XDUOO XD05 BASIC Portable Headphone Amplifier DAC ES90108K2M XMOS 32bit 384kHz DSD256
xDuoo presents with its XD-05 Basic a small, affordable yet extremely powerful portable headphone and DAC amplifier. Indeed, low price doesn't always rhyme with economy of means and the brand proves it here by offering a complete, robust, versatile device capable of delivering a powerful and rich sound.
Reference : 15521
149,00 €tax incl.
124,17 € tax excl.
xDuoo XD05 Basic
Portable Headphone Amplifier DAC ES9018K2M XMOS 32bit 384kHz DSD256
xDuoo XD-05 Basic Amplificateur Casque DAC Portable ES9018K2M XMOS 32bit 384kHz DSD256
High Quality Digital Decoding & Amplification
The conversion stage of the XD-05 Basic features an excellent ES9018K2M  DAC chip capable of reading high-resolution files, up to 32bit 384kHz PCM and up to DSD256, for high-fidelity listening. This contributes greatly to an immersive sound reproduction of great precision. This DAC is associated with high-performance interface chips: a Cirrus Logic CS8422 for SPDIF signals, an XMOS XUF208 for USB. This is followed by a low-pass filter, an AOP and current amplifiers.
The amplification stage therefore integrates a DIP8-mounted AOP that can be replaced to adapt the sound signature, as well as a Class A circuit, the merits of which have already been praised by many audiophiles. This architecture allows the XD-05 Basic to deliver a power of 500mW, allowing it to accompany all types of headphones. It will be as comfortable with demanding headphones with impedance up to 600Ω, as it will be with very sensitive in-ear headphones.
In addition, the device allows you to adjust the gain level to suit any listening device, while limiting distortion and providing fast response without increasing background noise, always with a view to maximum compatibility. A Bass Boost feature provides hardware-based bass boost, ideal for use when enjoying a movie or video game. The 4 PCM filters and the 3 DSD filters allow you to adjust the sound reproduction to best suit your type of listening, by playing on the response curve. The XD-05 also features an SRC hardware system to improve the quality of files with a low bit rate to find many details.
Optimized Battery & Display
The XD-05 features a large 3.7V 4000mAh Lithium Ion Polymer battery that provides at least 9 hours of continuous playback! Once at home, simply switch the power switch to EXTE to use an external power supply, such as a charger or a power bank.
A 0.91" OLED display clearly shows the sample rate of the file being played back, the selected input, the battery level and the selected filter. The volume knob is also surrounded by an LED, lighting up to indicate low battery power.
Product typePortable headphone amplifier and DAC
DAC chipESS ES9018 K2M
Inputs1x Aux In Jack 3.5mm
1x Coaxial / Optical (3.5mm format)
1x USB-C
Outputs1x Jack 6.35mm
1x Aux Out Jack 3.5mm
Adjustable gain+6dB
9dB
16dB
SNR115dB
Bass Boost0
+6dB
Frequency responseUSB / Optical / Coaxial : 20Hz - 20kHz (±0.5dB)
AMP : 10Hz - 60kHz (±0.5dB)
THD+NUSB / Coaxial / Optical : 0.0025% @ 1kHz
AUX IN : 0.0018% @ 1kHz
Output power500mW @ 32Ω
Crosstalk≥ 75dB
Charging timeQuick charge 1.2A : ≤ 5h
Slow charge 500mA : ≤ 11h
Battery lifeUSB ≥ 9h
AUX ≥ 16h
Coaxial / Optical ≥ 12h
Supported sampling ratesUSB : PCM up to 32bit 384kHz, DSD (DoP/Native) up to DSD256, DXD up to 32bit 384kHz
Optical / Coaxial : PCM up to 24bit 192kHz
CompatibilityWindows 7/8/10
Max OS X
iOS
Android
Dimensions75.2 x 139 x 22.8mm
Housing materialAluminium
Package1x xDuoo XD-05 Basic V2
1x USB-C cable
1x USB-C to USB-C cable
1x USB-C to Micro USB cable
1x USB-A to USB-C adapter
1x Jack 6.35mm to Jack 3.5mm adapter
10x Silicon feet
1x Silicon strip
InputJack 3.5mm
InputOptical Mini-Toslink
OutputJack 6.35mm
OutputJack 3.5mm
DAC / ADC ChipES9018K2M
Max sampling rateDSD256
Max sampling rate384kHz
ClassClass A / AB
3 reviews
Dt990 Peo
Enfin un ampli qui drive autoritairement mon dr990 pro.
Bel espace sonore de la précision de l'ampleur.
Ça ne vaut pas un audio GD en classe A mais c'est plutôt étonnant.
Fantaisie militaire de Bashung bien respecté ça foisonne c'est détouré un joli aigu.
Une légère redondance dans le haut grave mais sans plus.
L'appareil est un peu gros mais il faut savoir ce qu'on veut.
Bref très bon rapport qualité prix
This review has been posted for XDUOO XD05 BASIC Portable Headphone Amplifier DAC ES90108K2M XMOS 32bit 384kHz DSD256
powerful entry-level amp and good dac
It sounds clean and detailed. There is enough power to drive any headphone even on low gain. The dac seems fine and works well when connected to an external amp (this is not a pre-amp so no volume control for the line-out, volume control is only for the headphone-out.) there very little channel imbalance on extremely low volume (you will never listen to that low even with iems) The pachage has all the accesories you would need except from an aux cable (only needed to connect to external amp) there is even a very handy resusable adhesive to use if you want to "glue" this device to your phone or DAP. Battery lasts about 7 hours depending on use so pretty good. There is no hiss or noise even on very sensitive iems although the volume is too much to pair it with such iems, better suited for harder to drive stuff, unless you lower the volume from the phone-computer-dap. Generally Very satisfied with the purchase.
Parfait, impossible de charger la batterie et de l'utiliser en même temps sans brancher 2 cables
Malgré que ça ne soit pas annoncé il fonctionne parfaitement avec GNU/Linux, il est par contre nécessaire de modifier les fichiers de configuration de pulseaudio ou pipewire pour que l'échantillonage change selon le fichier source. Une fois modifié on voit bien le petit écran afficher l'échantillonage du fichier qu'on lit.
Aucune diférence audible entre PCM1 et PCM2.
Pas pris pour le bass boost, c'est au final une bonne surprise qui est bien utile selon le genre de musique et les casques audio.
Seul petit bémol le port USB pour les données sert uniquement aux données, il ne peut pas alimenter l'appareil, il faut donc aussi connecter le port d'alimentation si l'on ne veut pas décharger la batterie.
Autrement le son est très propre et même 600 ohms ne sont pas un problème.
Testé aussi avec une OP Amp TI LME49720NA/NOPB, pas vraiment de différence audible mais ça fonctionne aussi bien.
Avec un Surfans F20 en USB il y malheurement de petits artefactes, mais c'est le Surfans qui est en cause.
xDuoo presents with its XD-05 Basic a small, affordable yet extremely powerful portable headphone and DAC amplifier. Indeed, low price doesn't...
