ELECAUDIO DCT-2.1G Male Jack DC 5.5/2.1mm Connector Tellurium Copper Gold Plated 3µ
ELECAUDIO DCT-2.1G Jack DC 5.5 / 2.1mm Connector Tellurium Copper Gold Plated 3µ
This DC 5.5/2.1mm Elecaudio DCT-2.1G connector will allow you to design high quality power cables, ensuring a clean transmission of the electrical signal to your HiFi device. This cable uses high purity Tellurium copper contacts, with Direct Gold plating, i.e. gold plating without Nickel underlay.
Reference : 15441
11,90 €tax incl.
9,92 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Elecaudio DCT-2.1G
Elecaudio DCT-2.1G Jack DC 5.5 / 2.1mm Connector Tellurium Copper Gold Plated 3µ
This DC 5.5/2.1mm Elecaudio DCT-2.1G connector will allow you to design high quality power cables, ensuring a clean transmission of the electrical signal to your HiFi device. This cable uses high purity Tellurium copper contacts, with Direct Gold plating, i.e. gold plating without Nickel underlay. The connector is covered by a robust black aluminum shell.
Product typeJack DC connector
ConnectorJack DC 5.5/2.1mm
Contacts materialTellurium Copper
PlatingGold 3µ (without nickel undercoat)
Max cable diameterØ6.5mm
Mounting typeTo solder
Rated voltage12V
Rated current0.5A
Body materialAluminum
Total dimensions37.5 x Ø9.2mm
Max cable diameter (mm)6.5
Mounting typeTo weld
ConnecticMale
ConnectorJack DC
Contacts Material (Connector)Tellurium Copper
This DC 5.5/2.1mm Elecaudio DCT-2.1G connector will allow you to design high quality power cables, ensuring a clean transmission of the electrical...
