E1DA POWERDAC V2.1 Headphone Amplifier FDA TAS5558 320mW 32 Ohm
E1DA's FDA PowerDAC V2.1 headphone amplifier builds on the excellent foundation of its predecessor, the PowerDAC V2, while now allowing operation with both balanced and single-ended headphones. Thus, its balanced output is identical to that of the PDv2, with a 2.5mm TRRS jack allowing an output up to 600mW per channel.
Reference : 15753
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 22-09-2026.
E1DA PowerDAC V2.1
Headphone amplifier FDA TAS5558 320mW 32 Ohm
E1DA PowerDAC V2.1 Amplificateur Casque FDA TAS5558 320mW 32 Ohm
E1DA's FDA PowerDAC V2.1 headphone amplifier builds on the excellent foundation of its predecessor, the PowerDAC V2, while now allowing operation with both balanced and single-ended headphones. Thus, its balanced output is identical to that of the PDv2, with a 2.5mm TRRS jack allowing an output up to 600mW per channel. The single-ended output can be used with the supplied 2.5/3.5mm jack adapter with four times less power than the balanced output. A Boost mode allows it to enjoy a power of 600mW in single-ended, with a slight effect of crossfeed.
This PowerDAC V2.1 version also features a soft-start function to avoid high inrush current. The device can thus work with any Android smartphone.
A free mobile app is also available for Android and iOS, offering additional features. It features volume and tone control, seven parametric EQs, LPF, HPF and APF filters for phase alignment, a compressor and limiter, a profile manager and preset EQs.
E1DA POWERDAC V2.1 driver
The E1DA POWERDAC V2.1 headphone amplifier driver can be downloaded from the manufacturer's product page.
HPToy App
The connection between the HPToy application and the PowerDAC V2.1 is automatic. Simply activate the Bluetooth function of your smartphone and open the application to perform the pairing.
L'application HPToy pour Android est disponible via un fichier .apk dans l'onglet "Téléchargements" de cette page.
Amplifier typeFDA (Full Digital Amplifier)
Amplification chipTAS5558
Output power> 320mW @ 32Ω load, 1kHz, THD=1%
> 580mW @ 16Ω, 1kHz, THD=1%
Input1x USB
Output1x Jack 2.5mm balanced (pinout A&K)
Suported sampling ratesInput : 24bit 192kHz
Output : PWM 384kHz + passive LC demodulation
Output impedance1.5Ω @ 1000Hz FFT flat-top -6dBFS
32Ω load/open load, -4dB drop
Frequency response20Hz - 20kHz (±0.2dB)
10Hz - 30kHz (±0.5dB)
2.5Hz - 46kHz (±3dB)
SNR-108dB(A)
THD+N< 0.05% @ 1kHz, 0dBFS
Crosstalk< -92dB @ 1kHz
Supply voltage5V 250mA via USB
Dimensions75 x 45.5 x 19mm
Weight68g
PC USB2 Port, 32Ω load, THD+N = 1% @ 320mW
PC USB2 Port, 16Ω load, THD+N = 1% @ 580mW
PC USB2 Port, HFM HE400i load, THD+N = 1% @ 290mW
PC USB2 Port, 16Ω, crosstalk -92.64dB
Frequency response, 32Ω load
FFT 0dBFS, HFM HE400i load, USB power splitter to 5.2V 2A charger, THD+N = 0.032%
FFT -3dBFS, HFM HE400i load, USB power splitter to 5.2V 2A charger, THD+N = 0.023%
FFT -6dBFS, HFM HE400i load, USB power splitter to 5.2V 2A charger, THD+N = 0.014%
FFT -10dBFS, PC volume 50%, HFM HE400i load, USB power splitter to 5.2V 2A charger, THD+N = 0.0074%
FFT -20dBFS, HFM HE400i load, USB power splitter to 5.2V 2A charger, THD+N = 0.0065%
FFT -10dBFS, 6.6kHz, HFM HE400i load, USB power splitter to 5.2V 2A charger, THD+N = 0.0095%
FFT -10dBFS, 100Hz, HFM HE400i load, USB power splitter to 5.2V 2A charger, THD+N = 0.025%
FFT +0.6dBFS, 3.46VRMS, 374mW, 32Ω load, USB power splitter to 5.2V 2A charger, THD+N = 1%
FFT +0.6dBFS, 3.32VRMS, 688mW, 16Ω, USB power splitter to 5.2V 2A charger, THD+N = 1%
FFT +0.6dBFS, 3.5VRMS, 350mW, HFM HE400i load, USB power splitter to 5.2V 2A charger, THD+N = 1%
OutputJack 2.5mm
ColorSilver
ClassFDA
Le seul FDA pour casque du marché
Produit exceptionnel à de nombreux égards ...
Il a l'audace d’être à la fois moins cher et meilleur que tous ces concurrents dans le domaine (sans parler des possibilités de réglages inédites).
Si vous aimez l'écoute aux casque et intras foncez !!!
This review has been posted for E1DA POWERDAC V2.1 Headphone Amplifier FDA TAS5558 320mW 32 Ohm
E1DA's FDA PowerDAC V2.1 headphone amplifier builds on the excellent foundation of its predecessor, the PowerDAC V2, while now allowing...
