MINIDSP UMA-8 ENCLOSURE Housing for UMA-8
The MINIDSP UMA-8 ENCLOSURE is an enclosure designed for the miniDSP UMA-8 microphone array, allowing it to be protected and neatly integrated into an installation.
Reference : 22576
42,90 €tax incl.
35,75 € tax excl.
miniDSP UMA-8 ENCLOSURE Enclosure for UMA-8
The miniDSP UMA-8 Enclosure is an enclosure designed for the miniDSP UMA-8 microphone array, allowing it to be protected and neatly integrated into an installation. It combines a structure equipped with a circular plastic light guide with a metal screen, while a lower plastic ring provides enhanced support for the assembly. Its installation is simple and is carried out using a screwdriver. This enclosure is exclusively compatible with the miniDSP UMA-8 and is not suitable for the UMA8-SP. Please note that the product includes only the enclosure: the UMA-8 microphone array must be ordered separately.
Dimensions du MINIDSP UMA-8 ENCLOSURE
miniDSP UMA-8 Enclosure: design with light guide and metal shielding
The UMA-8 enclosure incorporates a circular plastic light guide combined with a metal screen. This design accommodates the UMA-8 microphone array in a dedicated enclosure while retaining the elements necessary for its integration. A plastic ring located on the lower section reinforces the support of the microphone array inside its enclosure.
Technical Specifications
Product typeMicrophone enclosure
CompatibilityminiDSP UMA-8 8-Channel USB MEMS Microphone Module
Package contents1x miniDSP UMA-8 ENCLOSURE
The MINIDSP UMA-8 ENCLOSURE is an enclosure designed for the miniDSP UMA-8 microphone array, allowing it to be protected and neatly integrated into...
