The Tang Band W6-1139SIF subwoofer delivers immersive bass reproduction thanks to its diameter of no less than 16.5mm. It has a power handling capacity of 50Wrms. Its paper diaphragm and rubber suspension provide excellent performance.
Product type | Speaker |
Speaker type | Subwoofer |
Diaphragm material | Paper |
Surround material | Rubber |
Structure material | Steel |
Magnetic system | Ferrite |
Nominal impedance | 4 ohm |
DCR impedance | 3.6 ohm |
Sensitivity | 83dB (1W/1m) |
Frequency response | 35-800Hz |
Free air resonance | 35Hz |
Voice coil diameter | 38.5mm |
Air gap height | 6mm |
Rated power RMS | 50Wrms |
Max. power | 100W |
Foce factor (BL) | 8.47TM |
Magnet weight | 826g |
Moving mass | 39.91g |
Suspension compliance | 598.98uMN |
Effective piston area | 0.0140m² |
Levc | 0.47mH |
Zo | 39 ohm |
X-Max | 11.5mm |
Vas | 11.78L |
Qts | 0.40 |
QMS | 2.65 |
Qes | 0.47 |
External diameter | Ø176.5mm |
Cutout diameter | 141.5 |
Depth | 110mm |
Mounting bolt diameter | 166mm |
Mounting holes | 4 |
Package | 1x TANG BAND W6-1139SIF Subwoofer |
Speaker Power (W RMS) | 50.0 |
Speaker Type | Subwoofer |
Impedance (Ω) | 4 |
Loudspeaker diameter (mm) | 165.0 |
Diaphragm type | Paper |
Efficiency / Sensitivity (dB) | 83.0 |
Max Linear Excursion (Xmax) (mm) | 11.5 |
Lowest frequency (Hz) | 35 |
Highest frequency (Hz) | 800 |
