Luca C.
Panos M.
Its more my personal taste
Ludovic P.
Customers reviews - There are 19585 reviews.
Fais le job
Ideal pour le son d'un téléviseur .
Jakub P.
Very, very good DAC
Well, one year passed since I bought this DAC, and everything works perfect. There weren`t any problems with it. Sound quality is amazing, especially if the DAC is powered properly (by linear power supply). Take in consideration playing DSD files, then Audiophonics spreads its wings.
Jakub P.
CS8416 Source Selector Module 2 SPDIF Inputs to 1 I2S Output This module is an input module with a coaxial input and an optical input. It is based on a Cirrus Logic CS8416 digital audio receiver supporting sample rates up to 192kHz. The...
Not for Raspberry Pi
The quality of the product is good, that`s why I give it 5 stars, but unfortunatelly it doesn`t work with Raspberry Pi/Audiophonics ES9038Q2M. If you want to have an optical or coaxial S/PDIF input in your DIY streamer, then just buy an optical/coaxial spdif socket and connect it to spdif + ground pins (+5V for optical socket) on Audiophonics DAC. You must also take into account the necessity of adding two capacitors to avoid "reloading" effect (lags in audio via optical spdif input).
Défaut de finition
Fibre dépassant de son logement, extrémité en champignon: le chinois a oublié de polir les extrémités !!!
ça m'a d'ailleurs abîmé une prise Toslink femelle qui ne retient plus son complément mâle.
Toutefois, câble repris sans Pb.
Stéphane C.
Coup de boost
30 ans...30 ans que mes enceintes DITTON étaient équipées de câbles de qualité...basique dirons nous. Et là..quel renouveau... ! Des basses plus présentes, plus rondes, des médiums plus clairs...et un gain dynamique indéniable...même sur des formats compressés...un bonheur.
Romain L.
ARYLIC UP2STREAM AMP MONO Amplifier Board WiFi Bluetooth 5.0 60W 4 Ohm The Arylic Up2Stream AMP Mono is a small, powerful and versatile amplifier module offering advanced wireless connectivity. The amplifier stage of the module is capable of...
Ma vieille TSF s’est transformée en enceinte connectée ; tout marche nickel !!
steve B.
Tres bien pour le prix , mais ....
Je l'ai acheter pour une seule chose , mes 3 blocs amplis de puissance Nuprime STA-9 n’ayant pas de prise trigger 12v , il me fallait une multiprise de bonne qualité non filtré avec une fiche IEC pour pouvoir lui mettre le petit bloc trigger 12v de chez Audiophonics et ainsi pouvoir commander l'allumage et l'extinction de cette multiprise .
PS: le petit module Trigger 12v de chez Audiphonics n'est bien sur pas livré avec cette multiprise , il coute environ 30e sur le site d'Audiophonics.fr
L'objet et de qualité correcte malgré quelque trucs qui m'ont un peu laissé pantois .
Déjà posé sur une surface plane , elle est bancale , 1 des 4 pieds en caoutchouc est plus court sur pattes ... surement une changement de lot a la prod' .
2eme: , et ca c'est plutôt gonflé ... le câble d'alimentation du cette multiprise est en 3G0.75MM² !!! 3x0.75mm² , mais c'est une blague alors que l’intérieur est câblé en 2.5mm² ... A REMPLACER d'office svp .
Bon moi j'avais prévu le coup car il me fallait rapidement un 3G1.5mm² de 5m , j'ai donc commandé un Oehlbach 3g1.5 de 5m avec , et 2 ferrites en 9mm pour ce câble . 30e en tout . Bon j'ai pas besoin de gros gros cable j'ai que 1200w a y faire passer
3eme: j'ai ouvert l'engin , car j'avais lu plusieurs fois que certaine vis étaient mal serrer , et j'ai bien fait ! un des câble bleu sur le gros bornier de la platine était insérer que sur 2 ou 3mm ... d'ailleurs on le vois sur les photos .
De l'autre coté sur la platine , c'est un câble de terre qui dépasse ...
J'ai tout re-cablé proprement et serrer les vis correctement .
