Patrick G.
tres bonne conception
Abdoulaye D.
Soudure
Abdoulaye D.
Pince 3 in 1
Andris L.
Delta-sigma end game
Delta-sigma end game, but probably too expensive for many enthusiasts and I agree about the packaging, it is vulnerable, just hope that the store will package it well (it was acceptable for me).
Andris L.
The best of the best in its class
Super cheap price that makes any DAC sound acceptable (entry level Hi-Fi). The sound is relaxed but confident and well controlled with a slightly pronounced separation of vocals and instruments. From a very cheap built-in DAC, you will notice that the sound is no longer so compressed, it has become freer. I think this OP-Amp could be compared with any budget external DAC, but definitely better than the built-in one of Wiim streamer, cheap phone or headphones. This OP-Amp is the first one that produces a different sound from the ones included in the Aune X8 set (I compared).
Andris L.
Solid material with a metal plate inside that you can't see in the picture.
Andris L.
AUNE X8 XVIII BT MAGIC DAC ES9038Q2M Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Black The X8 XVIII BT Magic DAC from Aune is a special edition of the DAC, on the occasion of the 18th anniversary of the brand. This one takes back the idea of the interchangeable...
Standart package *** stars worth
I wrote a review for ASR. In short, you should know:
Only one extra Op-Ams comes with the set.
All the extra Op-Amps offered by Aune are no better than a cheap DAC on the market. The sound starts to normalize around OPA627, which can be purchased separately, and because of which you will not be able to close the lid of the device. The optical port does not click into place. The potentiometer has difficulty separating the channels. A POP sound will be heard when laying in/out. Only with Sparkos SS3602 will you have a real benefit. You can initially buy the cheap BB OPA627 and upgrade over time, or upgrade immediately if funds allow and the system is ready for it.
Bernard P.
attention au branchement
Très bonne prise achetée pour montage cordon secteur en DIY. Par contre suite à connexion sur barrette secteur dynavox X4100, allumage de la led Inversion de phase. Après recherche du défaut , le cordon est en cause : inversion phase et neutre au niveau de l'inscription N et L inscrit au niveau insertion des fils: Donc à ne suivre pour le branchement.
Par contre le schéma de branchement donné par le site est correct
Hugo Z.
Digitaler Eingang mit Bluetooth
Verbindung ist sehr gut und reißt nicht ab. Klang über Digitalkabel sehr gut.
AIYIMA B2D1496 Class A/B Amplifier Board SanKen1494/3858 2x220W 4 Ohm The AIYIMA B2D1496 is a Class A/B amplifier module. It is based on 8 SANKEN transistors, 4x 2SA1494 and 4x 2SC3858, to deliver a comfortable power of 2x220W under 4Ω or...
Service de qualité de la part d' Audiophonics, expédition rapide et emballage correct. .
L'ampli acheté produit un son de qualité, sa fabrication est de bonne qualité. Seule la dimension en hauteur est 5mm supérieure à celle donnée dans les caractéristiques produit.
denis L.
Super soudure
Necessite un bon fer a t° élevée mais soudage facile. Excellent pour les câbles RCA DIY son super détaillé et fidèle. Pas donnée mais résultat au top!
denis L.
Excellent RQP
Très bonne qualité des matériaux utilisés. La fiche peut paraître un peu légère mais elle tient bien dans les connecteurs pour une utilisation domestique sans débranchement très fréquents. Facile a souder et son top, neutre et fidèle. Très bon rapport Q/P
Marcos Pérez J.
A great cable
I have no experience in my current system with expensive cables, but I do have experience in how my equipment sounds and a good system must sound. And I can't think of how another cable could sound better. This cable is extremely detailed, and the best: not at all shiny, something that is usual in silver cables. An increase in the level of detail also means an increase in the hissing level in the recordings.
It is an ideal cable for DSD or low noise tracks. I have mounted it with RCA NEUTRIK NF2CB2 connectors. It would be very interesting to try it with other connectors to see the differences.
Marcos Pérez J.
