Male Jack DC 5.5/2.5mm Connector Gold Plated
This 5.5/2.5mm DC Jack power plug with gold-plated copper contact will allow you to create your own power cables with DC Jack connector. Gold plating ensures both good signal conductivity and above all excellent oxidation resistance.
3.3 / 5
Reference : 12119
2,20 €tax incl.
1,83 € tax excl.
Shipping date: 16-12-2025.
Jack DC Connector
Jack DC 5.5 / 2.5mm Gold Plated (Unit)
Connecteur d'alimentation Jack DC 5.5/2.5mm plaqué or
ConnectorJack DC 5.5/2.5mm
Contact materialCopper
PlatingGold
Max cable diameter4mm
Total connector dimensions33.5 x 8.2mm
Acceptable cable diameterØ 4mm
QuantitySold by unit (1)
Max cable diameter (mm)4.0
Mounting typeTo weld
ConnecticMale
ConnectorJack DC
4 reviews
moyen
Trop fragile ! La connexion de masse est vraiment fine et fragile...déçu !
This review has been posted for Male Jack DC 5.5/2.5mm Connector Gold Plated
Too short
I confirm that I have a cable with these exact plugs and these plugs do not make electrical contact, these plugs are a 5.5/2.5 non-standard variant, they are about 2mm shorter than the standard.
Mitigé
Belle qualité de fabrication mais gros problèmes de faux contacts avec le port femelle... la fiche male nage trop là où une fiche standard marchait parfaitement.
Sebastian L
This DC jack is good value for the money. It delivers good contact but the solder pin to the outer ring is a bit thin and soft.
Also the shipping cost of €25.50 within EU is quite high compared to the low weight and price of the item itself.
This 5.5/2.5mm DC Jack power plug with gold-plated copper contact will allow you to create your own power cables with DC Jack connector. Gold...
