Roland S.
Dac tv
Walter V.
Great product!
Joli mais non..
Customers reviews - There are 19048 reviews.
Jose l.
MUSICIAN MONOCEROS Preamplifier Balanced Class A Silver The Musician Monoceros is a beautiful, high-end balanced preamplifier with a high performance Class A architecture and a completely discrete line input stage. Its volume control...
beaucoup de plaisir musical.
pour tout ceux qui en marre du son numérique comme moi avant de acheter ce préampli. c'est tellement bon que je me couche de plus tard en plus tard . c'est une merveille ne cherchais plus , a 2h. du matin je crois entendre une platine TECHNICS SL 1200. WAOUH.LAISSEZ LE BIEN CHAUFER . très économique en plus max 20w. REGARDER LE TEST SUR NIEW SOUND , tout ce qui est écrit est vraie et je confirme .
Clarice C.
AUDALYTIC AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Silver The Audalytic AH90 is a DAC offering excellent decoding performance and precise sound reproduction, thanks to a careful and intelligent design. And it's reasonably priced for...
80% of the Gustard A26 at 1/3 the price
This unit is simply wonderful. Instrumental timbres are correct. Instrumental separation is accomplished. The unit is in no way slow in the low bass frequencies. If your speakers tend to beam the treble frequencies, the filters supplied in the DAC are a huge help and don't destroy the musicality. I am joyous over this purchase. I feel confident in saying that this is the best Streaming, DAC, and headphone amp you can buy for 599. FIf you are not Roon centric, you can use a WiiM Pro, because this unit will beat the pants off of the WiiM Pro+. I am still setting everything up and amazed it even bettered my Moon CD-1 with Burr-Brown Chips and I 8 times upsampling. They will be releasing a new firmware to address some concerns expressed by DSD disk owners. I listened to several of mine without the firmware and it is still the best DAC I have heard. It drives ma headphones too. It does not do Chromecast natively but the company says they intend to extend availabilities. Head-Fi has a dedicated page for Gustard owners if you are interested.
I am in love.
Gilles G.
Esthétique
Une gamme de gaines coton noir esthétique et facile à passer. Idéale pour la finition d'un câble.
MUNDORF E-CAP ECAP100 (BR100) RAW Capacitor 100VDC 32VAC 15μF Mundorf E-Cap audio and signal coupling capacitors are bipolar electrolytic capacitors. They are used in applications where film capacitors are not suitable for space or cost...
Voilà une série de condensateurs d'excellente qualité audio, très belle fabrication compacte.
Je les ai monté en parallèle dans mes filtres d'enceintes et aucune différence avec des condensateurs MKP de haut vol dans cette configuration.
Toujours aussi rapide Audiophonics pour la livraison, en 24h, bravo !! bravo vraiment !!
MUNDORF E-CAP ECAP100 (BR100) RAW Capacitor 100VDC 32VAC 10μF Mundorf E-Cap audio and signal coupling capacitors are bipolar electrolytic capacitors. They are used in applications where film capacitors are not suitable for space or cost...
ATAUDIO SILVER Male USB-A to Male USB-B Cable Pure OCC Silver 0.75m The ATAudio Silver USB cable offers exceptional build quality for optimal transmission performance. It features eight pure silver conductors that are insulated and braided...
Excellent RQP
Testé aujourd'hui sur entrée usb Tooping depuis un Ifi Zen Streamer le résultat est excellent pour un cable neuf sur une entrée usb neuve elle aussi.
Belle ouverture grave tendus et scène sonore tout a fait cohérente.
Merci Audiophonics
Jean Francois A.
SOVTEK EL84SOV / 6BQ5 Tube Pentode (Matched Pair) The Sovtek EL84SOV/6BQ5 is a pentode tube with equipotential cathode, designed to amplify low frequency power in the output stages of HiFi audio devices. It offers a soft, warm...
Conforme
Conforme à mes attentes. Livraison rapide et colis bien protégé. Super !
Jean Francois A.
Conforme
Jean-Marc H.
incontournable
C'est le connecteur à utiliser pour un câble coaxiale.
Car il se monte sans soudure d'où l’appellation RCA75ohm.
Un vieux principe qui s'applique à tout nos câbles coaxiaux utilisés pour transmettre un signal, qu'il soit numérique ou vidéo, pour maintenir une impédance de 75ohm.....Donc soudure à proscrire.
