SMSL SA-36A Plus Digital Amplifier TPA3118 Bluetooth 4.1 2x 50W / 4 Ohm Black
The SMSL SA-36A Plus black is a remarkably efficient compact audio amplifier that takes advantage of a wide range of connectors allowing it to be associated with it from many different sources.
4.8 / 5
Reference : 11445
59,90 €tax incl.
49,92 € tax excl.
The SMSL SA-36A Plus is a remarkably efficient, compact audio amplifier that takes advantage of a wide range of connectors allowing it to be associated with many different sources.
Indeed, this amplifier has a USB input, an SD card input, an AUX jack 3.5mm, and an Wireless Bluetooth 4.1 antenna.
Its amplifier module TPA3118 Class D allows it to deliver an output power of 2x30W under 8 Ohm. It benefits from high quality electronic components.
On its front panel, 5 buttons of commands. A Play / Pause button, the 2 volume buttons +/-, the Power button, as well as the button for the various buttons settings EQ Mode .
Qobuzissime for the SMSL SA-36A Plus
(Review by Qobuz)
" This S.M.S.S.L SA-36A Plus switching amplifier may have amazed us even more than the AD18 and A8 models of the brand by offering, at a lower power level but not negligible, and at a really low price, sound performances that remind us furiously of those of its big brothers. "
Test Qobuz
General specifications:
  • Amplifier chip: TPA3118 / Class D (PDF available in attached files)
  • Output power: 2x 30W under 8 Ohm / 2x 50W under 4 Ohm
  • Bluetooth version: 4.1
  • Maximum sampling rate: 16 Bit / 44kHz
  • EQ Fashion: Flat / Rock / Pop / Classical / Jazz
  • Power supply in 24V DC
  • Power Consumption: 22W
  • Power consumption at rest: 0.5W
  • Accepts file formatsrs: WMA / MP3
Connectivity / Dimensions / Weight:
  • Input USB-A (Up to 64GB) / SD Card In (Up to 32GB)
  • Output: HP Stereo Terminal Block
  • Input AUX Jack 3.5mm
  • Dimensions: 250x188x68mm
  • Weight: 322g
  • Black color
  • Black Face
  • Comes with: 24V AC adapter / Bluetooth antenna
InputMicro SD
InputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3118
Power (W)30.0
5 reviews
Très bon pour le prix
Acheter sans grande conviction pour mes eltax monitor 3 je suis très étonnée par le rendu. Je l'ai relié sur mon pc en USB avec foobar et les pilotes asio, et le rendu est vraiment bon pour cette gamme de prix, c'est détaillé et précis. Un très bon rapport qualité prix, de plus reçu en 24h merci c'est la deuxième fois que je commande sur ce site et je suis très satisfait du conseil.
This review has been posted for SMSL SA-36A Plus Digital Amplifier TPA3118 Bluetooth 4.1 2x 50W / 4 Ohm Black
Bluffant!
Surprenant petit ampli Full Digital! Le son produit est de très bonne qualité: bien défini, dynamique et équilibré. La puissance est suffisante pour une pièce de taille moyenne. Il propose plusieurs entrées qui fonctionnent toutes très bien (bluetooth, AUX, USB). Associé à de bonnes enceintes, le résultat est bluffant! Seuls bémols: pas d'écran, et peu de réglages d'égalisation, mais à ce prix... (D'ailleurs, la marque propose d'autres modèles qui pallient ces petits manques)
Répond à mes attentes
Mes attentes : un son de qualité pour une petite pièce équipée de 2 vieilles mais très bonnes enceintes Goodmans.
L'absence de notice (y compris sur le site du fabricant). est palliée par la fiche de Qobuz.
Aucun regret quant à ce choix.
Excellent appareil
J'avais été déçu par un Alientek D8 en remplacement d'un T-amp TA2020. Avec le SMSL SA-36A Plus, pour le coup, je suis comblé : je retrouve la finesse, la dynamique, les timbres qui m'avaient séduit avec le T-amp. Il alimente une paire d'Oran 4305, dont le niveau de grave n'est pas énorme, mais reste propre et percutant avec cet ampli. La puissance est un peu limite pour une paire d'enceintes de cette sensibilité (87 dB), mais rien d'indécent.
Les voix et les cordes sont magnifiques, la scène sonore irréprochable compte tenu des configurations que j'ai déjà expérimentées. Bref je suis ravi. A ceux qui cherchent le mode d'emploi de l'ampli, il figure sur le carton d'emballage ! On peut connecter l'ampli directement à un ordinateur en USB, il est reconnu comme n'importe quel DAC. Traitement de la commande par Audiophonics irréprochable.
excellent
un son époustouflant pour un boîtier si petit, aérien,...
Un moins pas de mode d'emploi rien de rien il faut se débrouiller heureusement que Qobuz avait juste une petite fiche sur les touches.
5 * avec un mode d'emploi même simple, d'autant pls qu'il me semble que la loi française l'impose.
The SMSL SA-36A Plus black is a remarkably efficient compact audio amplifier that takes advantage of a wide range of connectors allowing it to...
