Marc S.
Ce Bliss est incroyable en tant que préamplificateur classA HDG. Je l'utilise avec le DAC Holo Sring3 L2 et pour la...
Johan v.
Good after software update
Not bought here for practical reasons it would not read anything after track 31 and after a helpful email from Shanling and a...
Johan v.
My favorite hookup wire
Strips easely soldering well heat resistant great to work with
Customers reviews - There are 19589 reviews.
Jérôme L.
Du pur bonheur
Novice dans ce genre de matériel, je redécouvre ma musique.
Mon matériel :
- un raspdac mini avec la carte isabre ES9038
- un ampli XDUOO TA-20, ampli qui emmène largement la puissance demandé par le casque.
C'est vraiment un autre monde, tout est clair et défini, l'impression d'avoir les chanteurs à coté de sois.
Le casque est confortable et semble assez costaud pour écouter sans se fatiguer pendant de bonnes heures.
Seul hic, la longueur du cable. Le son est tellement bon qu'on a envie de se lever et de se mettre à bouger mais le cable vous stop vite!
Ciaran K.
i2s dac for raspberry pi
I had an old unused raspberry pi (version 1b!) and wanted to create a squeezebox client. This needed a few small changes to the board - soldering on a header - but after that was a simple matter of following the instructions to connect the correct pins. The sound is excellent! Also very impressed with Audiophonics service - there was a small part missing in the order which was very kindly posted out to me - merci!
stoica r.
Very very nice
It is an amp in class D that is worth all the money and some. The finish from audiophonics is very very nice. But is not going to work for me with the gain on in any position. With sparkon or not is not worth the money. When you desble the gain and put xlr with 4v to 10v output in class A si wonderful. On my opinion is better than jeff rolland. 10+++ for the build -1 for output integration
Marcus K.
SMSL VMV A1 Amplifier Class A MOSFET PGA2311 2x15W 4 Ohm The SMSL A1 is a compact but very powerful Class A amplifier, offering an excellent sound reproduction, both round, musical and precise. This amplifier provides a beautiful...
Very enjoyable amplifier
Not a joke. I bought this because of good reviews and because I have efficient speakers. Sort of an experiment. I owned many amps in the past, some costing ten or even twenty times more. But this thing is a precious little amp. I am using it with an external preamp, so keep that in mind. The temperature does not exceed 43 degrees. In my system, this really is a winner.
Emmanuel v.
Volume de sortie stéréo trop faible
J'espère qu'il s'agit juste d'un problème de configuration mais j'ai une atténuation de 6dB de la sortie stéréo analogique en comparaison avec mon récepteur Bluetooth SMSL B1. La réponse du SAV de iEAST est que le signal de sortie est de 1V, comme la prise casque d'un iPhone, alors que si je me trompe, le standard de sortie de ligne audio est de 2V. Cela expliquerait les 6dB de différence mesurés sur mon ampli Yamaha. Il faut donc tourner le bouton de volume pour compenser, ce qui n'est vraiment pas très commode, outre la diminution du rapport signal bruit que cela entraîne. Je m'étonne que personne n'ai mentionné ce problème.
Christopher G.
cpg
I was always sceptical if "better" digital cables made a difference, surely bits are bits?
However this cable is definitely better than my previous ca. 30€ digital cable. Well worth a try.
Willy M.
Ravi de mon achat!
Merci à Audiophonics pour le sérieux!
Ce petit DAC correspond tout à fait à mes attentes, compact, beau son, look bien sympa, facile à installer!
En ce qui me concerne et à ce tarif rien à redire!
jb b.
WONDOM PS-BC12112 BCPB3 Battery Management System Module 5x Lithium 18650 The Wondom BCPB3 is a battery management and protection module, taking advantage of the performance and reliability of the previous models while offering more battery...
très efficace
entièrement satisfait de ce kit qui gère bien la charge des batteries . on peut recharger en branchant un courant de 5 à 24v , y compris par panneau solaire et il se débrouille donc très pratique, le seul bémol c'est qu'il n'y a pas de bouton 'off' , donc le système tourne en permanence, pour çà prévoir des interrupteurs sur les sytèmes alimentés .
ce module est livré avec tout ses cables donc inutile de commander le pack de cable en option (PS-BC12311)
jb b.
