DAYTON AUDIO RS180P-8 Reference Speaker Driver Midbass Paper 60W 8 Ohm 90dB 45Hz - 8000Hz Ø18cm
DAYTON AUDIO's Reference Series is now available with a paper cone! These pieces feature a patented paper cone combining natural paper pulp, synthetic Kevlar ® and glass fibers to create the perfect combination. These speakers use a low-distortion motor system and a rigid aluminum cone.
4.0 / 5
Reference : 8497
75,00 €tax incl.
62,50 € tax excl.
Last items in stock !
Shipping date: 10-06-2025.
Dayton audio RS180P-8 Woofer Reference 8 Ohm 17cm
Range"Reference Series"of DAYTON AUDIO is now available with a paper cone!
These pieces feature a patented paper cone combining natural paper pulp, synthetic Kevlar® and fiberglass to create the perfect combination.
These speakers use a low distortion motor system and a rigid aluminum cone.
The reference series can surpass woofers that cost several times the price!
Low distortion and high excursion capabilities provide exceptional clarity, detail and dynamics.
This woofer features a black and sturdy anodized cone, a 6-hole chassis, a rubber suspension, a solid aluminum phase part, and gold spring terminals.
https://www.audiophonics.fr/images2/8497/8497_daytonaudio_rs180p-8_3.jpg
Features:
  • Nominal diameter: 7 "/ 17cm
  • Power handling (RMS): 60 watts
  • Puissance (max): 90 watts
  • Impedance: 8 ohms
  • Sensitivity: 89 dB @ 1W / 1m
  • Frequency response: 45 - 8000 Hz.
  • Voice Coil Diameter: 1.5 "
  • Resistance DC (Re): 6.4 ohms
  • Voice Coil inductor (Le): 0.84 mH
  • Resonant Frequency (Fs): 48 Hz
  • Mechanical Q (QMS): 1.45
  • Q electromagnetic (SEQ): 0.41
  • Q total (Qts): 0.32
  • Area of ​​the cone (Sd): 29.14 cm2
  • Cone / Diaphragm Material: Kevlar Paper / Cone
  • Contour material: Rubber
  • Materials: Ferrite / Cast aluminum
  • Overall Outside Diameter: 7.125 "
  • Overall Depth: 3.25 "
  • Baffle Cutting Diameter: 5.75 "
  • # Mounting holes 6
https://www.audiophonics.fr/images2/8497/8497_daytonaudio_rs180p-8_1.jpg
https://www.audiophonics.fr/images2/8497/8497_daytonaudio_rs180p-8_2.jpg
Speaker Power (W RMS)60.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)180.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)90.0
Max Linear Excursion (Xmax) (mm)6.0
Lowest frequency (Hz)45
Highest frequency (Hz)8000
Jc
Bon rapport qualité prix, bonne fabrication.
This review has been posted for DAYTON AUDIO RS180P-8 Reference Speaker Driver Midbass Paper 60W 8 Ohm 90dB 45Hz - 8000Hz Ø18cm
DAYTON AUDIO's Reference Series is now available with a paper cone! These pieces feature a patented paper cone combining natural paper pulp,...