Bon en règle générale , c’était pas trop mal .
C'est un câblage en ligne , ce qui n'est pas trop hi-fi dans l’âme ... il aurait été mieux d'avoir un câblage en étoile , mais gardons a l'esprit que cette multiprises coute 122e.
Le filtrage est minimaliste , mais ça devrait suffire a enlever les grosses EMI-RFI du réseau crée par le congélo , micro-ondes et ballon chauffe eau ou lampe Halogène/Led par exemple .
J'ai également vérifié le fonctionnement du détecteur de phase , ça marche bien et c'est juste .
Bon je ne suis pas déçu par cette engin , mais j’enlève 1 étoile quand même pour ces 2 câbles partiellement enfilés dans leurs bornes et pour ce câble d'alimentation en 3G0.75 !
Merci de m'avoir lu , et merci pour votre petit vote "utile" ou non ;)
a+ , pour les photos interne , allez vois mon avis sur amazon.fr
 (16)
Remi P.
ravi
Acheté en remplacement du M8 première version (ES9018) qui m'a lâché après 5 ans de loyaux services, ce petit dac avec son alim externe SMSL P1 redonne un vrai peps et de l'aération à mon installation hifi fixe. Vraiment ravi de cet achat.
Pierre-Jean G.
Produit conforme et expédition très rapide. A conseiller
Jean-Pierre L.
PARFAIT
Excellent produit, fabrication très soignée, très facile d'utilisation, améliore sensiblement l'écoute et surtout les contacts. colis très bien protégé et parvenu dans les délais; produit correspondant tout à fait à mes attentes.
Ronan L.
Satisfait mais pas conquis
Fabrication qualitative.
Ce câble m'a permis de relier directement la cellule au prephono, il m'a fallu souder 4 petites cosses (travail d'orfèvre).
La platine (LE TALLEC) attend sa nouvelle courroie, donc je ne peux donner un avis precis, mais c'est plus délié et plus de bruit parasite... c'est déjà pas mal...
Bruno C.
Excellent câble hp
Utilisé en bi-câblage avec ampli numérique Nuforce dda100 et enceintes Mission M33, ce câble me donne entière satisfaction. La restitution sonore est riche en détails et aérée. Une impression de limpidité s'en dégage. L'on se surprend à se mettre à apprécier des albums pour lesquels l'intérêt était jusqu'ici limité.
pierre a.
tres pratique
embouts de cable tres pratiques
sertis avec la pince cela fait une terminaison de cable tres propre
je recommande
Nicola G.
Ottimo cavo l’ho sostituito per il collegamento pre/amplificatore a dei cavi Van den Hull con una grande differenza come qualità sonora e dettaglio. Ampiamente consigliati ottimo il servizio di Audiophonics.5 stelle
pierre a.
tres bon cable
j'avais besoin d'un cable de modulation assez court et celui ci fait
tres bien l'affaire
assez souple et prises de tres bonne qualité
sincerement pourquoi mettre plus cher ?
je recommande
Dominique B.
Impeccable.
Colis reçu rapidement et bien emballé, produit conforme à la description et à mes attentes. Ma chaine Philips est réparée et fonctionne comme au premier jour. Elle souffrait d'un problème de souffle qu'on entendait à faible volume.
Un sans faute de Audiophonics.
Lennart B.
Superb
So i bought this used, just wanted to post this review because this really is an amazing DAC and even at retail value it is fully worth the price. It's a bit of a shame that Audiophonics discontinued it.
I use mine connected via USB to a computer running Roon.
Outputs to a Rotel pre and power amp driving a pair of B&W CDM7 SE speakers.
I'm not really sure about the filters but i listen to a lot of slow/ambient electronic music and prefer the slow roll filter in general, it seems to make the bass roll off in a smoother fashion.
However there's one quirk with mine (maybe can be fixed with software update? If Audiophonics can chime in that'd be much appreciated).
So when i turn it on and play files from different sample rates the display will get stuck and the source/filter button doesn't work anymore so the DAC needs to be restarted.
