Triple Regulated Linear Power Supply Module IRF9Z34NS +/-15V +5V
3.0 / 5
Reference : 14229
26,91 €tax incl.
22,42 € tax excl.
Shipping date: 23-09-2026.
Triple linear regulated power supply
This module uses three independant linear regulated power supplies, each exploiting its own recitifer MOSFET IRF9Z34NS driven by a Ti NE5534 OPA.
Each of these power stages works with a variable potentiometer W202 and can thus be adjusted to obtain the desired voltage. The power circuits are independent and can provide voltage of +5V and +/-15V.
Dimensions & Connectors
The PCB is organized so as to make it easy to merge the outputs of power supplies circuits 1 & 2 if needed. This type of arrangement will be particularly useful for obtaining a negative & positive (+/-) DC voltage.
This property makes it an ideal choice for powering advanced DAC modules where digital and analog stages can be powered from separate sources, such as 9038 DAC & output stage modules from IAN CANADA.
TypePower supply
Power supply typelinear regulated
Entries Outputsx3
bridge rectifierIRF9Z34NS
Output voltage+5V and +/-15V (x2)
Dimensions70.6 x 86.3 x 30 mm
distances69.4 x 78.9
InputSolder pad
OutputSolder pad
Output voltage (V)15.0
Output voltage (V)5.0
Output current (A)NC
Input voltage (V)N/A
Power SupplyRegulated Linear Power Supply
moyen
la derniere regulation ne fonctionne pas, c est dommage
This review has been posted for Triple Regulated Linear Power Supply Module IRF9Z34NS +/-15V +5V