WONDOM PS-BC12311 Package Functional cables for module BCPB3 / BCPB4 / BCPB6 This cable kit contains all the necessary connectivity to use all the features of your Wondom battery managers.
vérifier l'utilité de ce kit avant de commander
les cartes de gestions de charge de batteries wondom sont livrées avec ce kit de cable donc inutile de commander ce kit si vous avez commandé un WONDOM PS-BC12112
Eric v.
qualité moyenne. Vis de serrage relativement médiocre.
Si non envoi rapide et serieux comme toujours chez AUDIOPHONICS
Arturas J.
puikus
Excellent quality, fully meets your description
Arturas J.
normal
the connection does not match the description. I had to get tired of connecting the 2.5 power cable. tired and assembled to connect the contact holds good.
Christopher G.
cpg
as one of the previous reviewers said, this is a very good transport. The only disadvantage is you cannot select the track number
Narcisse a.
DAYTON AUDIO UM10-22 Ultimax DVC Speaker Driver Subwoofer 500W 2x2 Ohm 85dB 25Hz - 1500Hz Ø25cm Dayton Audio's Ultimax series DVC subwoofers are specially designed to move energy and create clean, articulate, tense fast bass. Enjoy the best value for money available !...
parfait si ce n'était le prix
Un sub qui en jette c'est sûr! aussi bien au propre qu'au figuré. Il est lourd, sérieusement construit et même beau pour être honnête avec son HP sans cache noyau et sa membrane épaisse. Comme tout bon HP SQ il est malheureusement lourd et nécessite un ampli qui a du courant. Je l'alimente avec un vieux infinity numérique bien droit, dans un caisson clos d'environ 25L il fait des merveilles avec une belle descente et une articulation propre et détaillée agrémenté d'une belle ampleur. Il sera parfait aussi bien pour restituer les basses profondes d'un James Blake que les kicks énervés et frénétiques d'un bloc party ou d'un blink 182. Le prix est à la hauteur de la prestation mais pour le non initiés qui n'y verra que du feu, un dayton de la gamme LS fera déjà un excellent travail.
transparence et neutralité
Un excellent équilibre , une grande netteté sans ce côté dur que peut apporter l'écoute en numérique . Tout est là . Recommandable dans cette gamme de prix.
Davide C.
mod gain
Good module buffer.
Hi, i bought old version (no switch) preamp many years ago. I don't remember the modify to reduce the gain. Can you help me? Thanks.
Hi,
It's silk printed on the board.
You can change the buffer gain using the DIP switch.
Frédéric L.
MUNDORF 2.8G Insulated Female Blade Terminal Gold Plated 2.8mm 0.5-1.5mm² Red (x10) These female blade connectors allow a simple and fast connection/disconnection while ensuring excellent contact. The contacts of these connectors are gold...
Pas d’alliage cuivre
Cosse de très bonne qualité, j’ai voulu vérifier en limant la cosse
couleur laiton et apparu et non du cuivre.
Quentin T.
Un préampli vraiment ?
Un bon produit pour le prix, mais je ne pense pas qu'on puisse le qualifier de préamplificateur, car il faut pousser le volume au maximum pour retrouver un volume normal.
En tant que contrôleur de volume/sélecteur de source/récepteur BT, en revanche, il fait un très bon job.
Gregory O.
Viborg
Top class sound and better than my way more costly one from F-H
ROSE HIFI RS250 Lecteur Réseau Audio DAC ES9038Q2M 32bit 768kHz A true audiophile network player, the Rose Audio RS250 combines versatility with high performance, thanks to its high-end DAC and optimized power supply stage. A jewel of design...
Un appareil pour geek patients aux petits doigts.
Look 10/10
Son 10/10
!!! Utilisation 0/10 !!! Une horreur.
Hifirose revendu pour cause d'ergonomie "usine à gaz". Tout est ici :
https://community.roseaudio.kr/t/why-i-sold-my-hifirose-pourquoi-jai-revendu-mon-hifirose/4306
Philippe F.
NEOTECH NEI-1001 II Interconnect Cable Balanced UP-OCC Silver 2x1.17mm² Triple Shielding The Neotech NEI-1001 II is a balanced modulation cable made of 2 Silver UP-OCC conductors with a cross section of 1.17mm². Each conductor is composed of 4 strands of...
Excellent en RCA
Câbles associés aux fiches RCA WBT-0152 Ag au diamètre adapté. 2 fils soudés sur points chauds, le 3ème sur point froid + blindage à sur fiche source.
