TONEWINNER AD-89D Class AB 2.1 Amplifier
ToneWinner unveils an all-in-one device with its AD89D Class AB integrated amplifier. This 2.1-channel amplifier features a CD player, high-fidelity Bluetooth reception and an HDMI ARC port. Powerful and versatile, the Tonewinner AD-89D is capable of delivering up to 2x 130W at 8 ohm.
By buying this product you get 109 loyalty points
Reference : 18655
1 099,00 €tax incl.
915,83 € tax excl.
Shipping date: 27-05-2025.
TONEWINNER AD-89D Class AB  Amplifier 2.1 Bluetooth HDMI ARC CD 2x130W 8 Ohm
Photo of TONEWINNER AD-89D amplifier
Tonewinner unveils an all-in-one device with its AD89D Class AB integrated amplifier. This 2.1-channel amplifier features a CD player, high-fidelity Bluetooth reception and an HDMI ARC port. Powerful and versatile, the Tonewinner AD-89D is capable of delivering up to 2x 130W at 8 ohm, and fulfills the functions of CD player, multimedia player/DAC and integrated amplifier or power amplifier. Its wide range of connectors makes it easy to integrate into any audio system.
TONEWINNER AD-89D highlights
Tonewinner AD-89D: high-fidelity architecture and design
This Tonewinner amplifier adopts a high-speed, low-distortion Class A amplifier circuit with strong drive capability and beautiful dynamics. It's also worth mentioning that the internal structure separates the power stage from the input and signal processing stages. Left and right channels are also processed independently. This structure greatly reduces the risk of interference and noise generation. On the power supply side, the AD89-D uses a 350VA toroidal transformer and 40000uF capacitors. No less than 8 high-precision, high-power matched tubes are used for the output stage.
Photo de l'intérieur du TONEWINNER AD-89D
Tonewinner AD-89D: local player and CD player
The AD-89D supports WAV, Flac and APE files via U disk and TF card up to 128 GB for lossless music file quality. In addition, the high-quality CD drive on the front panel absorbs shocks and ensures reliable, stable playback quality.
Photo of TONEWINNER AD-89D CD player
Picture of a Bluetooth smartphone with the TONEWINNER AD-89D
Tonewinner AD-89D: Bluetooth functionality
The AD-89D amplifier's Bluetooth functionality lets you enjoy stable, low-distortion, low-latency wireless transmission, so you can connect your smartphone or tablet.
Tonewinner AD-89D: high-fidelity digital inputs
Among its digital inputs, the AD-89D features a USB-B port with digital interface supporting up to PCM 24bit 48kHz. So you can enjoy high-resolution streams via a source such as your computer.
Digital inputs for the TONEWINNER AD-89D
TONEWINNER AD-89D subwoofer output and HDMI ARC input
Tonewinner AD-89D: Subwoofer output and HDMI ARC port
The HDMI ARC port and subwoofer output allow the AD-89D to be integrated into a home theater setup, for more immersive sound thanks to an active subwoofer.
Tonewinner AD-89D: from integrated amplifier to power amplifier
U-shaped rings on the AD-89D's connectors enable it to be used as an integrated amplifier. Removing these rings simply allows it to be used as a pure power amplifier within a complete sound system. This amplifier's immense versatility means it can meet most of your needs.
Photo of TONEWINNER AD-89D configurations
Tonewinner AD-89D: control application with treble and bass adjustment
A dedicated control app makes it easy to navigate between your different sources. The mobile app interface also features a TV settings menu. It supports up to 8 levels of file folder management, making it particularly practical for playback of files on U discs and TF cards.
Photo of the TONEWINNER AD-89D control application
Tonewinner AD-89D overview
Connection diagram for TONEWINNER AD-89D
13x Coaxial input
2Toslink optical input
3Bluetooth reception antenna
4TF card slot
5USB-B input
6HDMI ARC input
7Speaker terminals
8Subwoofer output
9PRE OUT/ AMP IN
103x Analog RCA stereo input
11IEC power supply
Product typeIntegraterd amplifier
Amplification typeClass AB
Channel numbers2.1
Inputs1x CD player
1x USB-B
1x Optical Toslink
3x SPDIF coaxial
1x HDMI ARC
3x RCA stereo
Bluetooth
TF card slot
U disk (up to 128GB)
OutputsSpeaker terminals
Subwoofer output
Output power2x 130W (8Ω, 1kHz)
Input impedance10kohm
Frequency response10Hz-50kHz (+1/-3dB)
THD≤ 0.05%(A weighted, analog direct)
SNR≥ 95dB(A weighted, analog direct)
Global gain≥ 41dB (A weighted, analog direct)
Power supply110V-115V (60Hz) / 220V-230V (50Hz)
Max. power consumption450W / 8Ω
Dimensions430×397×151mm
Net weight12.7Kg
Package1x Tonnewinner AD-89D amplifier
InputHDMI ARC
InputXLR
InputSD Card
OutputSpeaker terminal
OutputSubwoofer
Channel2.1
ClassClass A / AB
Amplifier chipN/A
Power (W)130.0
ToneWinner unveils an all-in-one device with its AD89D Class AB integrated amplifier. This 2.1-channel amplifier features a CD player,...
