VIABLUE T6S Jack 6.35mm Stereo Connector 24k Gold Plated Ø9.5mm (Unit)
15%
4.0 / 5
Reduced price!
Reference : 4646
Limited special offer
21,90 €tax incl.
-15%
18,62 €tax incl.
15,51 € tax excl.
Shipping date: 26-12-2025.
VIABLUE T6s JACK 6,3mm Stereo Bronze Gold plated 24k (Unit)
Stereo 6.3mm jack connector of the T6s VIABLUE series that can be used in the design of a very high quality modulation cable. All T6s series connectors are supplied with 2 diameter reducers. These reducers allow to adapt the connectors to the diameter of the cable to be used.
The small reducer has an outer diameter of 7.5 mm and an inner diameter of 4.5 mm, allowing the use of cables with a diameter between 3 and 4.5 mm. The large one has an external diameter of 9.5 mm and an internal diameter of 7.5 mm. It is designed for cables with a diameter of 5 to 7.5mm. Without these reducers, the T6s connector allows the use of large cables with a diameter between 7.5 and 9.5mm.
Specifications:
  • Jack 6,35mm stereo connector
  • One piece machined aluminum very rigid body
  • 24k Gold plated copper alloy contacts
  • Mounting type: To solder
  • Body to screw with two M4 screws
  • Suitable cable diameters: 3 to 4.5mm (with small reducer) / 5 to 7.5mm (with large reducer) / 7.5 to 9.5mm (without reducer)
  • Total length: 61.2mm
  • Outer diameter: 13,5mm
https://www.audiophonics.fr/images2/4646_VIABLUE-T6S-JACK6.3-STEREO_1.jpg
https://www.audiophonics.fr/images2/4646_VIABLUE-T6S-JACK6.3-STEREO_2.jpg
Max cable diameter (mm)9.5
Mounting typeTo weld
ConnecticMale
Contacts number3
Très bonne qualité
Produit d'excellente qualité même si avec la largeur de câble la plus petite donnée comme "compatible" il est difficile de le bloquer.
De même, avec une fiche jack femelle un peu dure, l'arrière de la prise ne tient pas suffisamment sur le métal et celle-ci s'enlève, tirant au passage sur les soudures. Un peu dommage pour un produit de ce prix, surtout que ce défaut serait facile à corriger.
This review has been posted for VIABLUE T6S Jack 6.35mm Stereo Connector 24k Gold Plated Ø9.5mm (Unit)