Résultat excellent. Grande transparence et dynamique, et surtout une scène sonore étendue. L’écoute n’est pas fatiguante. Hautement conseillé !
Laurent A.
DAYTON AUDIO DS90-8 Design Series Speaker Driver Full Range 20W 8 Ohm 84dB 80Hz - 13kHz Ø8cm This 80mm paper-treated membrane driver has a bandwidth from 80Hz to 13000hz. It is ideal for the design of speakers without passive filters with a linear response in two litres...
De petits montres..!
J'ai installé ces petits haut parleurs dans de petites enceintes labyrinthe Iwistao.
Raccordées à un petit ampli FX audio fx252a et un petit pré ampli FX tube-03, le tout, raccordé à mon téléphone (chambre à coucher). Le son est à peine croyable !
Pour le moment, ils sont utilisés en large bande et ça fait déjà bien le taf. Je vais ensuite rajouter un second ampli, un petit filtre actif et deux tweeters histoire d'élargir la bande.
Sinon, seuls ils sont quand même fabuleux pour le prix..
(Les labyrinthes Iwistao y sont aussi pour bcp pour la réponse dans les graves)
Yves A.
USB Black Cable USB-C Male TO USB-C Male 3.1 12cm This high-quality male / male C-type cable allows you to connect any tablet or smartphone with a USB type-C or any type of C-type input.
USB C vers USB C court
Rapide et fiable Bravo ....encore Merci
Impressionnant
Ce câble est une révélation, car il n’a pas démérité en le comparant à des ténors de la catégorie. Associé à des Viborg plaquées or/argent il a réussi à détrôner mon câble fétiche à plus de 1000€ dont je tairais le nom.
Après une bonne cinquantaine d’heures de chauffe, il est d’une cohérence et d’un équilibre à faire pâlir, voire trembler les grandes marques prestigieuses. Les timbres sont de toutes beautés avec un médium émouvant.
La dynamique frôle la perfection avec un son riche et maîtrisé. Quant aux aiguës, ils filent sans s’arrêter dans un soyeux envoûtant.
Bref c’est que du bonheur
Merci audiophonics pour ces pépites au RQP imbattable
Matos : ampli et cd Roksan K2, HP Focal Chorus V 826 re câblée athom mini
Mogami w3103 pour les HP
ET Mogami w3082( c’est une tuerie) pour la liaison cd/ampli.
Jochen R.
SMSL TABEBUIA WAVECOR Bookshelf Speakers 2 Way 100W 4Ω 88dB 56Hz-32kHz Black (Pair) The Tabebuia are the first loudspeakers offered by the acclaimed and recognized SMSL brand. These compact bookshelf models include a tweeter and a woofer from Wavecor, a company...
High quality desktop speakers
I've tried some rather different passive loudspeakers in a near-field desktop setup.,from e.g. Wharfedale, Dali, JBL, Tannoy and others. These were the only ones which did the disappearing act without sounding thin. And the quality of the parts and the finish is top notch. In the end I had to use them with a classic NAD amp because the ProJect Stereo Box S2 was simply not up to the task (annoying hiss). Highly recommended!
Fabien F.
ARYLIC UP2STREAM AMP 2.1 Amplifier Module 2.1 WiFi Bluetooth 5.0 Tone Control 2x50W + 100W The Arylic Up2Stream Amp 2.1 is a 2.1 channel amplifier with full wireless connectivity. It will allow you to use a subwoofer while enjoying the convenience of audio streaming....
Super pour une enceinte 3 voies actives
Je l'ai utilisé pour fabriquer une enceinte active grâce au DSP intégré qui permet de configurer des filtres indépendants pour chaque canal (tweeter, medium, Sub). Détails in English ICI:
https://www.diyaudio.com/community/threads/3-ways-active-speakers-boombox-bluetooth-wifi-with-arylic-amp-2-1.384549/#post-6979277
ATOHM WT-LMB Banana Plugs Gold Plated 24K Ø5mm (Pair) High-quality male banana plugs (suitable for ZEF MAX, ZEF SPEAKER and ZEF MINI).
Materiel de qualité
Matériel de qualité, mais serrage moyen...
Fastidieux à mettre et à enlever
Dylan C.
Ceci n'est pas un préampli !
Cet appareil n'est pas un préampli mais un atténuateur et un sélecteur de source.