A workaround i've found to this issue is just switching the channel back and forth back to USB again first thing after power up
So a minor annoyance which i will gladly oversee, but would be nice to get fixed.
Overall superb value for money.
Thibault K.
Utilisé sous Linux (Kubuntu) avec un Sennheiser HD650. Fonctionne parfaitement, le niveau de gain 1 est déjà largement suffisant. La qualité du son est excellente et pas le moindre souffle.
Egon B.
Discret
Je l'utilise comme DAC entre un chromecast audio connecté via toslink et un amplificateur intégré. Tous les deux sont alimentés d'électricité par la même powerbank bon-marché. Son plus détaillé et grave plus clair par rapport aux DACs du chromecast et de l'amplificateur intégré. Parfait pour écouter de la musique. Un peu trop détaillé à mon avis connecté à une télévision (que m'importe les micro sons de claquement, d'aspiration des acteurs ...).
À part le son, ce que j'apprécie beaucoup c'est que le DAC est toujours en mode standby, et s'éveille automatiquement dès qu'il reçoit un signal du Chromecast.
Michel a.
fine power module
the module perfectly meets my expectations, is easy to set up and therefore keeps exactly the value, even under load.
despite the corona problems, I quickly had the power module at home.
perfect!
Yohann S.
Amplificateur Stéréo Class D Purifi
C'est juste incroyable comment ça peut donner un son aussi puissant et aussi musical.
Il alimente mes Jenzen Illuminator DIY, en complément (provisoire) d'un DAC préamplificateur OPPO SONICA, le tout connecté en XLR SUPRA.
Beaucoup de détails, ampli neutre.
De la puissance et une attaque super franche sur le registre grave.
Le tout est super équilibré, tout est bien à sa place. Du détails, mais jamais analytique.
Dernière étape pour mon setup, je dois choisir un préamplificateur à tubes symétrique.
Qualité de fabrication et sérieux d'Audiophonics. Au top les gars franchement! MERCI
Musicalement
Yohann
Fr D.
USB-C to USB-A Cable Silver / Gold plated Copper Shielded 1m This braided USB cable has a USB-C male connector and a USB-A male connector. Each connector is 24k gold plated. Each conductor of the cable is made of silver-plated copper,...
Attention aux incompatibilités
J'ai voulu reliier mon Oppo 203 à un disque dur Samsung T 7 et cela ne fonctionne pas.
Obligé de le retourner à mes frais ce qui n'est pas normal car les risques d'incompatilités ne sont pas signalés.
Jean-François A.
fiche RCA de qualité
Très bonne prise RCA, qualitative et facile à souder. Utile pour la plupart des connections. Bon rapport qualité/prix
Jean-François A.
Câblage d'enceintes
Très bon câble, suffisant en section. Musicalité neutre, détaillée avec des basses définies et bien modulées. Pas d'agressivité, une belle assise et de belles percutions dans les aigus. Un bon rapport qualité/Prix. Je le recommande
Jean-François A.
Prise DIN avec verrouillage par bague
Prise DIN métal parfaite pour réaliser les cordons pour le matériel NAIM AUDIO, ave le verrouillage par bague des embases équipées de ce mode de blocage.
Jean Michel W.
Power Connector DIN 4 Pins for NAS Synology (Unit) This DIN 4 pins connector will allow you to create your own power cables, especially for Synology's NAS brand connectors. The connector accepts cables up to 6.4mm in diameter.
Très bon produit. Merci au tuto :-)
Maxime B.
DAVIS ACOUSTICS MIA 20 Bookshelf Speakers 2 Way 80W 88dB 55Hz-20kHz Dark Wood (Pair) The smaller Davis Acoustics model, the MIA 20s benefit from advanced technological solutions that can be found in higher range models. These small 2-way bookshelf speakers are...
Excellent investissement
Derrière un DAC U-SABRE Audiophonics et un ampli hybride Qinpu Q2, ces enceintes bibliothèque complètent un premier investissement pour transformer une vieille installation en système hi-fi clair, chaleureux. Toute la musique à redécouvrir !
Maxime B.
