Amplifier Class AB Pure Direct 2x115W 4 Ohm
The Yamaha A-S201 is an affordable yet effective entry into the world of hi-fi. Based on the Natural Sound concept to faithfully reproduce your music, it benefits from a careful design.
The A-S201 benefits from a nice power reserve, with 2x115W power at 4Ω in a Class AB architecture. Its circuitry has been designed to ensure the shortest possible signal path by optimizing the layout of the components. Thus, the power supply stage is placed close to the amplifier circuit, in order to reduce power loss while improving the energy input, allowing to generate a high level of volume. The ground and power supply of the A-S201 are connected at one point, to eliminate interference and ensure a very good signal-to-noise ratio.
The A-S201's Pure Direct mode allows the audio signal to bypass all tone and balance control circuits. This allows you to enjoy better sound quality while preserving the power of the amplifier. A method that allows for accurate and rich reproduction.
The Yamaha A-S201 inherits the simple, modern design of many of the brand's products. With its elegant, high-quality finish, it's a perfect match for any other HiFi equipment. All the controls have been designed to be easily accessible for intuitive use.
The A-S201 has a simple but complete connectivity. There are five analog inputs on stereo RCA allowing to connect different sources, but also a MM phono input to connect a vinyl turntable. On the output side, the amplifier provides two pairs of speaker terminals, allowing four speakers to be connected. Two buttons on the front panel allow you to use pair A, pair B or both pairs at the same time.
A power management feature allows the amplifier to automatically cut off power and activate the standby mode when not in use for a long time. This function can be set to a delay of 2, 4, 8 or 12 hours, or it can be disabled. In addition, the standby power consumption of the device is very low, with only 0.5W.
| Specifications | |
| Product type | Amplifier |
| Amplification type | Class AB |
| Inputs | 5x Stereo RCA 1x Phono MM input on stereo RCA |
| Outputs | 2x Stereo speaker outputs |
| Output power | 2x115W @ 4Ω, 1kHz, 0.7% THD |
| Dynamic power / channel | 125W @ 8Ω 150W @ 6Ω 165W @ 4Ω 180W @ 2Ω |
| Frequency response | 20Hz-20kHz (0 ±0.5dB 10Hz-100kHz (0 ±3dB) |
| THD | Phono MM to Rec Out : 0.025% @ 8Ω, 20Hz-20kHz CD to SP Out : 0.2% @ 8Ω, 20Hz-20kHz |
| SNR (CD) | 100dB (S: 500mV) |
| Input sensitivity (CD) | 500mV / 47kΩ |
| General | |
| Standby consumption | 0.5W |
| Dimensions | 435 x 141 x 333mm |
| Weight | 6.7kg |
| Color | Black |
| Input | RCA |
| Input | Phono |
| Output | Speaker terminal |
| Color | Black |
| Channel | 4.1 |
| Channel | 2 (Stereo) |
| Channel | 2.1 |
| Channel | 4 |
| Class | Class A / AB |
| Amplifier chip | Transistors |
| Power (W) | 115.0 |
| Remote Control | Yes |
