX, aptX HD, aptX Adaptive and LDAC codecs. This simplifies use with a smartphone and streaming application.
Bluetooth functionality of the SMSL RAW-HA1
SMSL RAW-HA1: ergonomic and aesthetically pleasing
This amplifier features a color LCD screen with tempered glass protection, giving access to an ergonomic, intuitive control interface for a pleasant user experience.
SMSL RAW-HA1 interface and screen presentation
SMSL RAW-HA1 overview
14.4mm jack balanced headphone output
2Jack 6.35mm headphone output
3LCD screen with tempered glass window
4Multifunction knob
5Stereo RCA analog input
6SPDIF coaxial input
7Subwoofer output
8Bluetooth antenna
9HDMI ARC input
10Speaker terminal output
11Power IEC / Power switch
SMSL RAW-HA1 test by Audio Science review (Amir)
"The RAW-HA1 packs a lot of functionality into a compact form factor. The user interface is attractive and the performance is on point. That's why I recommend the RAW-HA1."
Product typeAmplifier
Headphone amplifier
Amplification chipInfineon
DAC chip/headphone amplificationCS43131
USB interfaceXMOS XU-316
Bluetooth chipQualcomm QCC5125
Inputs1x Analog RCA
1x USB-C
1x Coaxial
1x Optical Toslink
1x HDMI ARC
Bluetooth
OutputsSpeaker terminals
1x Subwoofer output
1x 6.35mm jack single-ended headphone output
1x 4.4mm jack balanced headphone output
Output power2x165W @ 4 Ohm
2x85W @ 8 Ohm
Input sensitivity245mV/22kOhm
THD+N0.003%
SNR108dB
Crosstalk87dB
Supported sample ratesUSB: PCM 32bit 768kHZ, DSD256, MQA
Optical Toslink / Coaxial: 24bit 192kHz, DSD DoP64, MQA/MQA-CD
Supported Bluetooth codecsSBC, AAC, AptX, AptX, aptX HD, aptX Adaptative, LDAC
USB transmissionUSB 2.0 Asynchronous
USB compatibilityWindows 7/8/8.1/10/11 (with driver)
Mac OSX
Linux
Power supplyAC 100-240V
Power consumption40W (Normal volume)
Dimensions219 x 45 x 190mm
Weight1.55kg
Package1x SMSL RAW-HA1
1x Remote control
1x Bluetooth antenna
1x Power supply cable
SMSL RAW-HA1 measurements
InputHDMI ARC
OutputJack 6.35mm
OutputJack 4.4mm
OutputSpeaker terminal
OutputSubwoofer
Channel2 (Stereo)
Amplifier chipN/A
Power (W)165.0
Remote ControlYes
With the SMSL RAW-HA1, the brand unveils a versatile, high-performance integrated amplifier/headphone amplifier. At the cutting edge of technology,...