Pour remplacer une vieille installation d'ado, ce petit ampli offre un premier investissement surprenant ! En sortie du DAC U-SABRE Audiophonics, et avec des enceintes bibliothèques DAVIS MIA 20, la transformation du son est incroyable, notamment en clarté et en chaleur. Sa puissance est largement suffisante pour un bureau/chambre/pièce de travail.
Maxime B.
C'est le deuxième que j'achète, connectés en usb à des ordinateurs de bureau. En sortie, deux amplis hybrides Q2 et APPJ, pour de petites installations à prix raisonnable. Un test avec/sans rend clairement audible l'apport du DAC côté clarté : un voile se lève sur toutes les musiques que j'écoute (classique, jazz). Et à ce prix, il faut foncer ! Pour démarrer une première installation Hi-Fi, c'est indispensable !
Aurelio Germano T.
Alimentatore di alta qualità.
Costruzione e funzionamento impeccabili.
Indispensabile per Allo Signature + Rasp.
Aurelio Germano T.
Svolge egregiamente il suo lavoro.
In realtà le stelle dovrebbero essere 4,5....nella mia configurazione il lettore meccanico Cyrus è ancora superiore come risultato sonoro, anche se non di molto. Può dipendere da molti fattori ed anche dal software installato(volumio) che d'altra parte è un' interfaccia molto intuitivo e facile da usare. Rapporto qualità prezzo comunque eccezionale ed ottimo apparecchio.
Matthieu L.
PUISSANCE, DOUCEUR, TRANSPARENCE ET SILENCE!
Je souhaite compléter mon avis du 15/12/2020 suite à l'utilisation d'un câble XLR4 à la place du 6.35, avec mon casque Kennerton Thekk. En effet, ce branchement en symétrique a fait totalement disparaître le "hum" (petit bruit de fond sourd, type bruit de vieux transformateur électrique), qui se produisait "à vide" (sans musique).
Merci à Audiphonics d'avoir pris le temps de vérifier ce souci sur un appareil en stock, et de m'avoir recommandé une solution efficace et répondant au souci.
L'écoute est désormais vraiment au top avec mon Thekk: cet ampli me semble globalement d'un très haut niveau, surtout en regard de ce prix!
J'ai la nette impression que le branchement en tout symétrique (en entrée depuis le dac et en sortie vers le casque) a "ouvert" l'écoute, et la sublime complètement! Il n'y a aucun crispation, c'est transparent, neutre mais pas du tout sec, froid, chirurgical: il y a beaucoup d'élégance, beaucoup de matière dans les timbres difficiles comme le violon ou le piano. A côte de cela, la dynamique est vraiment incroyable et dépasse celle de mon Sugden Masterclass HA4!
C'est tout simplement magnifique à mes oreilles :-) !
Jan Š.
Jan Sejvl
This DAC is much better than I could ever hope for.Used with Nordost cables Heimdall II and Tyr then sounds fantastic.
Still not explored all capabilities as I use it just like DAC at present.
This DAC makes me to enjoy every listening session and looking forward to next one.All my old CDs sound new to me and much better.The sound is very friendly and pleasant in my set up.
Emmanuel C.
Voilà, il m'a fait opter pour la Classe D
Voilà, je viens d'un gros ampli Technics de puissance faisant 17Kg le SU-A50 que j'affectionnais et qui a « presque » tenu la comparaison avec un Marantz SM11S1 sur des RF7 MKII de Kipsch.
Mon écoute principale est des « Monitor Audio Bronze 100 », probablement qu'un modèle supérieur me laisserait entrevoir les défauts de ce modèle.
J'avais commencé par un tout petit modèle vendu 44€ (AUDIOPHONICS TDA-S50) où la surprise fût de taille. Je lui reprochais juste son manque de rondeur et d'épaisseur. Je me suis dit, pourquoi ne pas essayer un pas plus haut ?
Ici toujours autant de netteté, même il me paraît plus rond avec un peu plus d'épaisseur que le modèle Audiophonic d'entrée de gamme avec le même intégré (TDA 7498E).
