DAYTON AUDIO CALMIC Measurement Microphone
New
The Dayton Audio CALMIC is a wired microphone designed to measure the response of a system during automatic calibration. Its 3.5mm jack connection allows it to be used with the Dayton Audio AXIS-8 DSP controller and the SPA1000DSP subwoofer amplifier, as well as with other receivers, processors, amplifiers and DSPs compatible with a wired calibration microphone.
Reference : 22680
44,90 €tax incl.
37,42 € tax excl.
Dayton Audio CALMIC Measurement Microphone
DAYTON AUDIO CALMIC: Front view
Its 4.5m cable allows the microphone to be placed at the main listening position while connected to the measuring device. To stabilize its placement on a table or other surface, its foam base limits vibrations and protects furniture. The M6 threads also allow it to be mounted on most photo tripods, microphone adapters and compatible stands, for easier and more precise positioning during calibration.
Technical specifications
Product typeMeasurement microphone
Cable length4.5m
Cable termination3.5mm jack
Weight90g
PackageSold individually
The Dayton Audio CALMIC is a wired microphone designed to measure the response of a system during automatic calibration. Its 3.5mm jack connection...
