Interface / DAC Board ES9038Q2M I2S vers SPDIF / RCA
This interface module takes an I2S signal as input and outputs it as SPDIF on a Toslink optical or coaxial connector, or as analog on a stereo RCA. The card is also equipped with a DAC with its ESS ES9038Q2M chip, allowing it to convert the signal from digital to analog for this last output, while promoting a precise and clear sound reproduction.
Reference : 17046
75,00 €tax incl.
62,50 € tax excl.
Shipping date: 08-08-2025.
interface / DAC board
Module interface / DAC ES9038Q2M I2S vers SPDIF / RCA
This interface module takes an I2S signal as input and outputs it as SPDIF on a Toslink optical or coaxial connector, or as analog on a stereo RCA. The card is also equipped with a DAC with its ESS ES9038Q2M chip, allowing it to convert the signal from digital to analog for this last output, while promoting a precise and clear sound reproduction. The I2S input of the module supports high resolution streams up to PCM 32bit 384kHz and DSD512. The SPDIF outputs support PCM sampling rates up to 24bit 192kHz as well as DSD DoP up to DSD128 for coaxial and DSD64 for optical.
Jumper settings
The module features different jumpers that can be used to make certain settings regarding output formats, filters and volume control. The tables below detail the different possibilities.
COAXIAL / OPTICAL OUTPUT FORMAT SETTING
DoP outputJ1 not short
PCM outputJ1 short
LEFT AND RIGHT CHANNEL INVERSION FOR DSD INPUT ON COAXIAL / OPTICAL OUTPUTS
DSD_L and DSD_R not invertedOP1 not short
DSD_L and DSD_R invertedOP1 short
FILTERs SETTINGs
Apodizing fast roll-off filterJ3, J4, J5, J6 shorts
Brick wall filterJ3 not short, J4 short
Corrected minimum phase fast roll-off filterJ3 not short, J5 short
Minimum phase slow roll-off filterJ3 not short, J6 short
Minimum phase fast roll-off filterJ3 short, J4 short
Linear phase slow roll-off filterJ3 short, J5 short
Linear phase fast roll-off filterJ3 short, J6 short
Volume control
SilentENB-GND short
Max volume, Can be connected to an external potentiometerENA-ENB short
Product typeInterface and DAC board
InputI2S
Outputs1* Optical Toslink
1* Coaxial
1* Stereo RCA
DAC chipESS ES9038Q2M
OPA1* NE5532P (DIP8)
Voltage regulator1* L7805C
Tension d'alimentation+/-12VDC
Dimensions (with connectors)86*81.2mm
Mouting holes spacing79*48mm
InputI2S
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipES9038Q2M
Max sampling rate384kHz
Max sampling rateDSD512
Interface chipNC
This interface module takes an I2S signal as input and outputs it as SPDIF on a Toslink optical or coaxial connector, or as analog on a stereo RCA....