Bref, c'est un grave et un extrême grave bien soutenus, un médium bien présent et très précis avec des aigus soyeux et non agressifs. Les coups de grosses caisses sont bien marqués sans empiéter sur le reste. Les guitares acoustiques sont très nettes, très réalistes. Bref, c'est un vrai plaisir d'écoute. Les pianos sont claquants, les cuivres bien ciselés, ...
Aussi les instruments sont bien détachés les uns des autres, la scène sonore très précise (on entend bien les emplacements des instruments avec une bonne netteté). C'est une sonorité très limpide, ferme et bien remplie. La dynamique n'est pas en reste, c'est vivant.
Comparé à mon matériel de monitoring studio, la réponse en fréquence semble plate (sauf l'extrême grave que je ne sais pas comparer, puisque absent des moniteurs).
Oui, comme l'autre modèle et comme c'est souvent signalé, il y a un léger souffle, mais il faut vraiment des haut-parleurs sensibles et être vraiment à proximité.
L'alimentation livrée avec, paraît de bonne facture, en tout cas l'ampli tient 2 à 3 secondes une fois débranchée du secteur. Signe d'une bonne réserve.
Il chauffe un tout petit peu plus que le modèle TDA S-50, du moins on sent qu'il n'est pas complètement froid. L'autre restait glacé, mais avec une alimentation plus basse en tension.
En conclusion :
C'est un petit ampli qui tient la comparaison avec des gros-modèles hi-fi (ou mi-fi pour les puristes) haut de gamme (dans les marques courantes de l'époque), ou parfois fait mieux. Je vois que certains lui reprochent un manque de ceci ou cela en comparaison avec des modèles bien plus onéreux. Oui, c'est justement cela qu'il faut tenir compte, il frôle la qualité de gros-modèles plus réputés, alors qu'il est tout petit et vient du fin fond de la Chine. Bref, c'est d'un rapport qualité-prix bluffant.
Pour en revenir à mon gros Technics de 17 kg, je vais le mettre de côté. Ne parvenant pas à identifier lequel est le meilleur des deux, je n'ai pas de raison de le garder, surtout du point de vue consommation électrique.
Mathias B.
Pack SMSL AD18 V3 FDA / Q ACOUSTICS 3010i Speakers / Speaker Cables OFC 24K 3m This pack consisting of an amplifier Full Digital SMSL AD18 and a pair of loudspeakers Q Acouctics 3010i fintion Graphite Black will be perfect for a HIFI channel in mini...
Je voulais attendre quelques jours pour donner mon avis histoire de roder un peu les enceintes. Tout d'abord je tiens à remercier l'équipe de Audiophonics chez qui je n'ai aucune action qui ont toujours répondus à mes nombreux mails d'interrogations.
Donc cet ensemble très compact fonctionne à merveille croyez-moi C'est trs doux à faible volume et pendent des heures d'écoute on ne se lasse jamais et si vous montez le son ça suit et ça ne bouge pas.J'avais peur d'un manque de basse au début mais non c'est très naturel comme son et depuis le rodage effectué pas moins de 50 heures c'est mieux. Alors foncez un rapport qualité/prix imbattable!!!
quel équilibre !
j ai réalisé 2 jeux en rca avec masse supprimé d un côté.
et pour resté cohérent j ai utilisé le hp de 4mm de la même marque .
quelle classe !
c est charpenté , pas prise de tête , équilibré , défini , timbré et j en passe ...
du materiel de pro avec des exigences de pro au juste prix .
il y à bien longtemps que mon choix de câble se fait chez eux .
le reste n est que du vent .
fabuleux ! ( dans mes conditions d écoute bien évidement )
Marc T.
Etonnant !
Commandé par curiosité, et pour compléter un DAC qui ne traite que le 16bits en USB.
Quelle claque ! Il "enterre" ce dernier qui coûtait 40 fois plus cher et suréchantillonnait tout... J'entends enfin dans l'orchestre les cordes qui vibrent et les cuivres qui claquent.
Il révèle tous les défauts de ma chaîne secondaire ; du coup, j'attends de pouvoir le tester sur la principale pour voir s'il est vraiment exceptionnel. En tout cas, il l'est pour son prix !
voir mon avis sur la fiche noire .