Highly recommended
I also use this power amplifier in an active speaker system to amplify the bass frequency speaker. I can only say that the result is totally realistic bass frequencies. I have also done tests as a medium and high frequency amplifier and the result has surprised me very positively, not so much as to replace a power amplifier with 300B valves and premium components, and although the timbre and especially the voices of the power stage of vacuum valves are noticeably superior, the scene and speed seem outstanding to me, especially for the price of these stages. I advise your purchase without reservation.
j'en rajoute une couche !!!
aujourd'hui mon revendeur hifi m'a prêté un drive heed obelisk dt pour tests.....le drive va rester à la casa car couplé au D300 cela donne un truc super musical !!! avec le oyaide dst-75 cela donne de la matière et beaucoup de délicatesse tout en gardant une dynamique très naturelle....
ne sous-estimez pas ce petit dac,c'est une merveille de musicalité !!!!
Daniel P.
Utilisé pour le secteur
C'est vraiment du très bon câble, tout est mieux, je vais l'essayer pour les enceintes.
Daniel P.
NEOTECH NC-01675RH Banana Plugs Rhodium Plated OFC Copper Cryo Treatment Ø8mm (Set x4) These Neotech NC-01675RH banana plugs feature excellent design quality and are ideal for creating high-performance HiFi speaker cables. The contacts are made of Rhodium-plated...
Conception à revoir
Je suis déçu, pas par le son mais par le fait que, s'il y a bien deux vis pour maintenir le câble, une seule est fonctionnelle, une courte si votre câble est épais, une longue si le câble est fin, mais pas les deux, pour le prix j'aurais aimé avoir des vis supplémentaires. Et puis avec des Furutech, je peux bloquer les fiches d'une seule main, ce qui est pratique lorsque l'ampli est lourd et un peu inaccessible par l'arrière, alors qu'avec ces Neotech il faut les deux mains pour un bon blocage.
Remy M.
Un câble de toute confiance
Je recherchais un prolongateur Jack 6,35mm de 2,5m, ce qui est curieusement peu fréquent.
Un câble est un support passif qui transmet un signal électrique. Il ne le modifie pas si ses composants sont de qualité, sans jeu dans le connecteur, sans faux contact, sans interférence, sans distorsion.
Sinon, le son de vos enceintes ou de votre casque sera altéré, mais il ne sera en aucun cas amélioré. Toutes les mesures physiques et les tests en double aveugle le démontrent.
Mogami et Neutrick sont des références incontestées dans leur domaine et le montage a été très bien fait. Le résultat est parfait et ce câble durera certainement plus longtemps que moi.
Eric K.
câble RCA
Bonne qualité mais un peu dur à enficher (il faut desserrer le connecteur délicatement !). Merci: bon rapport qualité/prix.
Eric K.
filtre Heimdall
Installé sur des sources : très efficace. Un peu "léger" par rapport à d'autres produits (?...)
Eric K.
filtre secteur
Très efficace, merci
Eric K.
DYNAVOX 2-Way Speakers 40W 92dB 4-8Ω 50Hz-20kHz (Pair) This pair of low-cost 2-way trapezoidal speakers offer excellent value for money and are ideal for use in small rooms or bedrooms. Each speaker is equipped with a 130mm...
enceintes compactes
très correctes pour ce prix. Merci audiophonics !
Eric K.
FOSI AUDIO T3 Amplificateur à Tubes Class AB 2x 6F2 Bluetooth 5.0 2x50W 4 Ohm The Fosi Audio T3 is a small tube amplifier allowing to enjoy the sound signature of this round and warm type of amplification at a low price. It is thus equipped with two 6F2...
ampli 50W
Très bon son/appareil compact.
Patrick C.
DAC Topping DX1 suite ....
Essais avec alim linéaire et alimentation batterie (avec un câble USB en "Y") concluants : l'amélioration sur la dynamique dans le grave et l'aération en vaut le coup.
Ça m'énerve qu'il soit bon !
En attendant la réparation de mon top ampli classe A haut de gamme, il me fallait un truc pas cher pour patienter.
J'ai écouté des PURIFI et autres "classe D" qui ne m'ont pas du tout plu. Froid et plat a mon gout.
Bien, je sors le truc tout léger de sa boîte, c'est joli. Je branche. Je lis le mode d'emploi (nécessaire) et je teste.
Sur l'option SDB, effet "loudness" comme j'aime le son, je suis très énervé de m'avouer que le son est la.
La scène est plus petite qu'avec mon ampli habituel. Je lui ai trouve quand même un défaut. Na !
Pour le reste, c'est le premier classe D qui me séduise en plus du prix ridiculement bas (20 fois moins que mon ancien ampli).
