Keystone RCA-RD-FL RCA Headphone (Red)
This female Keystone socket is intended for use with plastic wall plates. ( Example:Keystone Plastic Wall Plate 1 Location)
This product is used in conjunction with the dedicated plates allows you to organize the inputs outputs of your wall wirings.
Specifications: B>
P>
Mounting type | To connect |
Max panel thickness (mm) | N/A |
Accepts Banana Plugs | N/A |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