Alessandro C.
Perfect product deserves perfect service... and you provided both!
I am so happy for the purchase. You guys at Audiophonics have super served me again. Super quick delivery despite the holiday season and delivery in a not easy to reach destination in the Italian Alps region.
You offered one of the best prices around for the UMIK-1. Just tested with REW and - gents! - it rocks! Could not be happier.
Than you, Alessandro.
un cadeau du ciel ?
sur la photo et au prix proposé on pouvait s attendre au pire . je ne souhaitais pas dépenser trop pour réaliser un câble à tester , et bien que nenni , la fiche est lourde , c est robuste , elle est plutôt grande , avantage ou défaut ? pour souder c est parfait , mais si peu de place derriere les appareils à eviter absolument .
le contacte est parfait . elle ne retire rien et ne rajoute rien ! chose que je n ai jamais constaté d ailleur .
j ai ésité avec les neutrik , je ne regrette pas mon choix !
pourquoi dépenser plus ?
Ronan b.
Conforme
Fonctionne correctement, assez facile à souder
Ronan b.
Knob Aluminium Notched Shaft 30x10mm Ø6mm Black This 30mm diameter and 10mm deep black Aluminium knob has a 6mm diameter notched pin. A perfect button for mounting on a DIY project or as a replacement for a damaged button, at...
Joli Bouton
Belle finition, facile à installer
Vukmir S.
Great power cable
Longer burn in than usual but really worth.
Improved sound in the every way.
Thicker instruments, bigger bass, and overall more juice.
Unbelievable low price for all that.
Finally closing my searching for a amplifier power cable.
Felix A.
Vinyl
Câble de connexion pour platine tourne-disque très bien adapté. Grâce à sa section transversale, il est conçu de manière optimale pour les petits signaux avec d'excellentes valeurs de capacité.
mariano N.
Ampli moyen.
sortie optique qui ne fonctionne quasiment pas après un mois d'utilisation, voire quand elle veut bien. Du coup je ne peux utiliser cet ampli que très rarement, voire pas du tout.
Je ne suis pas convaincu des qualités hifi de cet ampli. Je me suis orienté vers un nad 338. C'est le jour et la nuit.
Cet appareil n'a pas de sorties mais deux entrées optiques.
Aucun problème de cette nature n'est connu sur cet appareil.
Ce NAD n'est pas un FDA et coute 6 x plus cher, vous comparez des choses qui ne le sont pas vraiment ...
Erwan L.
L'interface est reconnue sans problème par Windows et Linux. Simple et efficace, pas besoin d'une interface avec un meilleur échantillonnage, le son est très bon sur la sortie optique.
Julien Anne B.
Juste parfait.
Excellente qualité audio. Excellente fabrication. Très joli design.
Correspond exactement à ce qui était décrit et à ce que j'attendais.
Livraison très rapide.
Rosen L.
A great DAC!
A great DAC overall. Miles better than D30, also better than KhadasTB. With good treble details and not fatiguing, mid's are a little life like and sweet, bass i s great but lacking a little detail. It has a sense of 3d and depth. Also instruments separation is great for the price. It works flawlessly and works well with DSD too. I Use FB2K and JRIVER on a PC.
Also when connected to a Android(6) media player with USB Spotify and Tidal cannot play. When using specialized audio player it reserves the USB connection and it plays well!
If i use optical output on the Android player it is playing great Spotify and Tidal great. On Tidal it is not outputting more than 48khz but i think my player is the problem!
Laurent S.
TINYSINE TSA3118B Amplifier Module TPA3116D2 Bluetooth aptX TWS 2x50W This amplifier module from TinySine is based on a TPA3116D2 amplifier chip that can deliver up to 2x50W while offering very good efficiency thanks to its Class D architecture....
Installer dans une enceinte portable diy sur 2 haut parleurs de 35w. Parfait juste un très léger grésillement quand il n'y a pas de musique mais seulement audible avec un silence total.
Didier B.
écoute
excellent avec un aigu très propre par rapport à d'autres convertisseurs pourtant plus chers mais plus anciens.
