FIIO KA17 Balanced Portable DAC Headphone Amplifier Blue
With its KA17 balanced portable DAC headphone amplifier, FiiO unveils a compact high-performance device. The KA17 incorporates high-quality components such as two ES9069Q DAC chips and an XMOS XU316 USB interface. Added to this is an amplifier stage based on THX AAA 78+ technology and no fewer than 8 AOPs. Thanks to these components, the KA17 is able to decode high-resolution PCM 32bit 768kHz, DSD512 and MQA streams, while offering substantial output power of up to 2x 650mW @ 32 ohm 1% THD+N.
Reference : 18848
159,00 €tax incl.
132,50 € tax excl.
FIIO KA17 Balanced Portable DAC Headphone Amplifier 2x ES9069Q THX AAA 78+ XMOS XU316 32bit 768kHz DSD512 MQA Blue
FiiO KA17 picture
With its KA17 balanced portable DAC headphone amplifier, FiiO unveils a compact high-performance device. The KA17 incorporates high-quality components such as two ES9069Q DAC chips and an XMOS XU316 USB interface. Added to this is an amplifier stage based on THX AAA 78+ technology and no fewer than 8 AOPs. Thanks to these components, the KA17 is able to decode high-resolution PCM 32bit 768kHz, DSD512 and MQA streams, while offering substantial output power of up to 2x 650mW @ 32 ohm 1% THD+N. In terms of connectivity, the KA17 benefits from a USB-C connector and two outputs: a jack 3.5mm headphone output and a jack 4.4mm balanced output. In terms of aesthetics and ergonomics, the KA17 features a sturdy CNC-machined aluminum shell, a dot-matrix screen for displaying playback information and navigating settings, as well as side-mounted control buttons for volume control.
FiiO KA17: 2x ES9069Q DACs and XMOS XU316 USB interface
The FiiO KA17 portable DAC headphone amplifier features two ESS Technology ES9069Q DAC chips based on a 32bit Hyperstream IV architecture, enabling it to achieve a dynamic range of 130dB and a THD+N of -120dB for pure, detailed sound reproduction. Rarely used on devices of this minimum size, FiiO has nevertheless chosen to integrate an XMOS XU316 USB interface. This well-thought-out set of chips enables the KA17 to support high-resolution PCM 32bit, 768kHz, DSD512 and MQA streams.
Photo de la puce DAC ES9069Q et USB XMOS SU316
FiiO KA17: an amplifier stage based on THX AAA 78+ technology
Already used in the M11 Pro and M11 Plus, THX AAA 78+ technology is also present in the KA17. Here, it is coupled with the use of 8 AOPs working in parallel in a 4-channel symmetrical configuration for high output power and detailed sound reproduction quality. Indeed, its output power reaches up to 2x 650mW on its balanced 4.4mm jack output and up to 2x 270mW on its 3.5mm jack output.
Photo of the FIIO KA17 amplifier circuit
FiiO KA17: a circuit comparable to high-end audiophile DAPs
Digital and analog signal processing are performed on two separate PCBs, isolated to avoid any interference. Crystal oscillators bring a high level of precision to digital signal processing, while analog processing benefits from an LPF + BUF + BUF structure.
Photo de l'architecture FIIO KA17
Application FIIO control
FiiO KA17: a control app and EQ settings
The free FiiO Control App mobile application, available on both Android and iOS, gives you access to numerous settings for the KA17 from your smartphone. These include access to 10 EQ presets to tailor your listening experience to your musical preferences.
Zoom sur le port USB indépendant du FIIO KA17
FiiO KA17: an independent USB charging port
The KA17 features 2 USB ports, a classic USB port for connecting your external source such as your computer, tablet or smartphone, and a USB port for use with an external power supply. This external power port, when used, enables the KA17 to reach its maximum output power and better audio performance without consuming the battery of your source device.
FiiO KA17: advanced features
UAC1.0 protocol compatible
USB port UAC1.0 protocol
Connect to your video game console.
Gain level curves
2 gain levels
Adapt the gain level to your IEMs or headphones.
FIIO KA17 volume control
Two types of volume control
A fast 60-step adjustment and a precise 120-step adjustment.
SPDIF output
SPDIF output
The 3.5mm jack output also supports a 32bit 96kHz SPDIF signal, transforming the FiiO KA17 into a USB-to-SPDIF interface for connection to an external DAC, for example.
FiiO KA17 overview
FIIO KA17 overview
1Aluminum shell
2Volume +
3Volume -
4Multifunction button
5Switch mode desktop
63.5mm jack output
7Balanced 4.4mm jack output
8USB-C input (DATA + power)
9USB-C port for independent external power supply
Product typePortable DAC headphone amplifier
DAC chipES9069Q
USB interfaceXMOS XU316
AmplificationTHX AAA 78+
OPA2x OPA1612
Output1x Jack 3.5mm headphone output
1x Jack 4.4mm balanced headphone output
Supported sample ratesPCM 32bit 768kHz, DSD512, MQA
Output power270mW @ 32 ohm (THD+N < 1%, SE, desktop mode)
650mW @ 32 ohm (THD+N < 1%, BAL, desktop mode )
140mW @ 32 ohm (THD+N < 1%, SE, desktop mode off)
300mW @ 32 ohm (THD+N < 1%, BAL, desktop mode off)
30mW @ 300 ohm (THD+N < 1%, BAL, desktop mode)
90mW @ 300 ohm (THD+N < 1%, BAL, desktop mode)
SNR≥ 126dB (A-Weighted)
BruitPO : < 2uV (A-Weighted)
BAL : < 2.2uV (A-Weighted)
THD+N< 0.0004% (1kHz @ 32ohm
Dimensions64 x 27.7 x 12.7mm
ColorBlue
Weight33.5g
Package1x FiiO KA17 Portable DAC Headphone Amplifier
1x USB-C to USB-C OTG cable
1x USB-C to USB-A adapter
1x Leather case
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipES9069Q
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
ColorBlue
ClassN/A
With its KA17 balanced portable DAC headphone amplifier, FiiO unveils a compact high-performance device. The KA17 incorporates high-quality...