Les 4 entrées ne sont pas dédiée à une fonction, elles auraient été nommé 1 - 2 - 3 - 4 que ça n'aurait rien changer.
Je n'arrive pas à faire fonctionner le bluetooth ... peut-être que je m'y prend mal.
Le PGA2310 est bien un atténuateur, pas de doute sur ce point et il est intégré comme tel dans l'appareil.
Par contre, il fait parfaitement bien son travail avec transparence et neutralité (en 2022 ça serait quand même un comble).
Il faudrait peut-être avoir un petit préamplificateur en amont pour certain appareil qui seront branchés dessus. Un petit gain ajustable ne serait pas de trop à mon avis.
Mais ici, Audiophonics n'est que revendeur et pas concepteur.
M. B.
Excelent
VERY precise amplifier. Excelent. Noise is zero.
The blue leds (2) on the preamp board are so bright they make bars of blue on my ceiling thru the ventilation slits. Could do with a little less. I'll modify their resistors.
Trigger option on the outside would be nice.
Thanx for this fantastic amplifier !
M. B.
Ok. Has drawbacks.
+ Audio quality.
+ Quality built.
+ Swappable opamps.
- Device gets rather hot (after a while), on the outside, no ventilation openings, inside temperature probably very high. Should be taken in account when stacking devices.
- Remote volume(-) is sometimes interpreted as volume(+) on the edge of its range (~5m).
- Remote control "Next" of my Onkyo C-S5VL SACD is also interpreted as "Next audio channel" by the device. No other matching codes.
- Volume control motor makes a lot of noise. A full rotation to zero is performed at startup, even when it is at zero already. (Nnngggjjj...)
- Volume is reset at absolute zero at startup. Requires getting used to.
- Volume knob has no visible position-indication.
- Documentation ?
jean-françois v.
IAN CANADA RECLOCKPI Double I2S / DSD Reclocker Low Noise / Low Jitter Ian Canada's ReClockPi is a high quality, low noise, low jitter dual reclocker module. It is designed to work with the FifoPi or any other digital audio device in synchronous...
Excellent reclock avec FIFO PI Q3
Très bon upgrade que ce recloker en plus du FIFO PI Q3 de Ian canada. Pour ma part c'est ma dernière modif après avoir installé le FIFO PI Q3 ainsi que des horloges acusillicon et des AOP de chez Sparkos Labs en sortie de mon filtre actif Najda, voir mes avis à ce sujet. Ce que je peux dire c'est que je ne pensais pas avoir un gain réel et bien si, il est certes plus faible que les modifs précédentes mais tout de même il y a un gap. Le plus frappant c'est la sensation de gagner en émotion comme si on retrouvais la chaleur de l'analogique. TOut est plus juste du grave à l'aigu mais surtout mes Altec 414 ont un grave très tendu parfaitement juste comme si j'avais des 416. A achetter lorsque l'on a déjà fait pas mal de modif et que l'on souhaite encore gagné un peu.
B B.
reçu en 48h, bravo Audiophonics et merci à David pour les conseils. Je l'ai acheté pour ma chambre avec des enceinte Dali Oberon on wall. Je l'ai aussi testé avec mes enceintes Iroise 500 et ampli Marantz PM17. il pilote bien les cabasse mais je préfère le son du marantz qui me semble plus naturel. Il est aussi dix fois plus cher... En revanche sur les Dali c'est très bien malgré leur faible rendement, on ne fait pas la différence avec le marantz et il vaut des ampli 2 ou 3 fois plus chers. Le son est très clair, bien détaillé, graves et aigus bien équilibrés. Avec le BT ça permet d'avoir un ampli tout intégré avec un excellent rapport qualité prix !
DAVID B.
M David B - Audiophile Scientifique
J'ai remplacé mon ampli ART SLA2 (en class AB) par HPA-S400ET pour alimenter mes enceintes Magnepan 3.7i.
L'échange avec le service technique très cordial, on sent clairement la maitrise technique et la très bonne connaissance du produit (c’est pas un service commercial délocalisé essayant de faire de la figuration).
Commande passée le vendredi 11 mars 2022 à 11h00, Livré le lundi 14 mars 2022.L'emballage - double semble être à toute épreuve !
La différence de qualité du rendu sonore est très nette. Les aigus sont bcp plus clair et les basses ne bavent pas ! La différence se perçoit même dans des pièces éloignées de la maison.
