I use this wire for many thing, from cables, to internal wiring, and etc. Always perfect. Isolation is quite fat and strong, what sometime hel, sometime been hard. But it work perfect. Wire by him self is perfect. Recommend!
High Purity Silver Plated OFC Copper Wiring Cable PTFE Sleeve 0.5mm² Ø 3mm Transparent
This cable wire incorporates a high-purity OFC Copper conductor with a cross-section of 0.5mm² with Silver plating, ensuring excellent conductivity while being resistant to oxidation. The conductor is covered with a transparent PTFE insulating sheath for an external diameter of 3mm. This cable will allow you to carry out the internal wiring of your DIY devices and projects.
Product type | Wiring cable |
Conductor material | OFC Copper |
Conductor section | 0.5mm² |
Conductor plating | Silver |
Sleeve material | PTFE |
Cable diameter | 3mm |
Min / Max temperature | -65°C / +200°C |
Sleeve color | Transparent |
Quantity | Sold per meter |
Diameter (mm) | 3.0 |
Length (m) | Sold by length |
Number of conductors | 1 |
Insulation material | PTFE |
Shielding | No |
Section (mm²) | 0.50 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | Silver |
Ground / Shielding | No |
Average votes 4.5 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Pavol B.
Pavol B.
