DAYTON AUDIO MA880 Multiroom Amplifier 8 Channel
The Dayton Audio MA880 is an 8-channel Class D amplifier designed for audio distribution across multiple independent zones. It delivers 80W RMS per channel under 8Ω and 160W under 4Ω, utilising a modular architecture comprising four stereo zones.
By buying this product you get 84 loyalty points
Reference : 21834
849,00 €tax incl.
707,50 € tax excl.
Dayton Audio MA880 Multiroom Amplifier 8-channel Class D 8x160W 4 Ohm
Dayton Audio MA880 : Front view
Designed for both multi-room systems and home cinema setups, it combines flexible source routing with independent zone management, allowing the sound output to be precisely tailored to each room.
Dayton Audio MA880: 8x160W amplification
The amplifier features 8 channels delivering 80W RMS under 8Ω and 160W under 4Ω, enabling multiple zones to be powered simultaneously with a comfortable power reserve. This configuration also allows two channels to be bridged, increasing the power to 160W RMS at 8Ω, enabling the amplification to be adapted as required for more demanding speakers or main zones.
In addition to this flexibility, the use of a Class D topology optimises energy efficiency, resulting in minimal heat dissipation and stable operation during prolonged use, particularly in multi-room environments where multiple channels are in constant use.
Dayton Audio MA880: Independent multi-zone organisation
The amplifier is organised into four independent stereo zones, each associated with a dedicated line input, allowing a specific source to be assigned to each zone according to broadcasting requirements. This structure is complemented by two stereo BUS inputs shared by all channels, which allows the same source to be distributed across multiple zones whilst retaining the option for local differentiation. The zone-specific source selector switches between the local input and the BUS, thus allowing the routing to be adapted without the need for an external matrix, in line with a direct and scalable cabling approach.
This approach is complemented by individual gain control per zone, allowing the output level to be precisely adjusted to suit the speakers or the acoustics of each room, thereby ensuring overall listening consistency. At the same time, the pass-through line outputs allow multiple amplifiers to be daisy-chained, naturally extending the system to larger-scale multi-room setups whilst maintaining the integrity of the distributed signal.
Dayton Audio MA880 : Connectivity
Dayton Audio MA880 : Connection diagram
1115V/230V voltage selector switch
2IEC socket
3Fuse
4Common line inputs/outputs
5Dedicated line input
6Source selector
7Gain adjustment
812V trigger input
9Trigger/Auto mode selector
10Speaker output terminals
1112V trigger output
Product typeMulti-room amplifier
Inputs6x RCA
Outputs4x Phoenix speaker terminal
Channels8
Bridgeable
Output power8x80Wrms @ 8Ω
8x160Wrms @ 4Ω
4x160Wrms @ 8Ω (bridge mode)
Frequency response20Hz-20kHz
Input sensitivity680mV
Signal-to-noise-ratio (SNR)106dB
Total harmonic distortion (THD)<1%
Trigger voltage12V
Power supply voltage115VAC/60Hz - 230VAC/50Hz
Dimensions482.6 x 36.2 x 101.6mm
Weight7.2kg
Package1x Dayton Audio MA880
2x Rack Mounting Brackets
1x Rack Mount Installation Kit
4x 4 Pole Phoenix cable
1x Power Cable
OutputPhoenix connector
Channel8
Amplifier chipN/A
Power (W)80.0
Power (W)160.0
DAYTON AUDIO MA880 Multiroom Amplifier 8 Channel Class D 8x160W 4 Ohm
The Dayton Audio MA880 is an 8-channel Class D amplifier designed for audio distribution across multiple independent zones. It delivers 80W RMS per...