Je recommande vivement. Même aux audiophiles.
Jusqu'à maintenant, que du bon!
Première bonne surprise: l'ampli non dispo avec délai de 2-4 semaines. Je commande et je le reçois 4 jours plus tard. Merci @audiophonics
2ème surprise (qui ne devrait pas en être une): le son est superbe. Je reconnais cependant l'improbabilité de mon installation: en remplacement de 2 blocs mono flying mole, l'ampli est connecté à un sélecteur de sources audiophonics partagée entre une interface usb esi gigaport ex, la platine dvd, la télé et un player hidizs ap80 pour la réception bluetooth , et à mes antiques Jamo e610 pour les sorties. Quelques essais en bluetooth, puis en filaire avec une playlist sur le pc et enfin la nvidia shield. Sans conteste ni prétention audiophile de ma part, cet ampli délivre un son pêchu, détaillé riche en aiguës et basses... Boitier massif que je loge dans une case de mon meuble TV ikea, sans chauffe apparente.
Mon impression est donc plus que positive . A voir sur la longueur, mais j'ai confiance.
Merci encore pour cet appareil!
Giovanni G.
neutral, armonic and rich sound cable
this is a really good, wonderful cable.. it's outstanding considering it's price. i think it's at the same level of furutech occ cable at 1/3 the price.
the only cons it's about the internal conductor that are stiff, so it can be difficult to terminate (i have done a good job with viborg vr109g)
Srboljub S.
Good
Sound is great, incisive yet well balanced and with natural timbre. It's punchy and dynamic too.
The only reason I'm taking a star from it is that plastic build and parts fit could be better for this price. Viborg has much better build for one third of the price, but can't compre sonically to this Furutech.
Srboljub S.
Fantastic
These Furutech RCAs have very clean and energetic sound, with balanced tonality.
Compared to WBT next gen silver ones... These are less bright but more full-bodied and more punchy. I think these are simply more musical and prefer them to very open but slightly brittle sounding WBT.
Build quality is top notch and it's very easy to work with.
Srboljub S.
Awesome Socket
I have tested this socket against few others and can say it's worth every penny and then some.
Sound with it is precise and 3D, but very natural and not too sharp or too bright at all.
Just needs 300h to break in properly, it will sound nasty at moments before that happens.
Srboljub S.
Great buy
I used these RCA sockets in my tube DAC. Their quality is fantastic and since I haven't compared them to other sockets directly... The overall sound of a DAC is top notch.
Guillaume F.
DAYTON AUDIO DSA135-PR Passive Radiator 27.9 Hz Ø13cm A well-built passive radiator with aluminum diaphragm, designed to fit most medium-format (13cm) loudspeaker modernization/repair projects. It boasts a high excursion of 8mm,...
DSA135-PR
Petit radiateur passif de bonne facture.
L'aspect de la membrane en aluminium est du plus bel effet sur un caisson noir mat.
Couplé au bon haut parleur actif, ce haut parleur passif descendra relativement bas (dans les graves) compte tenu de ses dimensions. Idéal pour la fabrication de caisson de basses de très petite taille.
Guillaume F.
Bornier Atohm
Produit simple et efficace. Bonne finition pour la pièce plastique ainsi que les pièces métalliques. Aucun problème pour emmancher les fiches banane.
Maurizio B.
Extraordinary
I used to be a pioneer in the high-end computer based reproduction back a t the time when the problem was to have a bit perfect chain (yes, it was a long time ago). I now sold my trusted Weiss DAC202 and introduced the D90SE. The result is astounding. The transparency, the details and the musicality are simply great. If that was not enough, the price makes buying this DAC a no brainer.
Maurizio B.
It does what it promises
A simple device that does what it promises. In my case, it allowed me to turn on and off my Projector by adding a couple of smart sockets and monitor the load interrupted by this switch.
Daniel P.
Mauvaise connection.
N'entre pas bien dans une embase Furutech, ni dans une embase ampli d'ailleurs, le connecteur VF502 est meilleur, la matière n'est pas la même.
Rob L.
