PURIFI PTT8.0X08-NAB-02 Speaker Driver Full Range
The PURIFI PTT8.0X04-NAB-02 is an 8-inch (20.32 cm) loudspeaker with a nominal impedance of 8Ω, designed to deliver accurate midrange reproduction whilst maintaining a usable extension in the bass and treble ranges. With a power handling capacity of 300W and extremely low distortion, even at full power, the PTT8.0X04-NAB-02 is the ideal choice of full-range speaker for any Hi-Fi system.
By buying this product you get 68 loyalty points
Reference : 21569
689,00 €tax incl.
574,17 € tax excl.
Purifi PTT8.0X08-NAB-02 Speaker Driver Full Range 300W 8 Ohm 86.4dB 20Hz-20kHz Ø20.32cm
PURIFI PTT8.0X08-NAB-02 : Front view
The Purifi PTT8.0X04-NAB-02 is an 8-inch (20.32 cm) loudspeaker with a nominal impedance of 8Ω, designed to deliver accurate midrange reproduction whilst maintaining a usable extension in the bass and treble ranges. With a power handling capacity of 300W and extremely low distortion, even at full power, the PTT8.0X04-NAB-02 is the ideal choice of full-range speaker for any Hi-Fi system.
PURIFI PTT8.0X08-NAB-02 : Frequency response PURIFI PTT8.0X08-NAB-02 : Dimensions
Product typeFull-range speaker
Power rating300W
Diameter20.32cm (8")
Frequency response20Hz-20kHz
Electrical and acoustic parameters
Nominal impedance8Ω
Minimum impedance above resonance6.6Ω
Minimum impedance frequency223Hz
Maximum impedance100Ω
DC resistance6Ω
Voice coil inductance0.33mH
Sound pressure level (SPL)86.4dB @ 2.83Vrms/1m, 300Hz-800Hz
85.6dB @ 1W(Zmin)/1m, 300Hz-800H
Thiele & Small parameters
Resonance frequency (fs)24Hz
Mechanical quality coefficient (Qms)5.8
Electrical quality coefficient (Qes)0.37
Total quality coefficient (Qts)0.35
Equivalent volume (Vas)74.5L
Effective piston area (Sd)235.1cm²
Effective piston diameter (D)17.3cm
Mechanical resistance (Rms)1.22kg/s
Moving mass (Mms)47.6g
Suspension compliance (Cms)0.95mm/N
Weight3.5kg
PackageSold by unit
Speaker Power (W RMS)300.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)203.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)86.4
Max Linear Excursion (Xmax) (mm)15.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
PURIFI PTT8.0X08-NAB-02 Speaker Driver Full Range 300W 8 Ohm 86.4dB 20Hz-20kHz Ø20.32cm
The PURIFI PTT8.0X04-NAB-02 is an 8-inch (20.32 cm) loudspeaker with a nominal impedance of 8Ω, designed to deliver accurate midrange...
