AG GR-1 Portable Headphone Amplifier with Battery 32-300 Ohm
This AG GR-1 nomadic amplifier with its original and assertive design offers outstanding performance thanks to its high-quality design.
3.8 / 5
Reference : 12516
69,90 €tax incl.
58,25 € tax excl.
AG GR-1
Nomade Headphone Amplifier
AG GR-1 Amplificateur Casque
The AG GR-1 headphone amplifier stands out first and foremost for its clean, assertive design. An aesthetically pleasing case with a concentration of technology for music lovers!
Your music on another level
The AG GR-1 will provide high quality decoding and amplification, far more efficient than a smartphone or computer.
Simple & efficient
The AG GR-1 is designed to be very easy to use, for an immediate handling!
Certainly nomadic
With its small size and low weight of 239g, the AG GR-1 is an amplifier designed to follow you wherever you go.
Components at the service of your music
AG incorporates high end components into its GR-1 headphone amplifier for outstanding audio performance. Thus, we find in particular 3 Op Amp TI OPA2604 with a very low distortion of 0.03% and a very low noise as well as a great dynamic range. In addition, there is also a high-quality ALPS switch, EVOX and ELNA capacitors or two TI chips for the power supply circuit.
AG GR-1 amplificateur casque
An original design
Far from the classic shapes of many HiFi devices, the AG GR-1 offers a case with assertive geometrical shapes that won't leave anyone indifferent. An Aluminium shell also provides shielding to limit EMI and RFI interference.
An amplifier to accompany you everywhere
With its small size and reduced weight of 239g, the AG GR-1 is easy to carry on the go, so you can enjoy high quality music wherever you go. In addition, the GR-1 incorporates a large battery with a 10-hour battery life.
AG GR-1 amplificateur casqueAG GR-1 Amplificateur casque
AG GR-1 Review on Head-Fi
head-fi
Test du AG GR-1 par QOBUZ
Presentation video du AG GR-1
Acceptable headphone impedances16Ω - 300Ω
Distortion0.03% @ 1kHz
Weigth239g
Battery2000mAh (approx. 10h)
Power150mW 32Ω
Charging timeLess than 3.5h (DC 5V 2A)
Charging connectorMicro USB
Autonomy8-10h
AccessoriesJack 3.5mm Cable
USB -Micro USB Charging Cable
2x Caoutchouc Bands
Metal AG logo
InputJack 3.5mm
OutputJack 3.5mm
ColorSilver
4 reviews
IMPRESSIONS APRES 3 MOIS D'UTILISATION.
Après 3 mois d'utilisation, la qualité et la puissance de ce petit ampli demeurent surprenants.
Il faut néanmoins savoir deux choses: le manque de progressivité du réglage de volume évoqué par Quobuzz dépend de l'impédance de votre casque. La progressivité est normale avec un casque à partir de 120 ohms et "délicate avec un 32 ohms. Idem pour le "clong" à la mise sous tension. Léger avec un casque à partir de 120 ohms, redoutable avec mon Beoplay H6, pourtant transcendé par cet ampli avec mon baladeur Fiio mais que je branche et débranche à chaque utilisation pour éviter le claquement sec des transducteurs.
This review has been posted for AG GR-1 Portable Headphone Amplifier with Battery 32-300 Ohm
Excellent
Super amplificateur je l'ai associé à un shanling M0 il rend le shanling vraiment meilleur le résultat est excellent l'autonomie est très bonne et en plus le design est superbe.
Trés déçu
Le look du preamp est magnifique, l emballage aussi, mais l efficacité du produit n est pas au rendez vous. La hausse de volume en sortie d un iPad par rapport au volume original est infime. J ai acheté ce preamp pour pouvoir écouter des films en roulant dans un van en tournée... et c est pas gagné... à 70 euros le preamp c est très décevant.
Luc , ingé son.
SURPRENANT
Si le look "Star Treck" n'apporte rien d'autre que faire remarquer cet ampli, sa facilité à driver des casques nécessitant beaucoup de courant, comme mon vieil AKG 501 est surprenante au regard de son prix, surtout en promotion.
Bel emballage, jolie notice en mandarin (mais mode d'emploi évident) câble micro usb et câble de liaison Monster fournis. Ce câble Monster est très bon, mais court et assez rigide. Bien sur un Dap ou un smartphone mais trop court pour une tablette. Le niveau sonore est progressif sur une sortie casque (smartphone ou tablette, mais plus rapide sur la sortie ligne d'un DAP comme le faisait remarquer le test de Quobuzz..
Un excellent achat, sans concurrence dans cette gamme de prix.
