DAC Balanced Portable Headphone Amplifier 2x ES9018K2M 2x ES9601K 24bit 192kHz DSD128
The Hidizs DH1000 DAC / Portable Symmetrical Headphone Amplifier combo is the ideal companion for enjoying exceptional listening quality at home or outdoors. The device offers full compatibility and excellent audio performance thanks to a rigorous design to accompany you in your listening and reveal the smallest details of your music.
The amplification circuit embeds two ES9061K chips capable of developing significant power to accompany the vast majority of headphones on the market, up to 600 Ohm, while ensuring accurate and faithful reproduction.
The Hidizs DH1000 relies on a pair of high-performance DAC ESS ES9018K2M chips for digital-to-analog conversion, with each chip processing the audio stream of a single channel. In addition, these chips support high-resolution audio files up to 24bit 192kHz PCM and DSD128.
Low noise audio
The DH1000's carefully optimised PCB benefits from gold-plated circuitry for excellent electrical conductivity and a structure that significantly limits interference that can have a negative impact on the integrity of the audio signal and consequently on sound reproduction. With an excellent analog output stage with a signal-to-noise ratio (SNR) of 122dB, the DH1000 offers incredibly accurate and rich sound reproduction.
Outstanding sound quality
With an extended frequency response from 0Hz to 50kHz and 120dB stereo separation, the Hidizs DH1000 is able to unveil a sound of great transparency and separation of high, mid and low frequencies, allowing previously imperceptible details to be revealed for an unparalleled immersion in the heart of your music.
Quadruple high quality clocks
The DH1000 carries no less than 3 ultra low noise clocks for signal transmission and one for measurements. These allow a drastic reduction of the jitter and thus a significant limitation of the distortion.
Thanks to its two ES 9601K amplifier chips, the DH1000 is capable of accompanying most headphones on the market, including demanding models with an impedance of up to 600 Ohm. The Hidizs amplifier / DAC benefits from more than one dual headphone output, with an unbalanced 3.5mm jack and a balanced 2.5mm jack.
The DH1000 has two independent Micro USB inputs for power line and data transfer. This makes it possible to use the device on the move, with a power bank connected, while still listening to your music.
With its advanced decoding capabilities, the DH1000 supports many audio formats including FLAC, APE, WAV, ALAC, Apple Lossless, DSF, DSIFF with sample rates up to PCM 24bit 192kHz and native DSD128.
Product type | Balanced headphone amplifier / DAC |
DAC Chip | 2x ESS ES9018K2M |
Amplification chip | 2x ES9601K |
Supported sampling rates | PCM up to PCM 24bit 192kHz DSD up to DSD128 |
Frequency response | 0Hz - 50kHz |
Outputs | 1x Single-ended Jack 3.5mm 1x Balanced Jack 2.25mm |
Inputs | 2x Micro USB |
System compatibility | Android iOS Windows Mac |
ASIO compatibility | Windows 7 / 8 / 10 |
Autonomy | 10h |
THD+N | 117dB |
Channel separation | 120dB |
SNR | -122dB |
Output power | Single-ended Jack 3.5mm headphone output : 120mW 32 Ohm Balanced Jack 2.5mm headphone output : 150mW 32 Ohm |
Housing material | Aluminium alloy |
Glass | Double sided 2.5D tempered glass |
Dimensions | 121 x 68 x 13mm |
Color | Noir |
Package | 1x Hidizs DH1000 1x USB-A to Micro USB cable 1x USB OTG Cable 1x USB-C to Micro USB cable |