Les finitions de l'appareil sont impeccables et renforcent utilement l'aspect qualitatif !
Je tenterai sans doute plus tard de tester avec d'autres OP comme les OPA1612 pour voir…
Jean-Michel Q.
Une excellente affaire.
J’ai déjà deux casques hifiman (he400i et he1000v2) j’ai acheté cet édition XS en complément pour emporter en déplacement et je suis très favorablement impressionné. Une performance digne de ses grands frères et un prix qui écrase toute la concurrence. Aucune hésitation à avoir…
Matthias J.
Perfect unit - nothing more, nothing less
This is a totally boring device. Deadly quiet, lots of power, absolutely neutral, well built. It makes nothing wrong and you can hear exactly the sound of your source and your speakers. It easily controls even an Apogee Duetta Reference or a Cabasse Bora unconstrained and relaxed. And if your system sounds bad with the MPA-S250NC don’t blame this amplifier but look for the reason elsewhere. Highly recommended budget amp.
Yvon C.
J'ai commandé ce produit me basant juste sur sa bonne réputation. Les premiers résultats d'écoute (seulement 10 h 00 de rodage !) dépassent toutes me attentes. Extrêmement précis tout en étant naturel et très musical (fluidité et legato). Bref ! quoi de mieux à ce prix et bien au delà?
Francois g.
super mini Dac
Un très bon dac , la connectique est limitée mais l'écoute est superbe et c'est bluffant pour un petit truc au rqp imbattable. Voire les revues du Web pour les détails.
Francois g.
très bon straps
Remplacement de straps basique et le résultat se fait vraiment entendre, c'est plus équilibré , moins fatiguant , bref c'est mieux et la différence est sensible. Content de mon achat !
Francois g.
très bons straps
En remplacement de straps ohelbach basics, le remplacement est audible tout de suite et bien meilleur. Plus doux , mais surtout plus équilibrés. Mes enceintes
Francesco R.
le péché n'est pas identique
Ce ne sont pas les premiers que j'achète, mais les capuchons rouges sont toujours 2/3 mm plus courts que les blancs et de fabrication différente
Tres bon cables a prix contenu
Satisfait de ces câbles et surtout le système de verrouillage simple et rapide.
Enfin des câbles qui ne peuvent se différencier aux branchements.
À conseiller vivement...
Tres bon DAC
Je l'utilise essantellement entre un lecteur preampli ,un CD servant de transport et un ampli MPA-S250NC Audiophonic.
Le son est légèrement analogique et tout en finesse.
Je pense que le son va encore s'améliorer dans quelques jours.
Merci à David pour ses conseils.
Envoi rapide, mais ceci devient normal chez Audiophonics et très apprécié.
naturel avant tout
Une sensation de réalité de façon naturel . Plaira peut être plus aux mélomanes qu'aux "hifiste". Ma prise est connectée à une prise murale oyaide or /paladium , elle est le point de départ de tout mon système hifi. Elle remplace une fiche furutech rhodium qui peut paraitre plus dynamique mais à long terme n'affiche pas cette sensation d'équilibre naturel qui s'approche du concert . Le reste n'est qu'une affaire de goût.
Neutralité sans défaut
2 câbles connectés entre une alimentation séparée et un ampli double mono . Une neutralité et une rigueur de transcription parfaites. Une forme d'évidence sans artifice transparait . Un câble qui ne pardonnera pas les défauts de certains systèmes hifi . Prix légèrement élevé à mon goût d’où 4 étoiles . Reste cependant un très bon choix.
Dominique P.
Mais si !
Très sceptique sur l'influence des câbles et encore plus de ce genre de câble (numérique), mais intrigué par tous ces avis, je me suis fait ce petit cadeau. Pour voir...
Alors, je ne dirai pas comme beaucoup que les différences sont immédiates, énormes, sautant aux oreilles, avec ceci en plus et cela en moins, bref, les excès de langage audiophilesques.
En effet, je n'ai pas vraiment ressenti de différences dans l'immédiat. Mais je l'ai laissé car pour moi, c'est sur de longues écoutes sur plusieurs jours, sur divers enregistrements que je me prononce en général sur les différences entre matériels.
Eh bien, après quelques jours, je dois dire en effet que j'éprouve un plus. Plus de naturel ? Difficile à dire mais plus de plaisir en fait. Comme d'habitude et dans l'absolu, on ne change pas de chaîne bien sûr mais on apprécie, comme un raffinement supplémentaire. Surprenant !
