AUDIOPHONICS MPC6 V2 CLC Power distributor 6 ports Aluminum FURUTECH Black
By buying this product you get 39 loyalty points
Reference : 11706
399,00 €tax incl.
332,50 € tax excl.
AUDIOPHONICS MPC6 V2 CLC Distributeur secteur 6 ports Aluminium FURUTECH Noir
The Audiophonics MPC6 V2 CLC represents the new generation of high-end power sockets / filters. With a revised and corrected finish with rounded nails, a better mechanical resistance of the whole, the Audiophonics MPC6 V2 allows great possibilities of sector optimization.
This new generation MPC6 V2 CLC includes a new aluminium finish with rounded corners with a better finish and increased electromechanical performance.
This Audiophonics MPC6 V2 mains distributor contains a PI filter (CLC) allowing the attenuation of harmonics derived from the 50Hz polluting the musical signal. This elegant solution allows a high efficiency in terms of results without damaging the dynamics of the sound message. The components for this mounting allow a maximum current of 16A.
The advantages of the PI CLC filter are many:
  • Reduction of electromagnetic pulses (EMI) and interference on radio frequencies.
  • Protection against transient overvoltages (Metal Oxide (MOV) varistors (max supported current: 6.5Ka).
  • Immunity from external noise and emission reductions to the mains supply.
Throughout the process of creating this product, the emphasis has been placed on the choice of materials in order to obtain one of the best possible mains interconnections.
The connectors are entirely from Furutech sources and treated with the famous Alpha process, the ELECAUDIO wiring wire has been selected for its monocrystalline OCC copper, PTFE insulation and very low impedance. The retained tips allow a better contact and an increased protection against corrosion, the aluminium case has been selected for its solidity, inertia and robustness.
Here are the IEC, Schuko, and wiring sockets used for the Audiophonics MPC6 V2:
Schuko Connector :
IEC Connector :
Câblage :
Product typePower distributor
Number of Schuko plugx6 Gold Plated Pure Copper Schuko FI-E30
IEC PlugFurutech FI-06
Anti-slip rubber feetYes
Housing panels thicknessFront/Back panels: 3.5mm
Side panels: 3.5mm
Top panel: 8mm
Bottom panel: 3mm
Dimensions340 x 123 x 75mm
Weight2.34kg
