Je cherchais un petit subwoofer et je ne suis pas déçu. Pour le prix et le faible encombrement, c'est très bien pour faire un petit caisson.
This 16.5cm subwoofer speaker has a 36hz cutoff frequency. It allows the design of small subwoofers of quality and affordable. A simple amplifier in class D of 100W RMS RMS or 4 Ohm makes it easy to operate.
The Dayton Classic woofers are designed for 3-way construction as a low medium but can also be used as a subwoofer.
Their versatility allows them to be used both in closed and Bass Reflex
With these impressive performances and these smooth basses, they are popular in many DIY projects.
Characteristics :
Sealed Volume | 5.66 Litres |
Sealed F3 | 80 Hz |
Vented Volume | 14.16 Litres |
Vented F3 | 42 Hz |
Speaker Power (W RMS) | 100.0 |
Speaker Type | Subwoofer |
Impedance (Ω) | 4 |
Loudspeaker diameter (mm) | 165.0 |
Diaphragm type | Kevlar |
Efficiency / Sensitivity (dB) | 87.0 |
Max Linear Excursion (Xmax) (mm) | 6.0 |
Lowest frequency (Hz) | 36 |
Highest frequency (Hz) | 1100 |
Average votes 5.0 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Rachid C.
david h.
ERIC V.
Vincent D.
JEROME P.