Great Product And Service
The product is top-notch, both in build quality (with a very unassuming, but attractive, industrial design) and in the excellence of its sound reproduction across the audio spectrum. Plenty of output power for digital sources, but when amplifying the signal from my phono stage, there is not a lot of headroom. That could be the fault of the phono stage, though. Anyhow, an excellent product. I am very happy with it, and will have it in my system for a very long time. I don't think it could be replaced, actually. Great value. The reps who looked after my order were very accommodating, as there were a number of complications due to my not having a phone. They provided me with some effective workarounds. Very enviable patience on their part, too. Merci beaucoup, Audiophonics!
Patrice L.
Une liaison XLR enfin réellement équilibrée.
Côté source :
1 fil bleu + tresse sur le pôle 1(masse) de la fiche xlr.
1 fil bleu sur le pôle 3 (-) de la fiche.
1 fil blanc sur le pôle 2 (+) de la fiche.
Le second fil blanc est coupé au ras de la tresse.
Côté ampli :
Pôle 1 le fil bleu sans tresse.
Pôle 2 et 3 avec les fils correspondants .
Utiliser un multimètre calé sur test sonore de continuité afin de repérer les fils à leurs extrémités du cable ( notamment les fils blancs AVANT d'un couper un ).
Monté avec des fiches Neutrik plaquées argent, vous obtenez un cable xlr dont les trois pôles sont équipés de fils identiques , comme le cable Pangea xlr, mais ..... à un tout autre tarif.
Le résultat sonore est juste ... bluffant .
Un dernier conseil: Tester après montage, vos fiches mâle et femelle au multimètre ( calé sur test de continuité Bip ) , pin 1 mâle sur pin 1 femelle , etc.. afin de confirmer la bonne correspondance des cables ( pas de plantage de couleur ).
Frederic H.
Je les utilise en remplacement de chimiques sur filtres d'enceintes
avec de très bon résultat
Tolérances très serrées , comme toujours chez Jantzen
Gilles G.
EXCELLENTE PRISE / alternative à la FI50ncf
J'ai acheté plusieurs de ces prises en remplacement de FI50ncf rhodium, ces dernières faisaient monter mon système, c'était fatiguant et je ne prenais plus de plaisir. Une par une j'ai remplacé les fi50 par des fi 46, même dynamique, ouverture, chaleur, j'ai retrouvé enfin du plaisir à l'écoute. Je recommande chaudement.
David j.
Connectique de très bonne qualité de fabrication. Montage des câbles HP facilité par le système de vissage. On a à faire a du solide. Idéal pour monter des jumpers de bon niveau.
David j.
Connectique de très bonne qualité de fabrication. Montage des câbles HP facilité par le système de vissage. Les embouts de la fiche peuvent s'écarter ce qui permet une stabilité optimale du contact avec les bornes HP.
David j.
OYAIDE TUNAMI TERZO RR RCA Interconnect Cable 1m (Pair) This high quality modulation cable is assembled with the most famous Focus 1 connectors and a 102SSC cable, a top of the line model from Oyaide. This cable is presented to us...
Très bon câble de modulation
Ce câble est très cohérent sur l'ensemble des registres, donne de la définition et procure beaucoup de naturel à l'écoute. Les variations dynamiques sont très bien rendues mais sans exagération. Belles image et profondeur également. Il sonne très légèrement mat.
David j.
Je recherchais un préampli aux fonctionnalités simples (volume et sélecteur de source point barre), neutre, musical, de (très) bonne qualité de fabrication, à un prix très accessible pour driver un ampli DIY LFA-50 Optim-A dont je viens de faire l'acquisition. Ce préampli remplit parfaitement ce cahier des charges.
Ce préampli, preuve de sa neutralité, est très sensible aux câbles de modulation utilisés. en possédant plusieurs non utilisés, je me suis amusé à faire différents essais : les différences sont clairement audibles (couleur, définition, équilibre général, largeur et profondeur de la scène sonore).
J'ai donc fait le choix de lui associer des câbles de modulation et d'alimentation de qualité. En entrée du préampli j'utilise un câble argent de chez Audiocadabra (relié à un dac Gustard 20H) et en sortie du préampli un câble OYAIDE TUNAMI TERZO RR (vendu sur ce site). Pour l'alimentation, je n'ai pas hésité également à lui associé un câble FURUTECH The Empire E (également vendu sur ce site).
Les résultats à l'écoute dépassent largement mes attentes. Le rapport / qualité de ce préampli est imbattable. Il mérite des câbles de qualité.
Merci à Audiophonics pour la qualité des produits proposés et à l'efficacité et gentillesse de son équipe.
