FOSI AUDIO DS1 Portable Headphone Amplifier DAC ES9038Q2M Balanced 32bit 768kHz DSD512
The Fosi Audio DS1 is a compact and powerful portable headphone amplifier and DAC combo, ideal for enjoying high quality listening from a source such as a smartphone. Its digital / analog conversion section uses a ESS ES9038Q2M DAC chips ensuring a detailed and accurate sound reproduction, while supporting high resolution audio streams up to PCM 32bit 768kHz and DSD512.
Reference : 16996
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 12-05-2026.
Fosi Audio DS1
Amplificateur Casque DAC Portable ES9038Q2M Symétrique 32bit 768kHz DSD512
Fosi Audio DS1 Amplificateur Casque DAC Portable ES9038Q2M Symétrique 32bit 768kHz DSD512
The Fosi Audio DS1 is a compact and powerful portable headphone amplifier and DAC combo, ideal for enjoying high quality listening from a source such as a smartphone. Its digital / analog conversion section uses a ES9038Q2M DAC chips ensuring a detailed and accurate sound reproduction, while supporting high resolution audio streams up to PCM 32bit 768kHz and DSD512. Alongside them, its amplifier stage is capable of delivering comfortable power to accompany both demanding headphones and more sensitive earphones, all while maintaining low distortion and noise levels and high SNR.
On the connectivity side, the input is done from a USB-C connector. For the outputs, the DS1 provides a single-ended Jack 3.5mm and a balanced Jack 4.4mm for even more versatility.
Test du FOSI DS1
The DS1 is very well designed and quite powerful, capable of powering a large number of headphones at a good volume. It's slightly inferior to the DS2 variant in terms of noise and distortion, but makes up for it in terms of available power. I'm happy to recommend the Fosi DS1 headphones amplifier and DAC.
Logo ASR
Product typePortable headphone amplifier and DAC
DAC chipES9038Q2M
Input1* USB-C
Outputs1* Single-ended Jack 3.5mm
1* Balanced Jack 4.4mm
Output powerSingle-ended: 120mW
Balanced: 220mW
Impedance16-300Ω
Frequency response20Hz-20kHz (±0.5dB)
THDSingle-ended: 0.0006% @ 32Ω
Balanced: 0.001% @ 32Ω
SNR≥ 120dB
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
Weight38g
Package1* Fosi Audio DS1
1* USB-C cable
1* USB-A to USB-C adapter
OutputJack 3.5mm
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Max sampling rateDSD512
The Fosi Audio DS1 is a compact and powerful portable headphone amplifier and DAC combo, ideal for enjoying high quality listening from a source...
