Full-range speaker 8 ohm 10.35 cm
The ND91-8 is a full-range speaker featuring a low distortion motor mounted on a ferrite magnet . With a wide frequency response (65Hz - 17kHz), well-defined bass impact and low distortion, it is an excellent compromise for any simple modification / repair project.
Driver design adress both power and precision requirement thanks to a sophisticated design involving a structure copper alloy ring and a underhung coil, allowing increased linearity in movement within the magnetic field.
30 watts (RMS) of power with a 5.1 mm excursion (XMax) in small dimensions (103 x 60.8 cm) make this loudspeaker a balanced and versatile system that can be used both in a single enclosure assembly as in more complex project ( such as line-arrays ...)
Caractéristiques | ||
Type | - | Haut parleur large bande |
Nominal Diameter | - | 3.5" |
Power handling | - | RMS : 30W Peak ; 60W |
Impedance | - | 8 Ohms |
Frequency Response | - | 65 Hz - 17 kHz |
Voice Coil Inductance | Le | 1.24mH @ 1kHz |
DC Resistance | Re | 7.8 Ohms |
Resonant Frequency | Fs | 70.7 Hz |
Mechanical Q | Qms | 4.29 |
Electromagnetic Q | Qes | 0.53 |
Total Q | Qts | 0.47 |
Diaphragm Mass Inc. Airload | Mms | 4.8 g |
Sensitivity | SPL | 82.1 dB @ 2.83V/1m |
Mechanical Compliance of Suspension | Cms | 1.05 mm/N |
Surface Area Of Cone | Sd | 30.4 cm² |
Volume of Displacement | Vd | 12.2 cm³ |
Compliance Equivalent Volume | Vas | 1.53 Litre |
Maximum Linear Excursion | Xmax | 5.1 mm |
Voice Coil Diameter | - | 25 mm |
Materials | - | Cone - Aluminium Surrounding - Gomme Basket - Acier Coil Former - Polyimide Magnet - Ferrite |
Overal Diameter | - | 103.5 mm |
Overall Depth | - | 56.4 mm |
Cutout diameter | - | 85 mm |
Mounting holes | - | x4 |
Speaker Power (W RMS) | 30 |
Speaker Type | Full range |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 102.0 |
Diaphragm type | Aluminium |
Efficiency / Sensitivity (dB) | 82.0 |
Max Linear Excursion (Xmax) (mm) | 5.0 |
Lowest frequency (Hz) | 70 |
Highest frequency (Hz) | 17000 |
