Keystone OPT Optical Socket Toslink
This female Keystone socket is intended for use with plastic wall plates. ( Example:Keystone Plastic Wall Plate 1 Location)
This product is used in conjunction with the dedicated plates allows you to organize the inputs outputs of your wall wirings.
Specifications:
| Max panel thickness (mm) | N/A |
| Connector | Optical Toslink |
| Contacts Material (Connector) | N/A |
| Contacts Plating (Connector) | None |