J'ajoute que le câble est très bien fabriqué et "beau" (si ce qualificatif peut s'appliquer à un câble :-))
Dominique P.
ALLO FLEX Micro USB to USB-A Cable 90 Ohm for USBridge Signature / Revolution DAC 15cm This Allo Flex cable has been specially designed to connect the Allo USBridge to the Allo Revolution DAC. It has a controlled impedance from 90Ω, specific to these devices.
Très bon !
J'ai oublié de préciser que l'impédance de 90 ohms correspond à l'impédance théoriquement idéale non seulement pour les appareils annoncés mais pour tous les appareils (streamers / DACS) USB en fait. Impédance qui est rarement mentionnée par les constructeurs et qui pourtant fait la différence.
Dominique P.
Très bon si...
Vous cherchez un câble USB de qualité, le plus court possible et non blindé ? ...Et bon marché qui plus est ?
Celui-ci est fait pour vous si sa taille vous convient. ATTENTION, les 15 cm indiqués ne correspondent pas à la partie droite du câble (ce que je croyais) qui fait une petite dizaine de cms.
C'est ce qui me l'avait fait remiser car je ne pouvais pas l'utiliser entre mon ALLO USBridge signature et mon DAC Sanskrit 10th anniversary MKII.
Ayant changé la disposition des éléments de ma chaîne, je l'ai ressorti après plusieurs mois pour m'apercevoir qu'il... ne fonctionnait pas...!
Heureusement, Audiophonics a assuré comme toujours et après un petit échange de mails, j'ai reçu un nouveau câble, parfait celui-là. Bravo pour le SAV !
Chow s.
DSD 128
Hi, I'm using this converter too. However when connected to my Oppo 205 as a transport via I2S to my Pontus II it can obly play DSD 64 file. However when playing DSD 128 and above there is no sound. However my Pontus II led light show 1x and DSD while my Oppo 205 show DSD. Anyone facing this problem. Thanks
Richard M.
Turns on my amp perfectly
I use this to start my Rotel RB1080 from the 12v output from my Pioneer Elite LC-SX801. I was leaving my Rotel on all the time - even though it has a 12volt input, it made a funny noise and did not work. I had read on some hifi sights that this would work, so took the risk and ordered it from France. I am happy I did. It fits perfectly into my Rotel and the Rotel plug fits perfectly into it. I attached the 12v cord from my pioneer to this and Voila!!! Works perfectly and my Rotel is now shut off until the Pioneer turns on. Thank you. Worth every Euro!!
Henri F.
fantastique bloc de puissance
système d'écoute : PC windows optimisé avec fidelizer pro et process lasso, logiciel de lecture Audirvana Studio ou Hqplayer avec sortie asio avec protocole lecture réseau DIRETTA vers streamer Allo Usbridge tournant avec gentooplayer et le target DIRETTA vers dac AUDIO GD D77 en ACSS vers préampli AUDIO GD NFB1 AMP en XLR Vers le LPA - S400 ET vers colonnes TRIANGLE.
Tout d'abord oubliez tout les préjugés négatifs sur les amplis en classe D que l'ont peut lire sur différents forums francophones, sur leurs manques de musicalité, leur agressivité... Tout cela est totalement infondé, en tout cas avec les dernières générations. Ici le son est d'une transparence et précision extraordinaire. Il fait preuve d'une très grande musicalité, des basses hyper précises, bien tendues et propres, de très jolies médiums, des aigues bien présents et précis, tout cela sans aucune once d'agressivité. Il n'enlève et n'ajoute rien. il ne surjoue pas comme certains amplis de classes plus traditionnelles y compris à lampes. Non ici le son est restitué tel qu'il a été enregistré. il est d'une neutralité exemplaire. Et on ne s'ennui jamais à l'écoute contrairement à ce que l'on pourrait penser. Il permet de longues écoutes sans fatigue. Chez moi il tient la dragée haute et n'a pas à rougir face à un amplificateur intégré à lampes bien plus cher ! Autre grosse qualité est qu'il est évolutif et on peut très facilement changé d'AOP. vous avez compris que je prends énormément de plaisir avec et que pour moi j 'écarte totalement un retour sur des classes d'amplis plus traditionnels.
Merci à Audiophonics pour leurs précieux conseils et de nous proposer de tels produits à des prix défiants toutes concurrences.
