IFI AUDIO XCAN Portable Headphone Amplifier Bluetooth Balanced / Single-Ended
The iFi Audio xCAN is a dual mono headphone amplifier for use at home and on the move. Taking advantage of careful design and technologies specially designed by the brand, it ensures a rich and faithful reproduction.
By buying this product you get 34 loyalty points
Reference : 13451
349,00 €tax incl.
290,83 € tax excl.
iFi Audio xCAN
Headphone Amplifier Balanced / Single-Ended Bluetooth aptX
The iFi Audio xCAN is a dual mono headphone amplifier for use at home and on the move. Taking advantage of careful design and technologies specially designed by the brand, it ensures a rich and faithful reproduction. In addition, the amplifier benefits from advanced connectivity with the integration of Bluetooth aptX and AAC. The device is able to remember 8 devices and will allow you to stream your favorite songs
xxx
Dual mono headphone amp
The xCAN has a dual mono headphone amplifier capable of delivering no less than 1000mW per channel. It will allow your headset to reach its full potential, whether it is a 32 Ohm or 600 Ohm model. In addition, the xCAN has balanced inputs and outputs to connect a balanced source and headphone. The balanced headphone output is in 2.5mm Jack format and can be used to boost the amplification of a high-end DAP.
xxx
S-Balanced Technology
S-Balanced technology delivers the best audio performance with either unbalanced or balanced headphones. The S-Balanced output in 3.5mm Jack format offers the advantages of symmetry to unbalanced headphones, i.e. lower distortion and reduced crosstalk.
xxx
aptX and AAC Bluetooth
Thanks to its Bluetooth module supporting aptX and AAC technologies, the xCAN is able to offer sound quality extremely close to that of the CD. Simply stream your music from a Bluetooth-connected device such as your smartphone and enjoy your favorite songs.
xxx
3D+ and XBass II
La technologie 3D+ proposée par iFi Audio permet d'améliorer la restitution sonore en offrant une scène sonore absolument bluffante. La technologie XBass II elle permet de fournir une correction analogique des graves et de la réponse de votre casque. Le résultat est un son plus naturel et crédible notamment dans les médiums.
xxx
Perfect synchronization
The iFi Audio xCAN uses an AMR Global Master Timing clock for perfect signal synchronization and therefore no jitter. As a result, the signal is not degraded and the sound reproduction is of high purity and precision.
xxx
Cyberdrive
The Cyberdrive amplification stage is a new circuit proposed by iFi Audio. This design combines the analog system with digital control to take advantage of the advantages of each technology. This Cyberdrive stage integrates a very low noise OV4627 AOP at the input and a volume attenuator with W990VST digital control.
xxx
Battery
The xCAN has a built-in battery, rechargeable using the USB-C connector. The fact that the amplifier operates on battery power means that you do not need to use the battery of your smartphone or DAP. In addition, this battery offers a significant autonomy of 8 hours in playback.
iFi Audio xCAN review by Major HiFi
Thanks to a fantastic sound and the impressive capability to use a balanced line-in connection, this iFi amp signals a new chapter in affordable hifi audio gear. "
CharacteristicS-BalancedBalanced
Power> 3.8V 45mW @ 300 Ohm
> 3.5V 380mW @ 32 Ohm
> 3.1V 600mW @ 16 Ohm
> 7.6V 90mW @ 600 Ohm
> 7.2V 800mW @ 64 Ohm
> 5.7V 1000mW @ 32 Ohm
THD+N< 0.005% @ 100mW/1.26V 16 Ohm< 0.006% @ 360mW/2.4V 16 Ohm
SNR> 121dBA @ 3.8V> 120dBA @ 7.6V
Max input voltage3V RMS6V RMS
BluetoothAAC, aptX, aptX LL, SBC
16bit 44.1/48kHz
Inputs1x Jack 3.5mm (TRS or S-Balanced TRRS)
1x Jack 2.5mm (TRRS)
Impédance casque recommandée16 - 600 Ohm
Gain-95dB à +18dB adjustable by 1dB steps
Frequency response< 2Hz - > 200kHz (-3dB)
Battery life> 8 hours in playback
Dimensions95 x 67 x 19mm
Weight127g
InputJack 3.5mm
InputJack 2.5mm
OutputJack 2.5mm
OutputJack 3.5mm
ColorSilver
ClassN/A
The iFi Audio xCAN is a dual mono headphone amplifier for use at home and on the move. Taking advantage of careful design and technologies...