Les 75 ohm d'impédance du câble ne suffisent pas. Il faut des connecteurs sertis à chaque extrémité.
Ce Canare RCAP C5F est un excellent choix. Attention tout de même à la section de l'âme conductrice du câble que vous souhaitez utiliser. Au-delà de 0.2mm, ça ne rentre plus dans l'embout de contacte. Pour le sertissage, effectivement il y a une pince à 200€ , mais il en existe de bien moins cher dans tout les bon magasin de bricolage qui feront largement aussi bien et aussi efficace pour transmettre le signale.
Je monte depuis....un sacré bout de temps, ce connecteur sur l'excellent câble Furutech FC-62 en vente sur ce site ; et ça marche !
Pascal J.
En lieu et place du Mogami 3103
Parfait entre mes Elipson Concept 1 & un Kenwood Kr33L. Clair & précis de haut en bas. Remplace le mogami avec bonheur: en
prime + souple & moins cher.
Jean-Marc H.
Je les utilise depuis quelques temps, avec une pince à sertir sans le moindre souci
Anon
how can such a small capacitor have such an impact ?
now also used as bypass in the treble branch (Mundorf MCap Supreme) of the same speakers. Already after soldering more natural sound.
Raimo J.
Excellent quality
The ACSS feature is an interesting addition between my Audio GD Master 3 amplifier and the R28 2020 as a preamp. In my opinion, the sound is more musical, more distinctive and the performer comes out better than with a basic XLR cable. If you have a good XLR cable, you can easily compare the connection difference by pressing the button on the back of the amplifier and choose the best cable. Also the ABX test with a friend is easy.
The delivery of the order was also super fast delivered by UPS in 3 days. In practice, faster delivery than when ordered from home. Great online store.
Dieter Z.
Hello,
I am fully satisfied - great powerful amp, fast delivery, top performance, better than my previous ML 431!
Eric V.
Agréablement surpris
Commandé le vendredi, livré le lundi : peut difficilement faire mieux !! Emballage de qualité. Très agréablement surpris de la qualité de fabrication, c'est du solide et du lourd, montage bien ajusté. Pour la qualité audio, premiere impression très positive, c'est dynamique, le grave est bien présent. Pour ceux qui trouve que c'est fade, le coupable c'est pas l'ampli mais l'acoustique de votre pièce d'écoute qui n'est pas au top, ce qui peut se corriger en actif et ou passif.
Eric
Etonnant et imbattable rapport qualité prix
Surprise totale à l'écoute de cet ampli Classe D dont la puce TBA3255 bien que très réputée ne pouvait laisser imaginer un aussi bon résultat.
Mise en oeuvre et optimisation vraiment remarquable.
- Son à la fois transparent, très musical et absent de toute tonique ou distorsion même sur le fortés ?
Bravo !
Interface digitale excellente.
Cette interface outre sa qualité de fabrication s'avère très performante. Sa connectique est bien fournie. Elle alimente un dac "Lake People RS6 via la prise AES/EBU". Je l'ai raccordée à l'ordinateur sur une prise USB C par l'intermédiaire d'un câble en argent pure Ataudio silver USB C vers USB B. Le résultat est à la hauteur, musicalité, dynamique, précision du grave à l'aigu. Bref je ne regrette pas l'achat.
Jean-Luc P.
Home cinéma.
Acheté pour allumer mon caisson de basse avec la prise trigger de l'ampli. Fait le taf.
Livraison dans les délais et suivi du colis impeccable.
Julien G.
Parfait pour simraing
En complément d'un Bst-1 c'est excellent...
Expédition, prix et échanges avec le vendeur au top!
Jose l.
très bon son
très bon a toutes les fréquences .les sources numériques qui passent par lui deviennent vraiment analogiques . je suis très satisfait c'est ce que je voulait .
Virginien L.
Mitige
Je vais sans doute passer pour la bête noire mais je ne pense pas que ce produit soit magique.
La finition est bonne et la mise en œuvre assez simple.
Cote son, c’est pas si mal pour le prix, mais un dac correct autour de ce tarif fait sans doute mieux. (Mon ancien Dac de 10 ans et 600 euros a l'epoque reste bien superieur).
