JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 4.7 μF
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every detail of the signal, while maintaining unparalleled naturalness and realism.
4.6 / 5
Reference : 6596
27,40 €tax incl.
22,83 € tax excl.
Shipping date: 19-05-2026.
Jantzen Audio Superior Z-Cap
Capacitor 800V 4.7µF
Jantzen Audio Superior Z-Cap Condensateur
In particular, they are recommended for use as a capacitor for high-end tweeters or as a coupling capacitor in an amplifier. All Jantzen Audio Z-Cap capacitors have a nitrogen filling that allows the amount of foil per capacitor to be increased while eliminating the risk of evaporation that can be found in capacitors using oil or other dielectric fluids.
Superior Z-Cap capacitors are not polarized. The signal can therefore pass in both directions, without impacting the reproduction or sound performance.
Product typeCapacitor (Super MKP, non-polarized)
Capacity4.7µF
Voltage800VDC
Tolerance±2%
DielectricPolypropylene foil
ConstructionDual foil
Axial
ElectrodeAluminum metallized, vacuum deposited
Wires materialTinned OFC Copper
Dielectric absorption factor< 0.5% @ 20°C
Dielectric thicknessPB=6µm
Self-inductance0nH
Insulation resistance> 100000MΩ @ 20°C
Temperature range-55°C to +85°C
Metal layer thicknessPB=0.4µm
Metal layer conductivityPB=2.5Ω/cm²
DimensionsØ30 x 56mm
Poids60g
Tolerance (%)2
Capacitor capacitance (µF)4.7
Rated voltage (V)800
Capacitor typeFilm capacitor
Capacitor formatAxial
7 reviews
Pour upgrader Elipson prestige 2i
En remplacement des condo Spirit 475J 250V de mes enceintes biblio. Sur le coup je me suis dit m..... 50€ pour rien. Et puis progressivement le rodage s'est fait. Et là, miracle. Tout s'est ouvert. Je ne reconnais plus mes enceintes. Ces condensateurs Jantzen sont une petite merveille. Attention par contre il sera impossible de mettre la taille au-dessus.
This review has been posted for JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 4.7 μF
fantastic
sound quality, scene creation, softness,detail, i loved the all. i liked it more than dayton mpts
JANTZEN AUDIO SUPERIOR Z-CAP Condensateur 800V 4.7µF
Excellent condensateur(associé au 800v 8.2µF) pour la réfection d'un filtre passif 2 voies sur enceintes BW DM5 après changement de tweeter ( Dayton DC 28 FT-8), et recâblage interne (Neotech multibrin). Très bonne bande passante, aigus fins et détaillés , graves tendus et parfaitement maitrisés ,belle musicalité.
Too bright
Much better the Jantzen Alumen for tweeters
Condensateur pour tweeter
Avis très positif après quelques jours d'utilisation utilisés sur tweeter à dôme l'aigu et naturel et jamais fatiguant les timbres sont vrais et naturels je ne suis pas déçu. J'aimerai bien essayer les Alumen !
Ils sont installés sur Dali Rubicon 2 l'ampli est un Hegel H100.
Hervé
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system...