Giovanni-Mattia P.
MINIDSP UMIK-2 Low Noise Omnidirectional Measuring Microphone USB XMOS ASIO 32bit 192kHz The UMIK-2 is the second generation MiniDSP omnidirectional low-noise measuring microphone. It takes advantage of everything that made the first version, the UMIK-1, so...
Excellent product, easy setup, accurate results
Perfect service by Audiphonics, excellent measurment microphone, easily set up for working with Room EQ Wizard on Windows via ASIO driver. No problem in obtaining the individual calibration files from MiniDSP. All in all, five stars.
David L.
Symmetrizer This balancer has an unbalanced stereo RCA input and a balanced stereo XLR output. It will allow you to provide a balanced output to an audio device that does not have one
Dans l’objectif de réduire le bruit trop élevé sur un ampli XLS avec hp haute sensibilité j’ai tenté ce convertisseur pour passer en xlr. Ca marche impeccable, le signal est boosté de 8db environ permettant après réglage un bruit final bien diminué. La boite est bien construite pour le prix, pas parfaitement finie mais parait solide, et je l’ai choisie car le signal reste tres propre (cf mesures par L7audiolab). Il y a un léger bruit d’alim mais inaudible une fois en place dans le rack.
Joost B.
Gustard A26 dac
This dac with the new AKM AK4499EX chip is a real bargain. It benefits greatly from it’s linear power setup, using two big toroidal transformers for digital and analogue stages. I came from a RME ADI2 FS dac, this is a big step up. Wider soundstage, more detail, more natural sounding instruments. Also terrific experience with Audiophonics again, fast delivery, good packaging.
Eric J.
XDUOO MT-605 Tube Amplifier 12AU7 TPA3116 2x30W 4 Ohm The MT-605 from xDuoo is a small and affordable amplifier, combining the performance of a Class D with the musicality of a tube system. Its amplifier stage is indeed based on a...
Bon ampli type lampe, sans réglages, puissant
Sonne assez bien, mais iI n'a pas la dynamique et la précision des amplis transistor, dans les basses, la rythmique.
Il lui manque les réglages basse, aigu. Il donne un son assez clair, vivant, plutôt puissant. Pour moi, sa puissance de 2*30W, équivaut environ à la puissance d'un mini ampli class D de 2*100W. Mais les basses étant moins affirmées, les mediums sont les plus sonores.
Un autre ampli lampe avec réglages, et le bluetooth en ferait un idéal par rapport à celui-ci.
Eric J.
SMSL DA-6 Class D Amplifier Infineon 2x70W 4 Ohm Black The SMSL DA-6 is a small, practical, high-performance and affordable Class D amplifier based on an Infineon amplifier chip offering high efficiency and capable of developing...
Pas aimé le son
Son aseptisé. Il est peu puissant, mais il y a les réglages basses, aigus, brillance, suround...qui donne de l'intensité sonore. (branché sur des hauts parleurs de 10cm, eltax monitor I, 87db)
A part la télécommande pratique, et le petit boitier bien fait, des connecteurs correctes, l'écran numérique, il est pas très utile. Pas de bluetooth.
Il y a mieux sur ce site, pour la richesse sonore.
Eric J.
Fonctionnel
Pour le prix, un ampli peu puissant, avec réglage basses aigu, et caisson de basse, du bluetooth. Le son est agréable, réaliste.
Par contre, l'alimentation est abscente, 22€ à ajouter. La puissance 2*50W, ça va pour des hauts parleurs de 10cm, mais pas plus. Il a pas de réserve. Je n'ai pas utilsé de caisson de basse. Les connections de câbles sont minuscules et rapprochées.
Pour moi, idéal comme ampli de dépannage, de test ou pour donner un fond musical et la radio.
Claude G.
Un tissu acoustique de très bonne qualité
Le tissu acoustique Jantzen Audio possède l'avantage d'offrir un excellent rapport qualité/prix : son aspect visuel ainsi que les qualités de son tissage ne laissent aucun doute sur sa vocation à protéger efficacement les haut-parleurs de mes enceintes colonnes, tout en étant totalement transparent à leurs émissions sonores.
Julien R.
Câble de bonne facture, très bon produit.
Marino M.
Qualité
Câble de bonne facture son plus aéré par rapport à des RCA !
