AUNE B1S Portable Headphone Amplifier Discrete Class A
The Aune B1S, a new version of the B1, impressed by its class A design, integrated in a small format case, ideal for mobile use. With a large battery, the B1S will be able to accompany you during your travels.
3.3 / 5
Reference : 12393
199,00 €tax incl.
165,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
Aune B1S
Class A Discrete Headphone Amplifier
Aune B1S
The Aune B1 back!
The Aune B1 comes back in an improved version, the Aune B1S. Like its predecessor, it benefits from a Class A design and has been designed to power the most demanding helmets.
Class A in reduced format
Aune achieves the feat of integrating a Class A amplifier into an extremely small format. A design that will allow the amplifier to deliver rich, warm, generous, just and powerful sound to your music.
Aune B1S Class A
Adjustments to all headphones
The B1S has settings on its sides to adjust the amount of current used for amplification or gain adjustment. Thus, the amplifier is able to drive all types of HiFi headphones.
Aune B1S THD+N
An adapted battery
DAPs have developed rapidly in recent years. The B1S is the solution that will allow you to effectively amplify your DAP signal, ensuring an extremely low distortion of 0.0002%.
Un design sublime
The Aune B1S asserts itself with an inspiring design that is both robust and stylish. Black brushed Aluminium, the amplifier also has two windows that reveal its components, the heart of the amplifier.
Qobuzissime for the Aune B1
(Review by Qobuz)
" We award this Aune B1 autonomous headphone amplifier our Qobuzissime award for its very high quality of reproduction and also for its design and beautiful workmanship. A very warmly recommended device for those who like a pure, detailed, catchy sound, whether you are considering its use on the go or at home. "
Test Qobuz et Qobuzissime
Amplification typeClass A
Class A25mW / 16R
50mW / 32R
Gain adjustmentYes
Battery4000mAH
Autonomy5h to 10h depending on the selected mode
Battery condition test LEDs-
THD+N0.00015% @ 300Ω
SNR124dB @ 300Ω
Frequency response10Hz to 20kHz (+-0.02dB)
Crosstalk< 110dB @ 300Ω
Output max level6.443Vrms 18.4dBu (10Hz à 20kHz)
Power74mW @ 32Ω, 84mW @ 300Ω et 42mW @ 600Ω
Connectors
Input1x Stereo Line input 3.5mm
Sortie1x Stereo headphone output 3.5mm
Charging1x Mini-USB port
Dimensions125 x 65 x 18mm
Weight230g
Case materialAluminium
Accessories1x Jack 3.5mm cable Male/Male 15cm
1x USB-A Male to Micro USB Male cable 50cm
1x User manual
Schéma Aune B1S
InputJack 3.5mm
OutputJack 3.5mm
ClassClass A / AB
3 reviews
Amazing, holds its own against much higher priced units
Tried with Audeze LCD-1 and Sennheiser HD 6xx. I only had Woo Audio WA7 gen3 and Hegel H95 to compare with side by side. Aune has darker background than WA7 and is a touch more dynamic and a bit more resolving. There is greater separation of instruments and the soundstage is deeper (again, a bit). Considering the price, this is an amazing accomplishment. Hegel H95 throws a wider sound stage, but I'm not sure if it's more accurate. Overall, very pleased with the unit. I normally don't buy lower priced units, but this is the only portable class A unit I could find under 1k. This unit holds its own against much higher priced desktop amps.
This review has been posted for AUNE B1S Portable Headphone Amplifier Discrete Class A
très déçu ...
Dans l'absolu le son reste très bon ... mais appeler ça un amplificateur est une usurpation ... quel manque de puissance !!!
très très déçu ... couplé à un HD600 ...
L'investissement ne vaut pas le coup.
Merci à Audiophonics pour l'envoi rapide et le suivi irréprochable ... dommage que ce soit pour ça ...
F-a-n-t-a-s-t-i-q-u-e
Je cherchais depuis des mois un ampli et/ou dac nomade pour alimenter mes Beyer DT-770 et DT-990 Pro. Se sont succédés le Encore mDSD, l'AQ Dragonfly Red, et l'Oppo HA-2 (prix: 400€). Aucun de ces dac/ampli n'a bien sonné et fourni assez de puissance. Puis je suis tombé sur la marque AUNE, qui a la réputation de produire un son chaleureux, ce qui est parfait pour atténuer le haut du spectre agressif des Beyer. Avec l'Aune B1S je peux vous dire que vous entrez dans un nouvel univers. Le mode Classe A est remarquable, il apporte du corps aux voix. Le son est très ouvert, aéré, détaillé. Légèrement chaud, ce qui rend le tout très musical. on tape du pied. Mon DT-990 rivalise maintenant avec un Sennheiser HD660S! Merci audiophonics
The Aune B1S, a new version of the B1, impressed by its class A design, integrated in a small format case, ideal for mobile use. With a large...
