SUPRAVOX 285 EXC MK2 Speaker Driver Full Range 70W 8 Ohm 93/102dB 50Hz-7000Hz Ø28cm
Supravox 285 EXC - 28 cm - 93 à 102 dB - 50 / 7 kHz
By buying this product you get 123 loyalty points
Reference : 44
1 239,00 €tax incl.
1 032,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
A mobile crew and a response identical to the 215-2000 alnico.
Its advantage is the possibility of adjusting these parameters thanks to a powerful electromagnetic motor. Adaptable to many speakers, it requires an external power supply (ideal from 10 to 14V for 5A).
Sensitivity 1 W / 1m to Fs93 to 102dBFood0 to 12 Volts DC.
Bandwidth0 to 7kHzMagnetic field0 to 1.6 T
Impedance8 ohmsHP Diameter290/307 mm
Power consumption RMS70 Wbowl ThicknessAluminum 8mm
Weight7.5 kgDistance fixing holes290 mm
SuspensionPaperDrill hole diameter270 mm
Resonance Frequency50 HzHP Depth180 mm
Linear Excursion+/- 4 mmsd
471 cm²
Fs
mms
cms
R dc
53 Hz
18.5 g
0.49
6.5
Food
6 V
7 V
8 V
9 V
10 V
11 V
12 V
Vas154158154156154155154
qt
0.64
0.49
0.39
0.31
0.27
0.25
0.21
Qe
0.68
0.51
0.41
0.32
0.27
0.25
0.22
Qm
10.48
10
9.31
9.33
8.83
7.9
8.2
bl
7.74
8.8
9.98
11.1
12.1
12.6
13.5
SPL ref
97.1
98.5
99.4
100
101
101
102
Speaker Power (W RMS)70.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)280.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)102.0
Max Linear Excursion (Xmax) (mm)4.0
Lowest frequency (Hz)50
Highest frequency (Hz)7000
