With the PC105-4, Dayton Audio unveils a full-range speaker driver with a compact form factor and 40Wrms power handling. This speaker delivers smooth, natural sound reproduction. It is ideal for DIY construction or repair of small audio systems, or as a building block for more complex assemblies requiring several drivers of the same type. Despite its small size, the PC105-4 4" delivers good sound reproduction and is suitable for a wide range of uses. It performs well when used as a midrange driver in a three-speaker system. It can also be used in the design/repair of portable speakers, line arrays, soundbars or any other configuration requiring speaker networking.
Here are some of the highlights of the Dayton Audio PC105-4:
| Specifications | |
| Product type | Full-range speaker driver |
| Power handling | 40Wrms 80W max. |
| Impedance | 4 ohm |
| Frequency response | 80Hz-15kHz |
| Sensibility | 90.3dB 2,.3V/1 m |
| Nominal diameter | 10.16cm (4") |
| Bolt Circle Diameter | 11.3cm (4.45") |
| Voice coil diameter | 2.54cm (1") |
| Depth | 5.99cm (2.36") |
| Mounting holes | 4 |
| thiele-small parameters | |
| Resonant Frequency (Fs) | 81.4Hz |
| DC resistance (Re) | 3.3 ohm |
| Voice Coil Inductance (Le) | 0.32mH |
| Mechanical Q (Qms) | 2.17 |
| Electromagnetic Q (Qes) | 0.67 |
| Total Q (Qts) | 0.51 |
| Compliance Equivalent Volume (Vas) | 0.13ft³ |
| Mechanical Compliance of Suspension (cms) | 0.92mm/N |
| BL Product (BL) | 3.3T·m |
| Diaphragm Mass Inc. Airload (Mms) | 4.2g |
| Maximum Linear Excursion (Xmas) | 2mm |
| Surface Area of Cone (Sd) | 52.8cm² |
| Materials of construction | |
| Cone Material | Poly-composite |
| Surround Material | Caoutchouc |
| Voice Coil Wire Material | CCA |
| Voice Coil Former | Aluminium |
| Basket / Frame Material | Acier |
| Magnet Material | Ferrite |
| Recommended enclosure volume | |
| Sealed Volume | 0.07ft³ |
| Sealed F3 | 136Hz |
| Vented Volume | 0.15ft³ |
| Vented F3 | 80Hz |
| General | |
| Package | 1x DAYTON AUDIO PC105-4 speaker driver |
| Speaker Power (W RMS) | 40.0 |
| Speaker Type | Full range |
| Impedance (Ω) | 4 |
| Loudspeaker diameter (mm) | 107.0 |
| Diaphragm type | Composite alloy |
| Efficiency / Sensitivity (dB) | 90.0 |
| Max Linear Excursion (Xmax) (mm) | 2.0 |
| Lowest frequency (Hz) | 80 |
| Highest frequency (Hz) | 15000 |