Globalement c’est pas complétement mauvais mais le bas du spectre manque de profondeur et de tension (sans doute à cause de l’alimentation et le filtrage d’alimentation ou du rodage ?) et le haut est relativement criard, surtout sur des compressions.
De plus, la connexion Wifi n’est pas de dernière génération ca décroche facilement (Malgré mes 500 Mb), le niveau sonore change sans préavis, ou l’application plante. Privilégiez une connexion BT (la ca fonctionne bien) ou mieux Ethernet. (Mais je ne peux pas malheureusement).
Comme la plupart des streamers, l’interface de vos application préférées n’est pas standard et peu intuitive. (Mais idem pour des produits bien plus chers).
Bref, dans l’ensemble je reste persuadé que c’est un bon produit mais je reste vraiment sur ma faim. Ca reste un appareils entres de gamme et ce n’est pas du tout au niveau de ce que j’attendais.
boris h.
Tres bien
Acheté car le bluetooth d'origine de mon ampli était zéro à plus de 4 metres de distance...
Celui tiens bien le son à 10 mètres (sans mur évidemment, sinon ça coupe).
Ne fonctionne toujours pas bien avec le bluetooth de mon ordinateur (précision : BT reconnu mais liaison instable) ... mais ca, c'est parce que le BT du pc est vraiment pourrie...
Fonctionne niquel avec android ou iphone (anciennes version ou récente... et plus le BT source est récent meilleur est le son)
Son qualité très satisfaisante. Comparable CD. Légèrement mieux qu'un autre émetteur BT testé d'une autre marque et de prix équivalent.
Point d'amélioration à prévoir : si un appareil est connecté dessus, il faut cliquer sur un bouton de l'émetteur BT pour connecter le nouvel appareil. Ca aurait été bien une connexion "à la volée" depuis l'appareil source.
Bon, pas très gênant ...
J'ai priviligié cet outil à du wifi car fonctionne sans réseau internet, aussi car puce semble plus performante que solutions mélengeant BT/wifi (à prix équivalent), et enfin car à l'oreille la qualité est très bonne.
5 étoiles.
Marlon M.
White Round Vumeters with Controller Ø35mm (Pair) These 35mm diameter white backlit meters are easy to mount and wire to an amplifier, giving your unit a beautiful vintage look. The meters are delivered with a remote controller...
Look great, but no manual, good luck.
Nice price, I'm not sure if they work well or not because the meters didn't come with a manual and the labels are a bit misleading. The capacitors are rated at the same voltage as the AC input, shouldn't they be at least double the voltage for longevity?
The meters need the controller because they don't register like others and require higher voltages to measure sound levels (normal meters can connect directly to an output transformer for example).
Good price though, and they look good lit up, guess I will wire this up today :-p
Jean-Pierre D.
PANGEA PREMIER SE Digital Optical Cable Toslink 2m The Pangea Audio Premier SE optical cable uses a multiple bundle of plastic fiber optics. This feature allows it to overcome the limitations associated with the dispersion...
Haute qualité à un prix maîtrisé
Le rapport qualité/prix est très bon avec ce câble. C'est très bien fait. Le son est ouvert, impact des basses et aigus raffinés, une superbe scène sonore avec une voix et une instrumentation qui transparaissent. Pour moi, l'optique a toujours été un peu sec, mais ces propriétés ne s'entendent pas trop avec ce câble. Le service prévente d’Audiophonics me l’avait recommandé, très satisfait.
Thierry V.
Excellente qualité mais…
Excellente qualité de fabrication mais malheureusement non compatible avec les borniers de mes Dynaudio Spécial forty.
Philippe L.
KF F2 Contact Cleaner Lubricant 100ml KF F2 aerosol is an excellent cleaner, deoxidizer and lubricant for all mobile electrical and electronic contacts. It offers a protective action over time, penetrates and...
F2 toujours efficace, mais niveau tarif ça pic un peu
Philippe L.
Pour le prix ,rien de mieux
Philippe L.
Monté en entré disc sur ampli Nad T762, platine Dual, cellule Ortofon , son très correct pour le prix
Philippe L.
Produit de qualité
En remplacement d'un "potar" de volume d'ampli BST, dommage qu'il n'y a pas le même avec pin médiant pour le loudness .
Jean-Pierre D.
