TANG BAND W1‑2396S Full-Range Speaker
The Tang Band W1‑2396S is a 2.54cm (1") full-range speaker, designed to ensure coherent restitution across entire audible spectrum in space-constrained environments. It leverages mica-loaded polypropylene (PPM) diaphragm combined with vulcanized thermoplastic elastomer (TPV) suspension and neodymium magnet motor, enabling combination of surface rigidity, controlled damping and compact magnetic assembly. This architecture promotes homogeneous response despite minimal diameter, while maintaining controlled behaviour on transients.
Reference : 22266
23,90 €tax incl.
19,92 € tax excl.
Shipping date: 10-11-2026.
Tang Band W1‑2396S Full-Range Speaker 3W 4 Ohm 81dB 180Hz-20kHz Ø2.54cm
Tang Band W1‑2396S : Front view
Intended for compact integrations, it exploits extremely thin format enabling insertion into spaces where conventional transducers cannot be used. This approach extends to manufacturing consistency from patented design, ensuring performance repeatability from unit to unit, facilitating tuning and reproduction of multi-unit systems while guaranteeing stable restitution over time.
Tang Band W1‑2396S : Dimensions and measurements
Product typeFull-range speaker
Nominal diameterØ2.54cm (1")
PowerRMS : 3W
Max : 6W
Impedance4Ω
Frequency response180Hz-20kHz
Sensitivity81dB
Voice coil diameter19.4mm
Thiele & Small Parameters
Resonance frequency (fS)180Hz
DC resistance (RE)3.6Ω
Electrical quality factor (QES)0.8
Mechanical quality factor (QMS)2.21
Total quality factor (QTS)0.59
Equivalent suspension air volume (VAS)0.12L
Maximum impedance (Zmax)16Ω
Voice coil inductance (LE)0.042mH
Force factor (B·l)2.13T·m
Moving mass (MMD)0.9g
Diaphragm area (SD)0.00096m²
Maximum linear excursion (Xmax)1.1mm
Materials
Diaphragm materialMica-loaded polypropylene (PPM)
Suspension materialSantoprene
Magnet materialNeodymium
DimensionsØ46 x 11.9mm
PackageSold individually
Speaker Power (W RMS)3.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)2.54
Diaphragm typePolypropylene
Efficiency / Sensitivity (dB)81.0
Max Linear Excursion (Xmax) (mm)1.1
Lowest frequency (Hz)180
Highest frequency (Hz)20000
TANG BAND W1‑2396S Full-Range Speaker 3W 4 Ohm 81dB 180Hz-20kHz Ø2.54cm
The Tang Band W1‑2396S is a 2.54cm (1") full-range speaker, designed to ensure coherent restitution across entire audible spectrum in...
