COZOY Astrapi DAC USB OTG Smartphones & Tablets MFI iDevices
COZOY Astrapi High Resolution DAC USB Headphone Amplifier Smartphones & Tablets
50%
Reduced price!
Reference : 9711
Limited special offer
115,83 €
-50%
57,92 €tax excl.
Available
Shipping date: 27-06-2019.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Here is the universal answer to the poor audio quality of our digital companions.
Acting as both a converter and an amplifier it provides an incredible signal quality at this price.
A revolution in the miniaturization of USB DACs & Headphone Amplifiers, the COZOY Astrapi unveils a robust chassis incorporating a particularly effective system of efficiency.
The feat lies here in the fact that it nestles readily in the palm of your hand!
Indeed, its dimensions are equivalent to those of a USB key.
With incredible power and clarity, it is simply amazing.
This small jewelry is directly compatible with your Smartphones and Tablets. It is certified MFI (iDevices via lightning) and compatible Android.
WARNING ! Be sure to check the OTG compatibility of your terminal!
The use of DAC USB OTG requires a compatible application such as Hiby Music: Download Hiby Music
Characteristics :
  • Compatibility: PC, MAC, Android (ice cream sandwich andthe mandatory OTG) and iDevices
  • Support and certification Apple (iPhone5 / 6, iPad / iPad mini, ipod touch / nano 7)
  • Supported sampling rate: up to 24bit 192kHz and DSD (support software).
  • Noise Ratio: 105dB
  • THD: <0.003% at 1kHz / 0 dB
  • Output Power: 40mW at 16 Ohms
  • Output voltage: 1.5Vrms max.
  • Input Voltage: 1.8V - 3.3V
  • Micro USB port
  • Connection included: micro USB to micro USB (Android), Lightning to micro USB (IOS), micro USB to USB A (PC / MAC)
  • Headphones Jack 3.5mm
  • Supported Impedance: 16 - 100 Ohms
  • Quasi-zero consumption / No charge required
  • Chassis Aluminum anodized Silver.
  • Dimensions: 55x16x6mm
  • Weight: 9g
Head-Fi
Test in English (Click here)
Cozoy Astrapi
InputMicro USB
OutputJack 3.5mm
Max sampling rateDSD64
Max sampling rate192kHz
ColorSilver
Channel2 channels (Stereo)
Colissimo - TNT - SoColissimo
Bémol
il me semble que cet accessoire ne reprend pas les appels téléphoniques ni le contrôle. Il n'a aucun réglage ( tels que bass - volume - by pass ).
En effet pas de micro ou de contrôle de lecture intégré. Android permet de piloter sans soucis le volume du convertisseur et IOS permet 12 niveaux de réglages, il est tout particulièrement destiné aux casques à forte impédance.
This review has been posted for COZOY Astrapi DAC USB OTG Smartphones & Tablets MFI iDevices
