Quickly delivered to Lithuania. The store has fulfilled the order in compliance with all term obligations.
Thank you
This product has been replaced by the new version, the xDUOO XD05 BASIC V2 DAC ES9038Q2M.
Portable Headphone Amplifier DAC AK4490 XMOS 32bit 384kHz DSD256
xDuoo presents with its XD-05 Basic a small, affordable yet extremely powerful portable headphone and DAC amplifier. Indeed, low price doesn't always rhyme with economy of means and the brand proves it here by offering a complete, robust, versatile device capable of delivering a powerful and rich sound.
The conversion stage of the XD-05 Basic features an excellent AKM AK4490 DAC chip capable of reading high-resolution files, up to 32bit 384kHz PCM and up to DSD256, for high-fidelity listening. This contributes greatly to an immersive sound reproduction of great precision. This DAC is associated with high-performance interface chips: a Cirrus Logic CS8422 for SPDIF signals, an XMOS XUF208 for USB. This is followed by a low-pass filter, an AOP and current amplifiers.
The amplification stage therefore integrates a DIP8-mounted AOP that can be replaced to adapt the sound signature, as well as a Class A circuit, the merits of which have already been praised by many audiophiles. This architecture allows the XD-05 Basic to deliver a power of 500mW, allowing it to accompany all types of headphones. It will be as comfortable with demanding headphones with impedance up to 600Ω, as it will be with very sensitive in-ear headphones.
In addition, the device allows you to adjust the gain level to suit any listening device, while limiting distortion and providing fast response without increasing background noise, always with a view to maximum compatibility. A Bass Boost feature provides hardware-based bass boost, ideal for use when enjoying a movie or video game. The 4 PCM filters and the 3 DSD filters allow you to adjust the sound reproduction to best suit your type of listening, by playing on the response curve. The XD-05 also features an SRC hardware system to improve the quality of files with a low bit rate to find many details.
The XD-05 features a large 3.7V 4000mAh Lithium Ion Polymer battery that provides at least 9 hours of continuous playback! Once at home, simply switch the power switch to EXTE to use an external power supply, such as a charger or a power bank.
A 0.91" OLED display clearly shows the sample rate of the file being played back, the selected input, the battery level and the selected filter. The volume knob is also surrounded by an LED, lighting up to indicate low battery power.
| Specifications | |
| Product type | Portable headphone amplifier and DAC |
| DAC chip | AKM A4490 |
| Inputs | 1x Aux In Jack 3.5mm 1x Coaxial / Optical (3.5mm format) 1x USB-C |
| Outputs | 1x Jack 6.35mm 1x Aux Out Jack 3.5mm |
| Adjustable gain | +6dB 9dB 16dB |
| SNR | 115dB |
| Bass Boost | 0 +6dB |
| Frequency response | USB / Optical / Coaxial : 20Hz - 20kHz (±0.5dB) AMP : 10Hz - 60kHz (±0.5dB) |
| THD+N | USB / Coaxial / Optical : 0.0025% @ 1kHz AUX IN : 0.0018% @ 1kHz |
| Output power | 500mW @ 32Ω |
| Crosstalk | ≥ 75dB |
| Charging time | Quick charge 1.2A : ≤ 5h Slow charge 500mA : ≤ 11h |
| Battery life | USB ≥ 9h AUX ≥ 16h Coaxial / Optical ≥ 12h |
| Supported sampling rates | USB : PCM up to 32bit 384kHz, DSD (DoP/Native) up to DSD256, DXD up to 32bit 384kHz Optical / Coaxial : PCM up to 24bit 192kHz |
| Compatibility | Windows 7/8/10 Max OS X iOS Android |
| Specifications | |
| Dimensions | 75.2 x 139 x 22.8mm |
| Housing material | Aluminium |
| Color | Black |
| Package | 1x xDuoo XD-05 Basic 1x USB-C cable 1x USB-C to USB-C cable 1x USB-C to Micro USB cable 1x USB-A to USB-C adapter 1x Jack 6.35mm to Jack 3.5mm adapter 10x Silicon feet 1x Silicon strip |
| Input | Jack 3.5mm |
| Input | Optical Mini-Toslink |
| Input | SPDIF |
| Output | Jack 3.5mm |
| Output | Jack 6.35mm |
| Color | Black |
| Remote Control | No |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Ričardas D.
Leo M.
