MONACOR SPH-176 Speaker Driver Midbass
5%
This Monacor SPH-200CTC low-midrange driver offers excellent sound reproduction. It features a coated paper cone and rubber suspension for optimum bass reproduction. This model is also highly versatile, and can be used in a wide range of applications.
Reduced price!
Reference : 840
Limited time offer:
63,90 €tax incl.
-5%
60,71 €tax incl.
50,59 € tax excl.
Last items in stock !
Shipping date: 06-05-2026.
Monacor SPH-176 Speaker Driver Midbass 70W 8 Ohm 90dB 39Hz-4500Hz Ø17.1cm
Photo of Monacor SPH-176
Dimensions and performance of the Monacor SPH-176
Speaker driver typeLow-midrange speaker
Nominal diameterØ17.1cm
Power handlingRMS : 70W
Max : 120W
Impedance8Ω
Frequency repsonse39Hz - 4500Hz
Sensitivity90dB/W/m
Voice coil diameterØ25mm
Magnet weight450g
Magnet diameterØ90mm
Weight1.23kg
Thiele-Small parameters
Resonant frequency (Fs)39Hz
DC resistance (Re)6.6Ω
Voice coil inductance (Le)0.75mH
Mechanical quality coefficient (Qms)2.27
Electromagnetic quality coefficient (Qes)0.44
Total quality coefficient (Qts)0.37
Volume of air mass equivalent to mobile crew compliance (Vas)27L
Mechanical suspension compliance (Cms)1.01mm/N
Moving mass (Mms)14g
Force factor (BL)7.7Tm
Maximum linear excursion (Xmax)±5.5mm
Surface area of cone (Sd)140cm²
Materials
ConeCoated paper
Basket-
Voice coil formerAluminum
Mounting informations
Total external diameterØ175mm
Cutout diameterØ144mm
depth75mm
Bolt circle diameterØ144mm
Number of mounting holes4
Speaker Power (W RMS)70.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)176.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)90.0
Max Linear Excursion (Xmax) (mm)5.5
Lowest frequency (Hz)N/A
Highest frequency (Hz)4500
MONACOR SPH-176 Speaker Driver Midbass 70W 8 Ohm 90dB 39Hz-4500Hz Ø17.1cm
This Monacor SPH-200CTC low-midrange driver offers excellent sound reproduction. It features a coated paper cone and rubber suspension for optimum...