Un câble neutre avec de la présence, très bon rendu sur les voix pour un prix défiant toute concurrence
C’est un câble assez dynamique qui procure une très belle scène sonore, il manque un peu de matière et de timbres (très bonne neutralité par opposition). Son point fort, en dehors de son prix canon, la qualité des aigus qui ne sont jamais dur et parfaitement défini, les voix des chanteurs(ses) sont particulièrement belles, ce n’est pas trop clair ou trop sombre.
J’ai mis 5 étoiles pour le prix contenu (montage par Audiophonics), pour aller plus loin, à mon avis, c’est plus cher, le Neotec NEMOI 3220 (j’en ai une paire) offre plus avec davantage d’ouverture, de naturel et d’équilibre, il est plus capable de restituer la beauté de certains enregistrements, il me semble moins vif et dynamique par contre.
Thomas B.
Upgrade for XDUOO XD05 Pro
While the configuration of XD05 Pro, featuring OPA1612 integrated OpAmps provides already a sonic experience of high quality, one can recognize shortcomings in instrument separation, soundstage and attack. This is most noticeable in symphonic music played by large orchestra. There are not many reviews covering XD05 Pro and Sparkos SS3602 OpAmps and, with respect to the price of SS3602, I felt quite hesitant placing an order. Eventually I did and I am not at all disappointed! In fact, I am happy to endorse the Sparkos SS3602 OpAmps improve the HiFi experience in all aspects but one: the relative volume is slightly less than with OPA1612.
Worth noting: the XD05 Pro opamp printboard just manages to accomodate the SS3602, critical due to closy-by capacitors. In my case the remedy was chopping off the protruding wire tips in the very corners (tiny elevator bars fixing the printboards on top of each other) making sure the tips do not touch the capacitors. Different printboard revisions may carry cap's of different size and make, so yours may look different.
Anyway, I am convinced the Sparkos SS3602 mark the high end of OpAmp rolling and recommend them wholeheartedly!
Digital Interface USB Amanero / Bluetooth 5.0 to AES / SPDIF / I2S 32bit 192kHz DoP128 This small, high-performance digital interface takes a Bluetooth 5.0 or USB signal as input and then outputs it in I2S (via HDMI), AES, Toslink Optics or Coaxial. The Bluetooth...
Transfigure un "ancien" DAC Audio GD NFB 12.1,dont l'entrée USB est trés moyenne.
Avec un bon câble numérique coaxiale (un Audiophonics commandé en même temps),c'est vraiment très bon : Quobuz+Audirvana,avec un PC (en attendant un streamer dédié)
LAURENT G.
Eviter les box internet à proximité....
je veux juste signaler que cet amplificateur est sensible au bruit que peut générer une box internet située à proximité. J'avais installé la mienne sur l'étagère située juste au dessus de celle de l'ampli. Conséquence un ronflement périodique très audible dans le canal droit, atténué dans l'autre.
Problème résolu en éloignant la box internet (1 mètre suffit), ce qui au passage laisse augurer une médiocrité de conception et/ou de construction de cette dernière.
Laurent G.
LAURENT G.
Premières impressions
Preampli transparent et suffisamment puissant pour l'utiliser avec l'HPA -S400ET que j'ai du régler sur 20 db de gain pour pouvoir garder un réglage fin du volume.
Utilisé en sortie XLR, la possibilité de rajouter du gain en sortie est bienvenue pour une source phono qui gagne un peu de relief.
Ce appareil ne semble avoir aucune signature sonore et n''apporte donc aucune coloration particulière au son. Belle qualité de construction apparente et plutôt lourd pour la taille.
L'ayant reçu très récemment, il est trop tôt pour lui donner une note, notamment sur la fiabilité.
Mode d'emploi en français téléchargeable appréciable, mais ce serait mieux s'il était systématiquement joint avec l'appareil.
L.G.
Excellent cable
J'ai encore acheté ce câble pour un autre système.
A ce jour je n'ai pas trouve mieux et surtout a ce prix pour alimenter mes trois systèmes.
Il est vraiment au top.
Merci à Audiophonics pour avoir reçu le colis en 24H
Eric A.
AC/DC Switching Power Adapter 100-240VAC to 42V DC 8.5A This power adapter takes in input a voltage of 100-240VAC and allows to have in output a voltage of 42V DC for a current of 8.5A. Its output connector is a DC 5.5/2.5mm jack,...
Tres bonnee alimentation
Tres bon produit, ne chauffe pas du tout sur des blocs aiyima A07max. Je regrette seulement que le cordon secteur ne soit pas fourni, c'est pourquoi je ne met que 4 etoiles.
Eric A.
Rapport qualité prix impressionant
J'utilise 2 amplis A07 max en mode mono et c'est produit qui bien associé, c'est à dire avec un bon preampli peut se révéler très impressionant, car d'une très grande transparence.
En effet la puissance n'est pas un problème, mes Kef 105 -2 sont parfaitement tenues, cela descend bas, plus bas même qu'avec un ampli yamaha AS-2100. Impressionant ce que ces petites boites arrivent à envoyer comme jus, même si on reste tout de même loin des 300 W annoncés. Attention au voltage car les premières versions avaient des condensateurs de 50v un peu juste pour utiliser du 48v, pour ma part j'utilise l'alimentation 42v 8,5A Audiophonic sans probleme, cela chauffe tres peu. Je voulais tester la classe D à moindre frais je suis convaincu.
Richard P.
Belle surprise
Pour essayer en remplacement d'autres câbles japonais commençant par Moga dans le médium/aigu, ils apparaissent de suite un peu moins précis mais musical à mon goût sur mon système.
Très satisfait.
MUNDORF F71 Varnished Wire Ferrite Core Self 0.71mm 1.5mH The F-Series combines small size and low price, making it an excellent value for money for filtering woofers, or any other application requiring high inductance and/or low...
Super.
Super pour mes filtres d'enceintes, je les utilise en parallèle. Livraison 24h !
MUNDORF L071 Air Core Coil 0.71mm 0.27mH Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this...
Super.
Utilisées en parallèle dans mes filtres d'enceintes. Livraison 24h !
MUNDORF MR10 non-inductive metal film Resistor 10W 18 Ohm Unlike conventional resistors,  film metal winding resistors have no residual inductance. Thus, in cases where impulse response is essential, in midrange frequencies for...
Elles sont longues.
Longues mais excellentes pour mettre en parallèle dans des filtres d'enceintes. Livraison 24h !
Ils sont extras.
Très belle fabrication pour filtres en parallèle d'enceintes. Livraison 24h !
JANTZEN AUDIO CROSS-CAP Capacitor 400V 6.8µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
J'adore.
J'adore vraiment ces condensateurs, avis émis après utilisation d'une vingtaine de cette série. Livraison 24h !
JANTZEN AUDIO CROSS-CAP Capacitor 400V 4.7µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
J'adore.
J'adore vraiment ces condensateurs, avis après utilisation d'une vingtaine de cette série. Livraison 24h !
JANTZEN AUDIO CROSS-CAP Capacitor 400V 3.3µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
J'adore
J'adore vraiment ces excellents condensateurs, avis après une vingtaine achetés. Livraison 24h !
J'adore.
J'adore décidément ces condensateurs, j'en ai acheté une vingtaine, ils sont vraiment bons. Livraison 24h !
Excellent.
Excellente en série pour filtrer mes Cabasse Dom12 de mes Caravelle.
Livraison 24h !
JANTZEN AUDIO 000-0837 4N Copper Air Core Wire Coil 20AWG 0.92mH The Jantzen Audio Air Core Wire Coil is made of a very pure copper wire, offering distortion-free inductance. It will therefore be suitable for all audio applications. The coil...
Super en parallèle.
Super pour mes filtres en parallèle.
JANTZEN AUDIO 000-1673 4N Copper Air Core Wire Coil 17AWG 2.5mH 60x30mm High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.  The coil benefits from a modern design, self-supporting and with a low tolerance...
Du costaud !
Excellente. Plus imposante en vrai qu'en photo. Pour mettre en série sur mes Cabasse 21NDB, je refais entièrement mes filtres de Caravelle. Elle fait 2.60 mH, j'ai déroulé jusqu'aux 2.47 mH nécessaire, j'ai un impédance-mètre. Livraison en 24 h, je m'habitue à force, bravo à Audiophonics.
Très bien.
Bien plus solides que mes cosses chinoises même si celles-ci sont made in China aussi.
